Hi Rene. I am new to github so unsure how to create a new issue. I will look into it though as it is something I definitely need to learn. A quick note, I uninstalled and reinstalled again and everything was working for a few days but now it is not working again and all of the entities are showing unavailable. I am getting the ‘failed to setup’ error again.
yes, i redownloaded the Master-Branch. Then Beta.1
Reported Version: v0.11.0-beta.1
CHARGE_PROGRAM_CONFIGURE is true.
I have 2 cars connected. Only one support this (Diagnostic: 1x false, 1x true).
Update to Beta.2:
Works perfect! Thanks a lot!
ReneNulschDE
(Rene Nulsch (on vacation until mid of Oct. - expect slower responses))
1744
I have published a new version v0.11.1:
New:
Sensor: lastParkEvent (datetime), Attributes parkEventType (area of the car where the incident happened), parkEventLevel (level of the incident (low,medium,high) (see readme for int translation)
Sensor: Interior Protection (int), 0 and 1 = Not active, 2 = Active
Add “_last_full_message” to diagnostic log (contains the original MB data)
Experimental: New Service Charge_Program_Configure to select the active charge_program 0=default, 2=Home, 3=Work
Fixes:
Smart cars are available again
AuxHeat switch is back
Other:
Protos updated to latest Google Protobuf version
ReneNulschDE
1745
In case you get errors in your log like:
2024-02-22 09:45:50.209 INFO (MainThread) [custom_components.mbapi2020.websocket] Connecting to wss://websocket.emea-prod.mobilesdk.mercedes-benz.com/ws
2024-02-22 09:45:50.351 ERROR (MainThread) [custom_components.mbapi2020.websocket] Could not connect to wss://websocket.emea-prod.mobilesdk.mercedes-benz.com/ws, retry in 10 seconds...
2024-02-22 09:45:50.351 DEBUG (MainThread) [custom_components.mbapi2020.websocket] 429, message='Invalid response status', url=URL('wss://websocket.emea-prod.mobilesdk.mercedes-benz.com/ws')
or your mobile phone is in the same network line HA and the MB app is not working anymore.
Looks like MB has activated some request throttling this morning and only one connection per is possible.
I am seeing those two errors after the upgrade. It can´t login anymore. For me it looks like it has difficulties with my second Mercedes which is an old CLK convertible that does not support Mercedes ME functions ?!?!
Dieser Fehler wurde von einer benutzerdefinierten Integration verursacht
Logger: custom_components.mbapi2020.webapi
Source: custom_components/mbapi2020/webapi.py:109
Integration: MercedesME 2020 (documentation, issues)
First occurred: 20:14:13 (6 occurrences)
Last logged: 20:17:38
Error requesting: https://bff.emea-prod.mobilesdk.mercedes-benz.com/v1/vehicle/WDB208xxxxxxx/capabilities - 403 - 0 -
Error requesting: https://bff.emea-prod.mobilesdk.mercedes-benz.com/v1/vehicle/WDB208xxxxxxx/capabilities/commands - 403 - 0 -```
**[u]and this one[/u]**
Logger: homeassistant.config_entries
Source: config_entries.py:444
First occurred: 20:14:13 (3 occurrences)
Error setting up entry [email protected] (Region: Europe) for mbapi2020
File "/usr/src/homeassistant/homeassistant/config_entries.py", line 444, in async_setup
result = await component.async_setup_entry(hass, self)
File "/config/custom_components/mbapi2020/__init__.py", line 107, in async_setup_entry
for feature in capabilities.get("commands"):
AttributeError: 'NoneType' object has no attribute 'get'
Might be a little off-topic, but maybe not: did anyone manage to integrate the current Mercedes Wallbox (EVBox) into HA since there are no entities available in this component?
ReneNulschDE
1751
Hi Sven, this component does not currently have Mercedes Wallbox integration, as I don’t have such a box nor access to one. As far as I know, evcc.io has a EVBox integration and has HA-integration too.
Bit of a weird one. Not sure if homeassistant issue or component issue…
I’ve renamed my device to “car” from the vehicle registration number (a bit more intuitive) and I ticked the “update entity IDs” option, however I’ve noticed that quite a few of the entity IDs do not update to the new “car” name but retain the old reg number format…
I’ve had to reinstall the component quite a few times recently, which means updating the device name each time to “car” so my automations/dashboards still work, then I have to go, one-by-one, and update those entity IDs that do not re-name.
Any ideas? Does what I’ve written make sense?!
ReneNulschDE
1754
Hi Matt,
hard to say what went wrong… If you like, you can send me core.entity_registry out of the .storage folder with some examples where the renaming went wrong and where it was successful. Then I can check for some component related problems.
ReneNulschDE
1759
Question of the day: Does your mbapi2020.Sunroof Service to open or close the sunroof works? Its not working for my car with a general MB-error. In the official app it is also not available.
I tried to configure OCPP but was not successful. Even though the Wallbox is in my network, the OCPP HA integration gets no connection to the Wallbox. I think you need to setup OCPP in the Wallbox configuration first.
EvBox offers 2 apps in this regard:
EvBox Install (that I successfully used for Wallbox FW update)
EvBox Connect (that is not working since it only connects via Bluetooth on the setup and the Mercedes EvBox does not support Bluetooth)
As far as I am informed, you can only configure OCPP with EvBox Connect.
The Mercedes me app is a joke in regards to the Wallbox options. It does not offer any configuration.
