Message malformed: expected str for dictionary value @ data['device_id']
Hello, hoping someone can help me figure out why I am getting the error: “Message malformed: expected str for dictionary value @ data[‘device_id’]” when trying to save a blueprint automation. Here is my code in two files:
File 1:
blueprint:
  name: Z-Wave Command Queue
  description: >
    Safely executes Z-Wave commands with proper delays to prevent
    overwhelming the Z-Wave network.
  domain: script
  input:
    device_id:
      description: The Z-Wave device to send commands to
      selector:
        device:
          filter:
            model: ZEN32
    commands:
      description: List of parameter updates to execute
      selector:
        object:
    command_delay:
      description: Delay between commands in milliseconds
      selector:
        number:
          min: 50
          max: 500
          unit_of_measurement: ms
          step: 10
      default: 150
sequence:
  - repeat:
      for_each: "{{ commands }}"
      sequence:
        # Execute the Z-Wave command with proper parameters
        - device_id: "{{ device_id }}"
          domain: zwave_js
          type: set_config_parameter
          endpoint: "{{ repeat.item.endpoint | default(0) }}"
          parameter: "{{ repeat.item.parameter }}"
          bitmask: "{{ repeat.item.bitmask | default }}"
          subtype: "{{ repeat.item.subtype | default }}"
          value: "{{ repeat.item.value }}"
        # Add delay between commands (skip delay after last command)
        - if:
            - condition: template
              value_template: "{{ not loop.last }}"
          then:
            - delay:
                milliseconds: "{{ command_delay }}"
FIle 2:
# File: dimmable_room.yaml
# Location: config/blueprints/automation/
blueprint:
  name: Dimmable Room Control
  description: >
    Controls a room with Off/Dim/Max states using multiple scene controllers.
    Supports toggling between states and synchronizes LED indicators across
    all controllers to prevent Z-Wave network overload.
  domain: automation
  input:
    room_helper:
      description: The input_select helper tracking room state (must have Off, Dim, Max options)
      selector:
        entity:
          filter:
            domain: input_select
    scene_max:
      description: Scene to activate when room is set to Max brightness
      selector:
        entity:
          filter:
            domain: scene
    scene_dim:
      description: Scene to activate when room is set to Dim
      selector:
        entity:
          filter:
            domain: scene
    scene_off:
      description: Scene to activate when room is turned Off
      selector:
        entity:
          filter:
            domain: scene
    light_toggle_controllers:
      name: Light Toggle Buttons
      description: >
        Controllers and buttons that toggle between Max and Off.
        For each entry, select the device and specify which button number (1-5).
      selector:
        device:
          filter:
            integration: zwave_js
          multiple: true
    light_toggle_button_numbers:
      name: Light Toggle Button Numbers
      description: >
        Button numbers for Light toggle (1-5), in same order as devices above.
        Separate multiple buttons with commas (e.g., "5,5,5").
      selector:
        text:
      default: "5"
    dim_toggle_controllers:
      name: Dim Toggle Buttons
      description: >
        Controllers and buttons that toggle between Dim and Max.
      selector:
        device:
          filter:
          multiple: true
    dim_toggle_button_numbers:
      name: Dim Toggle Button Numbers
      description: >
        Button numbers for Dim toggle (1-5), in same order as devices above.
        Separate multiple buttons with commas (e.g., "2,2,2").
      selector:
        text:
      default: "2"
    command_delay:
      description: Delay between Z-Wave commands in milliseconds
      selector:
        number:
          min: 100
          max: 500
          step: 10
      default: 150
mode: queued
max: 2
variables:
  # Map button numbers to property_key values for triggers
  button_map:
    "1": "001"
    "2": "002"
    "3": "003"
    "4": "004"
    "5": "005"
  # Parse the comma-separated button numbers into lists
  light_button_numbers: >-
    {% set numbers = (light_toggle_button_numbers | string).split(',') %}
    {% set parsed = [] %}
    {% for num in numbers %}
      {% set parsed = parsed + [num | int] %}
    {% endfor %}
    {{ parsed }}
  dim_button_numbers: >-
    {% set numbers = (dim_toggle_button_numbers | string).split(',') %}
    {% endfor %}
    {{ parsed }}
  # Automatically determine all controllers that need LED updates
  all_controllers: >-
    {% set controllers = [] %}
    {% for device in light_toggle_controllers %}
      {% if device not in controllers %}
        {% set controllers = controllers + [device] %}
      {% endif %}
    {% endfor %}
    {% for device in dim_toggle_controllers %}
      {% endif %}
    {% endfor %}
    {{ controllers }}
  # LED indicator parameters map button numbers to config parameters
  led_param_map:
    "1": 2
    "2": 3
    "3": 4
    "4": 5
    "5": 6
triggers:
  # Room helper state change trigger
  - id: room_state_change
    trigger: state
    entity_id: !input room_helper
  # Light toggle button triggers (dynamically added for each controller/button pair)
  - id: light_toggle_press
    trigger: device
    device_id: !input light_toggle_controllers
    domain: zwave_js
    type: event.value_notification.central_scene
    property: scene
    property_key: >-
      {% set controllers = light_toggle_controllers %}
      {% set buttons = light_button_numbers %}
      {% set idx = trigger.idx | default(0) %}
      {% if idx < buttons | length %}
        {{ button_map[buttons[idx] | string] }}
      {% else %}
        "005"  # Default to button 5 if mismatch
      {% endif %}
    endpoint: 0
    command_class: 91
    value: 0
  # Dim toggle button triggers (dynamically added for each controller/button pair)
  - id: dim_toggle_press
    trigger: device
    device_id: !input dim_toggle_controllers
    domain: zwave_js
    property: scene
    property_key: >-
      {% set controllers = dim_toggle_controllers %}
      {% set buttons = dim_button_numbers %}
      {% else %}
        "002"  # Default to button 2 if mismatch
      {% endif %}
    endpoint: 0
    command_class: 91
    value: 0
  - choose:
      # Light toggle button was pressed
      - conditions:
          - condition: trigger
        sequence:
          - if:
              - condition: state
                state: "Off"
            then:
              - action: input_select.select_option
                  option: "Max"
            else:
                  option: "Off"
      # Dim toggle button was pressed
      - conditions:
        sequence:
          - if:
              - condition: state
                state: "Dim"
            then:
                  option: "Max"
            else:
                  option: "Dim"
      # Room state changed
      - conditions:
        sequence:
          - choose:
              # State changed to Max
              - conditions:
                    value_template: "{{ trigger.to_state.state == 'Max' }}"
                sequence:
                  # Activate scene first (high priority)
                  - action: scene.turn_on
                      entity_id: !input scene_max
                  # Update LED indicators on all controllers
                  - repeat:
                      for_each: "{{ all_controllers }}"
                      sequence:
                        - action: script.zwave_command_queue
                            device_id: "{{ repeat.item }}"
                            command_delay: !input command_delay
                            commands:
                              # Light toggle button (usually #5) - white
                              - parameter: 6
                                subtype: 6 (LED Indicator Color (Relay)) on endpoint 0
                                value: 0
                              # Dim toggle button (usually #2) - off
                              - parameter: 3
                                subtype: 3 (LED Indicator (Button 2)) on endpoint 0
                                value: 2
              # State changed to Dim
              - conditions:
                    value_template: "{{ trigger.to_state.state == 'Dim' }}"
                sequence:
                      entity_id: !input scene_dim
                  - repeat:
                      sequence:
                            commands:
                              # Dim toggle button (usually #2) - on
                              - parameter: 3
                                value: 3
                              - parameter: 6
                                value: 0
              # State changed to Off
              - conditions:
                    value_template: "{{ trigger.to_state.state == 'Off' }}"
                sequence:
                      entity_id: !input scene_off
                  - repeat:
                      sequence:
                            commands:
                              # Light toggle button (usually #5) - blue
                              - parameter: 6
                                value: 1
                              - parameter: 3
                                value: 2
You need to use !input where you are using the values directly, and assign the inputs to script variables where you need them in templates:
You cannot use templates in a Device Action.
Thanks for your help! I modified the code, but still getting the error. Any idea what I am doing wrong?
File 1:
blueprint:
  description: >
  domain: script
  input:
    device_id:
      selector:
        device:
          filter:
            model: ZEN32
    commands:
      selector:
        object:
    command_delay:
      selector:
        number:
          min: 50
          max: 500
          step: 10
      default: 150
variables:
  # Extract the device_id string from input if needed
  device_id_str: "{{ device_id if device_id is string else device_id.id if device_id is mapping and device_id.id is defined else device_id }}"
sequence:
  - repeat:
      sequence:
        - device_id: "{{ device_id_str }}"
          domain: zwave_js
        - if:
          then:
            - delay:
File 2:
blueprint:
  description: >
  domain: automation
  input:
    room_helper:
      selector:
        entity:
          filter:
    scene_max:
      selector:
        entity:
          filter:
            domain: scene
    scene_dim:
      selector:
        entity:
          filter:
            domain: scene
    scene_off:
      selector:
        entity:
          filter:
            domain: scene
      description: >
      selector:
        device:
          filter:
          multiple: true
      description: >
      selector:
        text:
      default: "5"
      description: >
      selector:
        device:
          filter:
          multiple: true
      description: >
      selector:
        text:
      default: "2"
    command_delay:
      selector:
        number:
          min: 100
          max: 500
          step: 10
      default: 150
mode: queued
max: 2
variables:
  # Store input values for use in templates
  room_helper_input: !input room_helper
  scene_max_input: !input scene_max
  scene_dim_input: !input scene_dim
  scene_off_input: !input scene_off
  light_toggle_controllers_input: !input light_toggle_controllers
  dim_toggle_controllers_input: !input dim_toggle_controllers
  command_delay_input: !input command_delay
  button_map:
    "1": "001"
    "2": "002"
    "3": "003"
    "4": "004"
    "5": "005"
    {% endfor %}
    {{ parsed }}
    {% endfor %}
    {{ parsed }}
  all_controllers: >-
    {% for device in light_toggle_controllers_input %}
      {% endif %}
    {% endfor %}
    {% for device in dim_toggle_controllers_input %}
      {% endif %}
    {% endfor %}
    {{ controllers }}
  led_param_map:
    "1": 2
    "2": 3
    "3": 4
    "4": 5
    "5": 6
triggers:
    trigger: state
    trigger: device
    domain: zwave_js
    property: scene
    property_key: >-
      {% set controllers = light_toggle_controllers_input %}
      {% else %}
      {% endif %}
    endpoint: 0
    command_class: 91
    value: 0
    trigger: device
    domain: zwave_js
    property: scene
    property_key: >-
      {% set controllers = dim_toggle_controllers_input %}
      {% else %}
      {% endif %}
    endpoint: 0
    command_class: 91
    value: 0
  - choose:
      - conditions:
        sequence:
          - if:
              - condition: state
                state: "Off"
            then:
                  option: "Max"
            else:
                  option: "Off"
      - conditions:
        sequence:
          - if:
              - condition: state
                state: "Dim"
            then:
                  option: "Max"
            else:
                  option: "Dim"
      - conditions:
        sequence:
          - choose:
              - conditions:
                sequence:
                  - repeat:
                      sequence:
                            device_id: "{{ repeat.item.id if repeat.item is mapping and repeat.item.id is defined else repeat.item }}"
                            command_delay: "{{ command_delay_input }}"
                            commands:
                              - parameter: 6
                                value: 0
                              - parameter: 3
                                value: 2
              - conditions:
                sequence:
                  - repeat:
                      sequence:
                            commands:
                              - parameter: 3
                                value: 3
                              - parameter: 6
                                value: 0
              - conditions:
                sequence:
                  - repeat:
                      sequence:
                            commands:
                              - parameter: 6
                                value: 1
                              - parameter: 3
                                value: 2
Thanks!
Because it still has the same source of the error.
You cannot use templates in a Device Trigger, Device Condition, or Device Action.
  • Your first blueprint contains a Device Action with templates.
  • Your second blueprint contains Device Triggers with templates.
You’ll need to redesign your blueprints to avoid using templated Device Actions and Device Triggers.
