Meteo-Swiss integration, fixed and properly working — beware: not the one available by default in HACS!
Hi Rudd-O,
First of all. Great job! and big thank you for your work and effort. Really much appreciate it.
Unfortunately my weather info gets only very limited data ( no temperature, pressure,…)
I’ve checked other “real station” and all is working perfectly.
The one station I’m using is Uetliberg:
All sensors for that weather station show value: Unknown
Any idea what can be wrong with it?
Hi guys,
I’m trying to install Meteo Swiss Integration but if I click on ADD integration and I search Meteo, I see only other weather service, even I followed all the details to install it from HACS.
Do you know what I can do? I configured the LOG tracking but I don’t know how to retrieve these information.
Sory but I’m a newbie
Please let me know
Many thanks
Hello. I am new with HA and I have successfully installed HACS and able to download Meteo Swiss. I restarted the HA and now, when I want to add the integration, I got this error :
Do you have and idea ?
Facing the same issue for weeks now…
Hello.
Could you fix this issue? Spent days trying to find a fix but I was unsuccessful
After you add the custom repository, don’t forget that the integration you must add to HACS is named Meteo Swiss (forked), not just Meteo Swiss. Meteo Swiss has been broken for many years now.
I know this is yet another integration, but you can try my GitHub - izacus/hass-swissweather: HomeAssistant module for MeteoSwiss integration which should work still and supports new forecast API.
First, thanks for the continuous work to make the integration working (spring time makes it even more useful) ! Since a few days the forecast data must be get through the service weather.get_forecasts which for the Meteo-Swiss integration is not compatible.
Are there intention for an update ?
just wanted to say THANK YOU! the integration is amazing and works like a charm.
Thanks izacus for the version including the new forecast API, however when creating a sensor template with the service: weather.get_forecasts, the syntax of the answer is not correct and the template cannot extract single weather values.
Someone managed it ?
Edit: after full reinstall of the forked integration, forecast works fine !
Thank you very much for this integration, it really helps a lot. What I would also be interested in is access to the hazard warnings, such as hail, to automatically raise our fabric shutters. Any chance that that could be implemented?
Thanks @izacus and @Rudd-O for maintaining these integrations!
@izacus since you posted a new integration, how exactly does it differ from the fork by @Rudd-O? Do you use a different API? Or a different way of integrating the data into HA? Do you support more or different APIs?
Hello
I get this error message when adding integration. However, the coordinates are correct…???
Fehlermeldung Meteo Swiss
Hi
I have the same issue like Valader.
Hello!
Same issue here.
Tried to un-/reinstall. Tried with different coordinates as well.
Unfortunately without success.
Core 2024.7.3
Supervisor 2024.06.2
OS 12.4
Hello All,
First of all, thank you for renewing the integration.
Im facing the same issue with the Setup. Was this issue resolved or has any on managed to fix it?
2024-08-07 11_09_49-Andrin-011 - TeamViewer
  • Core: 2024.7.3
  • Supervisor: 2024.08.0
  • Operating System: 12.4
Thank you very much for your help
Andrin
Same here :wave:t2:
Deleted the old version Installed the Fork version.
At the end of the installation i see this error
![image|431x222](upload://jHOjBtLne8cqvLT9hbUY4ao
Unfortunately I don’t see nothing under Settings> Integrations
thanks
same here, if I remember correctly, there was a way to fix it… just searching through the issues
might this help:
https://github.com/Rudd-O/homeassistant-meteoswiss/issues/44#issuecomment-2192452419
