Methods of integrating Somfy RTS blinds into HA?
Hi there,
I used this method today and pretty happy with the results, thanks for the tip!
The hardware build was very easy, but the software seems a bit trickier, HA using ZHA detects the relay board as Tuya T0004 and it works, but the switches latch. Are you perhaps aware how I might set/emulate them as momentary?
I came at this from a different angle using a cheap RFM69HCW module and a Pi Pico W, which can be put together easily for next to nothing.
The Pico runs a web interface for configuration, and uses MQTT to integrate with HA.
Itā€™s fully open source here: [GitHub - MarkGodwin/somfy_pico]
Itā€™s Somfy RTS only, but offers complete local control and supports >100 covers. YMMV!
Sound amazing - how did you get those remote addresses?
This seems like a no-brainer to meā€¦ local control with support from a third-partyā€¦ which integrates easily with HA (and Hubitat which I also care about).
Just because I donā€™t see it recommended here:
Somfy also sells a ~realtively~ cheap Somfy 1870755 Connectivity Kit that apparently works with the Overkiz integration. Itā€™s 60ā‚¬ and should be a complete solution, for those who donā€™t want to tinker.
The Problem of the Connectivity Kit: It only transmitt and do not receive, so in HA you do not know what the actual state of the blind is.
And it doesnā€™t calculate the actual position over time, so an percentage use is not possible and so the integration for example in HomeKit is not possibleā€¦
