Great, will this on short term be pushed to HACS as well, or would you advice me to install this manually on HA?
You can click on âUpdate informationâ in HACS and then you should get a notification few seconds later about the new version.
Hallo Rene,
thanks for the update.
Thanks for the quick fix. works again (german user).
There is an early support for default value handling for sensors. (âŚ) get in touch with me whenever you want to test this)
Can I test this?
Hi Thomas,
I will send you a private message with some instructions over the weekend.
BR
Rene
There are also geo-coordinates offered in the API. Is it planned to also transmit them to home assistant?
Hi @ssonder,
Welcome in this community and the MB thread.
The coordinates are published via the device tracker since several years already. Please check your available device trackers.
First check if the location data is available in your MB mobile app. If not check the purchased licenses.
On December 15th, my Mercedes Me (mbapi2020) all of a sudden stopped working: There is no error message in the integration or the device, but all entities are âunavailableâ.
I donât find error messages when I enable debug loggin on the intergation. Just these messages:
2023-12-20 11:01:12.885 DEBUG (MainThread) [custom_components.mbapi2020.websocket] Got notification: assigned_vehicles
2023-12-20 11:01:12.894 DEBUG (MainThread) [custom_components.mbapi2020.websocket] Got notification: apptwin_pending_command_request
2023-12-20 11:01:27.883 DEBUG (MainThread) [custom_components.mbapi2020.websocket] Got notification: assigned_vehicles
2023-12-20 11:01:27.892 DEBUG (MainThread) [custom_components.mbapi2020.websocket] Got notification: apptwin_pending_command_request
Can someone tell me how I should try to find and correct this issue?
Thanks in advance
Hi @WimG ,
In the 15th MB changed their API endpoints and a few hours later a new version of this component was released.
Check the postings in this thread and make sure you installed the latest version
BR
Rene
Hi Rene,
thanks for the reply.
One of the actions I did to try to solve the issue, was indeed to upgrade to the latest version. Both home-assistant and the MercedesMe2020 code.
I tried and tried again re-configuring the integration and never got it working. I did notice that the integration saw no problems but no entities were active.
In home-assistant.log (now already replaced by a new version), I noticed that the Mercedes cloud api reported no cars found, with the data sent to it.
In the end I deleted the configuration and the .mercedesme-token-cache and reconfigured everything. Than it worked and the carâs details all came back correctly, with the same name as before.
I donât know what was at the root of all of this and Iâm afraid the data to find out are already gone.
But Iâm a happy user again.
Happy holidays,
Wim
I have published a new minor release v0.9.9 to keep up with some changes in HA 2024.01.
Notable changes:
- Sensor âCharging Powerâ gets created even if the API does not provide values at HA startup.
Fixes:
Removal of a couple of deprecation warnings that otherwise would appear in Home Assistant 2024.1.0
Notes:
The sensor âcharging powerâ is created for all vehicles, even if the vehicle has no charging options. Please ignore or hide the sensor if needed. Thanks to @Thomas01 and @Markus76 for testing.
Thank you very much.
Thats incidentially the next step in clobbering together the data I need for a proper implementation of live data for A Better Routeplanner (ABRP - https://abetterrouteplanner.com/).
For the minimum set (according to ABRP) I still need the following things:
- Vehicle speed
- Power output (during driving)
Rene, does the Mercedes API supply these values in any way?
I can share what I have done so far to enable live data for ABRP using Home Assistant with Reneâs integration.
Thanks, and have a nice NYE.
Thomas
Thanks for the update!
I can confirm the sensor âcharging powerâ now works all the time. But I noticed the sensor has a value of -1 kW when not connected to a wallbox. The value is 0 kW when the car is connected but not charging and the value when charging is spot on with the value depicted in the Me-app.
Is that negative value when not charging and not being connected to a charger intended the be like that?
Hi @Thomas01 ,
current actual values are not available via the API but you can use the avarage values.
Power output since since start is the attribute âelectricconsumptionstartâ of the rangeelectric sensor. The average speed is available via the sensor âID_average_speed_startâ.
BR
Rene
Hi @M31Galaxy15287 ,
this is correct, whenever the API does not provide values, I use -1 as the initial default value for the charging power sensor. I decided to set this value to have a chance to react later on. Is this value a problem?
Yes, if using an utility meter to count the used energy⌠I would prefer to be 0
With the next release the default value is 0. The change is done in the master branch on github already, in case someone would like to test it.
And, can someone test if the missing unit at startup causing problems with the statistics? Background: I always use the reported unit from the API and as the API does not provide a value, I also donât know the unit.
A Better Routeplanner with Home Assistant
Goal:
Supply (realtime) data to A Better Routeplanner (ABRP).
This task is has two big steps, which are
- Setup ABRP Live Data
- Push Data from HA to ABRP
In Detail, these are:
1.1. Get (user) Token for your car from ABRP
1.2. Obtain API key for ABR
2.1. Setup Automation to send a REST URL in regular intervals to ABRP
2.2. Construct the REST URL
2.3. Set up various sensor data for the REST URL
1.1/1.2 Get Token and API key from ABRP.
To get the user token for the car in ABRP, select the car, click on âLive dataâ, then on âLink Genericâ. Note the Token.
To get the API key, send an email to [email protected] and request a âTelemetry-Only API keyâ. See also the API documentation under Iternio Telemetry API (via https://www.iternio.com/api âTelemetry APIâ).
For the HA stuff, we start from the end and move to the beginning.
Note: I have an EQS, hence a lot of my examples are named EQS. Feel free to substitute your own names. Also, I redacted my licence plate number in all the component names in HA, set all instances of "XXX"
to your car.
2.3. Set up Sensor Data
ABRP interprets negative power as charging the car, and positive power for driving. As the MercedesME API does not provide driving power, and only charging power in positive value, we need first to invert the charging power. Also ABRP expects status information (car is parked, car is charging, car is fast charging) as either 1 or 0, so we have to mangle these also.
sensors:
eqs_power_abrp:
friendly_name: EQS Power for ABRP
icon_template: mdi:flash
value_template: >
{% if states('sensor.XXX_charging_power')|float(0) > 0 %}
{{states('sensor.XXX_charging_power')|float(0)*(-1)}}
{% else %}
0
{% endif %}
sensors:
eqs_is_charging:
friendly_name: EQS is charging
value_template: >
{% if state_attr('sensor.XXX_range_electric', 'chargingstatus') in ["0", "5", "6", "9", "10", "11"] %}
1
{% else %}
0
{% endif %}
sensors:
eqs_is_dc_charging:
friendly_name: EQS is DC charging
value_template: >
{% if state_attr('sensor.XXX_range_electric', 'chargingstatus') in ["6", "11"] %}
1
{% else %}
0
{% endif %}
sensors:
eqs_is_parking:
friendly_name: EQS is parking
icon_template: mdi:car-brake-parking
value_template: >
{% if is_state('binary_sensor.XXX_park_brake_status', "off") %}
0
{% else %}
1
{% endif %}
Put your own token and API key in.
As we do not have the driving power available, I removed the power (and speed) parameter if the car is not charging. Under âcar_modelâ, I do supply the car model again (donât know if its necessary, as the token was already generated for a specific car in your ABRP account). To get the description of the car, send an API request of https://api.iternio.com/1/tlm/get_carmodels_list (no key or token required). You may also skip supplying the car model.
You could also check the proper construction of the url in HA under âDeveloper Toolsâ â âTEMPLATEâ.
Copy everything in the url part (from "{% set token"
to and including "https://api.iternio.com/1/tlm..."
), paste it into the template editor, copy the result and paste it into your browser. Check the response, and if OK, check the ABRP website.
rest_command:
abrp:
url: >
{% set token = "TOKEN" %}
{% set api_key = "APIKEY" %}
{% set power = "" %}
{% if is_state('sensor.eqs_is_charging', "1") %}
{% set power = ", \"speed\":0, \"power\":"~states('sensor.eqs_power_abrp') %}
{% endif %}
https://api.iternio.com/1/tlm/send?token={{token}}&api_key={{api_key}}&tlm={"utc":{{utcnow().strftime("%s")}}, "soc":{{states('sensor.XXX_state_of_charge')}}{{power}}, "lat":{{state_attr('device_tracker.XXX_device_tracker','latitude')}}, "lon":{{state_attr('device_tracker.XXX_device_tracker','longitude')}}, "is_charging":{{states('sensor.eqs_is_charging')}}, "is_dcfc":{{states('sensor.eqs_is_dc_charging')}}, "is_parked":{{states('sensor.eqs_is_parking')}}, "heading":{{state_attr('device_tracker.XXX_device_tracker', 'positionHeading')}}, "odometer":{{states('sensor.XXX_odometer')}}, "est_battery_range":{{states('sensor.XXX_range_electric')}}, "car_model":"mercedes:eqs:22:108:rwd"}
method: POST
headers:
content_type: "charset=utf-8; application/x-www-form-urlencoded"
Now that the REST command has been constructed, use an Automation to push regular updates of your car to ABRP.
Goal here:
If driving or charging, update ABRP every 5 seconds (as recommended by ABRP). Also continue updating every 5s up to 30s after parking (to accurately get the parked position and state). Start the 5s update shortly before driving (ie when the doors are unlocked).
And finally, if parked, update only every hour.
Some of these conditions may be redundant, havenât cleaned them up yet, works fine for me.
alias: ABRP upload
description: Uploads EQS data to A Better Routeplanner
- platform: time_pattern
seconds: /5
condition:
- condition: or
conditions:
- condition: template
value_template: "{{ now().minute == 27 and (28 < now().second < 33) }}"
- condition: numeric_state
entity_id: sensor.eqs_is_charging
above: "0"
entity_id: sensor.eqs_is_parking
below: "1"
- condition: not
conditions:
- condition: state
state: "1"
for:
hours: 0
minutes: 0
seconds: 30
entity_id: sensor.XXX_lock
above: "0"
attribute: doorLockStatusOverall
- service: rest_command.abrp
data: {}
mode: single
And that should take care of an automated update of ABRP from HA.
Many thanks to Rene for the MercedesMe 2020 integration, that makes this all possible.
The integration stopped working this morning. Itâs asking me to reconfigure. I delete the Cache file and when I enter my email address for the PIN it never gets sent. I tried it a few times. Any ideas?
Hi, what is your region? Are you on version 0.9.8 at minimum? What is the output of debug log? And did you startet the mobile app and checked the app?
Region: Europe (Ireland)
Version: 0.9.9
Mobile app is working fine
Let me check log
