Note the lack of quotes round the mac addr. You don’t need the bluetooth device tracker for MiFlora. Also with median: 3 you will have to wait about 1/2 hr before any updates.
Okey, deleted the quotes before and after the Mac addr. Also deleted bluetooth device tracker since I don’t use it. Did know about the 1/2 update time but will try with median 1 now.
Still unknown values… don’t understand what I’m doing wrong.
How did you guys get the Mac addr?
Since I’m using hass.io I had to change sd card with preinstalled os to be able to search for the Mac addresses. Then I wrote them down and changed back to my sd card with hass.io.
Is that the problem?
No you don’t need a component it’s inherent in the spec. when you created the sensors You haven’t said what PI you are using the older PI’s don’t have a BT chip so you need a dongle the newer PI’s 3 and 3B+ have an onboard BT chip, so you may need to buy a BT dongle if using PI 1’s and 2’s.
Having lots of trouble for months now. Worked fine for about a year with 6 sensors. Then someday my sdcard crashed, I reinstalled everything, added 2 sensors and since then it never worked reliable anymore.
This is what my logfile says:
2018-09-17 20:15:52 WARNING (MainThread) [homeassistant.helpers.entity] Update of sensor.mi_flora_5_moisture is taking over 10 seconds
2018-09-17 20:16:13 INFO (Thread-14) [homeassistant.components.sensor.miflora] Polling error Exit read_ble, no data (<Thread(Thread-14, started daemon 1842029680)>)
2018-09-17 20:16:13 DEBUG (Thread-16) [homeassistant.components.sensor.miflora] Polling data for Mi Flora 1 Moisture
2018-09-17 20:16:13 DEBUG (Thread-16) [miflora.miflora_poller] Using cache (0:18:36.750007 < 0:20:00)
2018-09-17 20:16:13 INFO (Thread-16) [homeassistant.components.sensor.miflora] Polling error Could not read data from Mi Flora sensor C4:7C:8D:64:46:77
2018-09-17 20:16:13 DEBUG (Thread-22) [homeassistant.components.sensor.miflora] Polling data for Mi Flora 2 Moisture
2018-09-17 20:16:13 DEBUG (Thread-22) [miflora.miflora_poller] Using cache (0:16:01.673919 < 0:20:00)
2018-09-17 20:16:13 INFO (Thread-22) [homeassistant.components.sensor.miflora] Polling error Could not read data from Mi Flora sensor C4:7C:8D:64:42:27
2018-09-17 20:16:13 DEBUG (Thread-22) [homeassistant.components.sensor.miflora] Polling data for Mi Flora 7 Moisture
2018-09-17 20:16:13 DEBUG (Thread-22) [miflora.miflora_poller] Using cache (0:17:03.382222 < 0:20:00)
2018-09-17 20:16:13 INFO (Thread-22) [homeassistant.components.sensor.miflora] Polling error Could not read data from Mi Flora sensor C4:7C:8D:65:BA:DB
2018-09-17 20:16:13 DEBUG (Thread-7) [homeassistant.components.sensor.miflora] Polling data for Mi Flora 3 Moisture
2018-09-17 20:16:13 DEBUG (Thread-7) [miflora.miflora_poller] Using cache (0:15:31.073260 < 0:20:00)
2018-09-17 20:16:13 INFO (Thread-7) [homeassistant.components.sensor.miflora] Polling error Could not read data from Mi Flora sensor C4:7C:8D:64:45:C7
2018-09-17 20:16:13 DEBUG (Thread-3) [homeassistant.components.sensor.miflora] Polling data for Mi Flora 6 Moisture
2018-09-17 20:16:13 DEBUG (Thread-3) [miflora.miflora_poller] Using cache (0:19:38.729210 < 0:20:00)
2018-09-17 20:16:13 INFO (Thread-3) [homeassistant.components.sensor.miflora] Polling error Could not read data from Mi Flora sensor C4:7C:8D:65:BA:EB
2018-09-17 20:16:13 DEBUG (Thread-18) [homeassistant.components.sensor.miflora] Polling data for Mi Flora 8 Moisture
2018-09-17 20:16:13 DEBUG (Thread-18) [miflora.miflora_poller] Using cache (0:18:06.497845 < 0:20:00)
2018-09-17 20:16:13 INFO (Thread-18) [homeassistant.components.sensor.miflora] Polling error Could not read data from Mi Flora sensor CC4:7C:8D:66:1E:6C
2018-09-17 20:16:13 DEBUG (Thread-19) [homeassistant.components.sensor.miflora] Polling data for Mi Flora 1 Moisture
2018-09-17 20:16:13 DEBUG (Thread-19) [miflora.miflora_poller] Using cache (0:18:37.064728 < 0:20:00)
2018-09-17 20:16:13 INFO (Thread-19) [homeassistant.components.sensor.miflora] Polling error Could not read data from Mi Flora sensor C4:7C:8D:64:46:77
2018-09-17 20:16:13 DEBUG (Thread-6) [homeassistant.components.sensor.miflora] Polling data for Mi Flora 3 Moisture
2018-09-17 20:16:13 DEBUG (Thread-6) [miflora.miflora_poller] Using cache (0:15:31.591010 < 0:20:00)
2018-09-17 20:16:14 INFO (Thread-6) [homeassistant.components.sensor.miflora] Polling error Could not read data from Mi Flora sensor C4:7C:8D:64:45:C7
2018-09-17 20:16:14 DEBUG (Thread-21) [homeassistant.components.sensor.miflora] Polling data for Mi Flora 8 Moisture
2018-09-17 20:16:14 DEBUG (Thread-21) [miflora.miflora_poller] Using cache (0:18:07.015284 < 0:20:00)
I tried deleting 2 sensors as well, timeout set to 30 seconds.
No I don’t. I just updated to 0.78.0 and now get the following errors:
2018-09-17 21:34:27 ERROR (MainThread) [homeassistant.components.sensor.miflora] Unable to connect to C4:7C:8D:64:46:77
2018-09-17 21:34:28 ERROR (MainThread) [homeassistant.components.sensor.miflora] Unable to connect to C4:7C:8D:64:42:27
2018-09-17 21:34:28 ERROR (MainThread) [homeassistant.components.sensor.miflora] Unable to connect to C4:7C:8D:64:45:C7
2018-09-17 21:34:28 ERROR (MainThread) [homeassistant.components.sensor.miflora] Unable to connect to C4:7C:8D:64:45:D3
2018-09-17 21:34:28 ERROR (MainThread) [homeassistant.components.sensor.miflora] Unable to connect to C4:7C:8D:64:45:9C
2018-09-17 21:34:28 ERROR (MainThread) [homeassistant.components.sensor.miflora] Unable to connect to C4:7C:8D:65:BA:EB
2018-09-17 21:34:28 ERROR (MainThread) [homeassistant.components.sensor.miflora] Unable to connect to C4:7C:8D:65:BA:DB
2018-09-17 21:34:28 ERROR (MainThread) [homeassistant.components.sensor.miflora] Unable to connect to C4:7C:8D:66:1E:6C
P.S. all sensors are working fine in the MiFlora app.
