Mesh multiple HA servers together
It would be cool if you could Mesh multiple HA servers together.
Example:
You have your main Homeassistant running on a central server on your network. There also is a second server only meant for a specific task like handling AI in local Assist. Another feature request meant that there should be a Mixtral chatbot integration that runs locally. You could make a seperate server just for running the chatbot.
Or if you have a homeassistant in a big building you could have a seperate server for each parts of a building all connected to each other.
Or doing just general workload balancing.
Would be cool to have it…
If you think it’s a good idea, you should vote for it. I did…
Suggested Reading:
Feature Request Guidelines :notebook_with_decorative_cover: - Feature Requests - Home Assistant Community.
Mesh means that all servers would be able to handle requests, which is not really what you describe.
Your description is to offload some work, which can be done with add-ons already or with services that have a well-known interface, like database servers or MQTT brokers.
You also suggest workload balancing, but that requires a setup with hardware that can be shared or coexist, which is often not the case with many of the technologies used in IoT today.
You also mention a big building with many servers, which would still require a main server, but this setup can already be made with the Remote HA integration.
Due to their architecture It is not possible to share Z-Wave and ZigBee resources between different HA systems concurrently and with fail over.
Z networks have a single point of failure issue with the coordinator
True and only way to use multiple HA iinstallations with these technologies is to split it out to its own unit, like with a MQTT gateway.
This will not remove the single point of failure, but it will make it possible to connect multiple HA installations simultaneously.
I like the mesh idea. Admittedly Z* networks would be an issue, and if the device with the radio went down, those devices would be lost to the mesh.
Still, for testing and debugging, load management and failover of a dead HA host, this would be a great option.
Voted!
I would like to see this too. Even if devices behind a gateway like Z-wave couldn’t be setup to fail-over, a hive system would allow for many other benefits like managing multiple locations, unified user management between locations, dashboards that show device status at multiple locations, automations that control devices between different locations, etc.
I use a CCTV system now that allows multiple servers to be combined (www.networkoptix.com) into a hive. It is quite nice for managing cameras at two or more locations through a single interface.
