I have not worked on this project for 2 years, and it will most likely not work with the current integration of Home Assistant. I will soon archieve it. (I don’t use it myself anymore)
It is working fine for me, has done through multiple upgrades. Haven’t tried adding it back in again to see if that is the issue though.
@scriven33 I recently started with Home Assistant so not very familiar yet but learning fast. I have a Davis Vantage Pro 2 with a meteobridge SD Nano.
I would like to use this integration but as @briis already announced end of LY it is now archieved. I cannot find it on HACS anymore.
I want to install it manually but does it still work ?
Any advice is very welcome!
Thanks in advance
My response from December still applies - it still works.
It was never in HACS by default - you had to add it as a custom repository.
Therefore you could just fork it and then add it to HACS yourself.
How long it will work is another matter.
The other option is to go after the raw JSON, via REST.
Someone else went that method a while ago.
Thanks you for your very quick response. Can you inform me how this works?
Update: I already found how to do it: very easy and I have it running already. Thank you!
I’m a bit late passing on my thanks… I’ve used this for sometime and its great. Many thanks for the work that you did @briis
