Midea A/C and ESPHome component - list of all known working models and manufacturers
Hey, i also would like to get some more photos or atleast instructions as how to open up the unit. I tried removing all the screws i could see but was still not able to open it up.
@redpersian Did you ever get a reply or figure it out on your own?
Edit: i found a diffrent post from him in another thread with pictures and a guy describing how to open the Midea Real Cool 35.
Take off all visible screws of the AC unit and then pull on the back. its held in by clips and they are strong, takes a bit of force to remove. Then the Rest is pretty easy. The USB is near the top of the front, roughly where the midea logo is. i just tilted the front a bit and switched the usb sticks.
Manufacturer: Midea Comfee
Model: Eco Friendly Pro
Year: 2019 (PCB date 2018)
Market: EU
A monoblock mobile unit that comes without WiFi.
It doesn’t have the pseudo USB, but a 4-pin JST XH 2.54 connector on the display PCB:
It is not necessary to get the display PCB out. The Wifi connector is accessible after removing the rear housing of the unit. It might be hidden under a grey foam sticker.
Manufacturer: Mirage
Model: InverterX EMC181J
Year: 2024
Market: US/MX
Manufacturer: Kaisai
Model: Eco
Year: probably 2020
Market: EU
Outdoor unit: KEX-12KTCO
Indoor unit: KEX-12KTCI
Everything works except indoor humidity and power usage.
Brand: Samsung
Model: AR09TXHQASIN
Year: 2022
Market: RU
using esp8266 esp12f (“hw580b” board)
reports outdoor temp
Brand: hOmeLabs
Model: ‎HME030356N
Year: 2022
Market: US
using esp8266 esp12f (“smartlight” board)
  • Unit did not have USB port, only JST Headers. used dupont cables soldered to smartlight board
Brand: Alliance
Model: FOUSI12
Year: 2018
Market: South Africa
Using SLWF-01pro by SMLIGHT, purchased from AliExpress
Unit does not have “USB” port, but a JST-XH 4 pin header
Successfully controlling following AC:
Brand: PITSOS
Model: NEFELI PSO09VW30
Year: 2022
Market: Greece / Cyprus
Used EPS01-1S as shown in previous posts.
Hi, Sorry I haven’t logged on to forums in a while. I used an esp8266 12f and a regulator to utilize the space they left for their module. as far the code is concerned, here is what I used for the pins.
logger:
  baud_rate: 0
uart:
  tx_pin: 1
  rx_pin: 3
  baud_rate: 9600
## IR part:
    name: AC Display Toggle IR
    on_press:
      - remote_transmitter.transmit_toshiba_ac:
          rc_code_1: 0xB54AF50AA55A
it works well, just let me know if you need full yaml config.
台灣三洋速捷淨
Brand: SANLUX
Model: SAE-V41HJ
Year: 2024
Market: TW
Note: No power and humidity information
Works even without 5v-3.3v level shifter (ESP32 / ESP32c3 tested)
This PCB is also used on Ariston Prios 80 Trial XD0. I will come back with an update.
Can I ask how you put a switch to enable and disable follow me?
I tried with the display setting but every time it always goes back to “OFF” and the log shows [W][component:237]: Component web_server took a long time for an operation (189 ms)"
and “[W][component:238]: Components should block for at most 30 ms” every time I press it.
Another question:
How did you implement “Prevent direct blowing” ?
The esphome wiki does not have the IR code for this feature, and I have no idea what it could be.
  1. I use template switch and remember and restore switch state
  2. I recorded some functions on the infrared remote control. The functions provided by each air conditioner will be different.
Below is a snippet of my air conditioner settings for your reference
substitutions:
  device_name: air-conditioner
  friendly_name: "air conditioner"
  model_name: "SAE-V41HJ"
  min_outdoor_temperature: "-20"
  max_outdoor_temperature: "80"
  follow_me_temperature_sensor: "sensor.temperature_humidity_sensor_67c2_temperature"
  min_photoresistor_threshold: "0"
  max_photoresistor_threshold: "1000000"
  default_display_photoresistor_threshold: "14000"
packages:
  base: !include base.yaml
  board: !include board/xiao_esp32c3.yaml
esphome:
  comment: SANLUX $model_name
remote_transmitter:
  pin:
    number: GPIO7
  carrier_duty_percent: 50%
climate:
  - platform: midea
    period: 1s
    timeout: 2s
    num_attempts: 3
    autoconf: true
    beeper: true
    visual:
      min_temperature: 16 °C
      max_temperature: 30 °C
      temperature_step: 1 °C
    supported_modes:
      - FAN_ONLY
      - HEAT_COOL
      - COOL
      - HEAT
      - DRY
    custom_fan_modes:
      - SILENT
      - TURBO
    supported_presets:
      - ECO
      - BOOST
      - SLEEP
    supported_swing_modes:
      - VERTICAL
      - HORIZONTAL
      - BOTH
      name: "Outdoor Temperature"
      filters:
        - lambda: |-
            if (!isnan(x) && x >= $min_outdoor_temperature && x <= $max_outdoor_temperature) {
              return x;
            return NAN;
switch:
    icon: mdi:volume-source
    optimistic: true
    restore_mode: RESTORE_DEFAULT_ON
    turn_on_action:
      midea_ac.beeper_on:
    turn_off_action:
      midea_ac.beeper_off:
    turn_on_action:
      if:
        condition:
          and:
            - lambda: return id(midea_climate).mode != CLIMATE_MODE_OFF;
            - switch.is_off: display_switch
        then:
          midea_ac.display_toggle:
    turn_off_action:
      if:
        condition:
          and:
            - switch.is_on: display_switch
        then:
    optimistic: true
    restore_mode: RESTORE_DEFAULT_OFF
    # Supports cool, fan only, dry modes
    name: "Prevent Direct Blowing"
    optimistic: true
    assumed_state: true
    turn_on_action:
      if:
        condition:
        then:
          - remote_transmitter.transmit_pronto:
              data: "0000 0073 0000 0064 009e 009f 0012 003b 0012 0013 0012 003b 0012 003a 0013 003a 0013 0013 0012 0013 0012 003b 0012 0013 0013 003a 0012 0013 0013 0013 0012 0013 0012 003b 0012 003a 0013 0013 0012 003b 0012 003a 0013 003a 0012 003b 0012 0013 0013 003a 0012 0013 0013 003a 0012 0013 0013 0013 0012 0013 0013 0012 0013 003a 0013 0013 0012 003a 0013 0013 0012 0013 0013 003a 0012 0013 0013 003a 0012 003b 0012 0013 0012 003b 0012 003a 0013 003a 0013 0013 0012 003a 0013 0013 0012 0013 0013 003a 0012 0013 0013 0013 0012 00bb 009f 009f 0012 003a 0013 0013 0012 003a 0013 003a 0013 003a 0012 0013 0013 0013 0012 003a 0013 0013 0012 003a 0013 0013 0012 0013 0013 0013 0012 003a 0013 003a 0013 0012 0013 003a 0013 003a 0012 003b 0012 003a 0013 0013 0012 003a 0013 0013 0012 003b 0012 0013 0012 0013 0013 0013 0012 0013 0013 003a 0012 0013 0013 003a 0012 0013 0013 0013 0012 003a 0013 0013 0012 003b 0012 003a 0013 0013 0012 003a 0013 003a 0013 003a 0012 0013 0013 003a 0012 0013 0013 0013 0012 003a 0013 0013 0012 0013 0013 0e4a"
    turn_off_action:
      if:
        condition:
        then:
              data: "0000 0073 0000 0064 00a1 009b 0015 0037 0014 0011 0015 0037 0015 0037 0014 0039 0014 0011 0014 0011 0015 0037 0015 0011 0014 0037 0015 0011 0014 0011 0014 0011 0015 0037 0014 0039 0014 0011 0015 0037 0014 0039 0014 0037 0015 0037 0014 0012 0013 0039 0014 0012 0014 0037 0014 0012 0013 0012 0014 0012 0014 0011 0014 0039 0013 0012 0014 0039 0013 0012 0014 0011 0014 0039 0015 0011 0014 0037 0015 0037 0014 0039 0013 0012 0014 0012 0014 0037 0015 0011 0013 0039 0015 0011 0013 0012 0015 0011 0014 0037 0015 0037 0013 00bb 00a0 009c 0014 0039 0014 0011 0014 0039 0014 0037 0015 0037 0014 0012 0014 0011 0014 0039 0014 0011 0014 0039 0014 0011 0014 0012 0013 0012 0013 003a 0013 0039 0014 0012 0013 003a 0013 0039 0014 0039 0013 003a 0014 0011 0014 0039 0013 0012 0014 0039 0013 0012 0014 0012 0013 0012 0014 0011 0014 0039 0014 0012 0013 0039 0014 0012 0013 0012 0013 003a 0013 0012 0014 0039 0013 003a 0013 0039 0014 0012 0013 0012 0014 0039 0013 0012 0014 0039 0013 0012 0014 0012 0013 0012 0014 0039 0013 003a 0013 0e4a"
    name: "Target Temperature"
    device_class: "temperature"
    state_class: "measurement"
    unit_of_measurement: °C
    icon: mdi:thermometer
    lambda: |-
      if (id(midea_climate).mode != CLIMATE_MODE_OFF) {
        return id(midea_climate).target_temperature;
      return NAN;
    name: "Indoor Temperature"
    lambda: return id(midea_climate).current_temperature;
  - platform: resistance
    sensor: source_sensor
    configuration: UPSTREAM
    resistor: 10kOhm
    name: Display Photoresistor
    disabled_by_default: true
    entity_category: diagnostic
    filters:
      - clamp:
          min_value: $min_photoresistor_threshold
          max_value: $max_photoresistor_threshold
    on_value:
      - lambda: |-
          if(id(midea_climate).mode == CLIMATE_MODE_OFF){
            id(display_switch).publish_state(false);
          }else if(id(display_photoresistor_threshold).has_state() && x < id(display_photoresistor_threshold).state){
            id(display_switch).publish_state(true);
          }else{
  - platform: adc
    pin: GPIO2
    attenuation: auto
    update_interval: 1s
  - platform: homeassistant
    entity_id: $follow_me_temperature_sensor
    filters:
      - throttle: 10s
      - heartbeat: 2min
      - debounce: 1s
    on_value:
      if:
        condition:
          and:
            - switch.is_on: follow_me
        then:
          midea_ac.follow_me:
            temperature: !lambda "return x;"
            beeper: false
number:
    name: "Display Photoresistor Threshold"
    icon: "mdi:alarm-light-outline"
    unit_of_measurement: "ohm"
    optimistic: true
    initial_value: $default_display_photoresistor_threshold
    restore_value: true
    step: 1
    entity_category: config
button:
    icon: mdi:tailwind
    on_press:
      if:
        condition:
        then:
          midea_ac.swing_step:
    on_press:
          data: "0000 0073 0000 0064 00a0 009c 0015 0037 0014 0011 0014 0039 0014 0039 0014 0037 0014 0012 0014 0011 0014 0039 0014 0011 0014 0039 0014 0011 0014 0013 0013 0011 0014 0039 0014 0039 0014 0011 0014 0039 0014 0037 0014 0039 0014 0039 0014 0011 0014 0039 0014 0012 0013 0039 0014 0012 0014 0011 0014 0011 0014 0012 0014 0037 0014 0012 0014 0039 0013 0012 0014 0011 0014 0039 0014 0011 0014 0012 0014 0037 0014 0039 0014 0039 0014 0039 0014 0039 0013 0012 0014 0039 0014 0037 0014 0012 0014 0011 0014 0012 0013 0012 0014 00ba 00a0 009c 0015 0037 0013 0012 0014 0039 0014 0037 0014 0039 0014 0012 0013 0012 0014 0039 0014 0011 0014 0039 0014 0011 0014 0012 0013 0013 0013 0039 0014 0037 0014 0012 0014 0039 0013 0039 0014 0039 0014 0039 0014 0011 0014 0039 0014 0011 0014 0039 0014 0011 0014 0012 0014 0011 0014 0012 0013 0039 0014 0012 0014 0037 0014 0012 0014 0012 0013 0039 0014 0011 0014 0012 0013 0039 0014 0039 0014 0039 0014 0039 0013 0039 0014 0012 0014 0037 0014 0039 0014 0012 0013 0012 0014 0011 0014 0012 0014 0e4a"
    on_press:
      lambda: |-
        id(midea_climate).dump_config();
Thank you very much
Everything works except the display, the switch when I press it then returns to the OFF position by itself, I can’t understand why, at the moment I have no way of testing if the display actually turns off and on because the IR LED has yet to arrive at my home, but it’s a matter of a week at most.
    turn_on_action:
      if:
        condition:
          and:
        then:
    turn_off_action:
      if:
        condition:
          and:
        then:
I was thinking of adding
optimistic: true
Could this work or is it irrelevant?
In the log I find when I press the display switch I always find this:
[D][switch:012]: 'Accendi/Spegni Display' Turning ON.
OFF is never displayed in the Log
The uart communication protocol cannot know whether the display is on, nor can it only control on or off. It can only control display toggle.
I use template switches because there are additional sensor(photoresistor) that automatically recognize the display state. If you don’t need to automate turning the display on or off, you can simply use the template button to control the display.
button:
   icon: mdi:theme-light-dark
   on_press:
Display switch and photoresistor sensor combination
Drilled a hole above the WIFI sign, installed a photoresistor facing the hole, and covered it with tape to avoid interference from other light sources.
The configuration part is in the previous reply.
I added optimistic: true to the display switch configuration and it works as it should.
I mounted the IR LED and everything works.
Senville SENL/18CD/IY
This unit is compatible but did require modification of the UART connector. Initially I was able to plug it in with a little more than normal force. The SLWF-01 did power up and connect to my Wifi and Home Assistant, but did not communicate with the mini-split. It reported the unit off and the sensor status were all unknown. After trying to add clearance slots to the SLWF-01 plug, I changed my mind and found it much easier to remove the circuit board from the mini-split and used an X-Acto knife to remove the tabs from the jack instead. Once removed it plugged in easily and came right up and worked as expected.
I would also need to know whether the Midea Breezeless+ MSFAAU-12HRFN8/MSFAAU-09HRFN8 work with ESPHome (specifically with the SMARTLIGHT SLWF-01pro (v.2.1) dongle), or at least if it’s reasonable to assume that they do. I see a Breezeless+ in the list of supported devices but it has a different model ID. Thanks
Brand: Carrier
Model: 42QHG009D8S
Year: 2023
Market: Netherlands.
Installed the dongle in the 3 unit airco. Works without issues, only can display the outside temperature and control the temperature setting of the airco, current room temperature, fan speed, louvre movement and mode (cooling heating…)
The power ussage and indoor humidity don’t function
Hello @DavidR0
Works well also on my Climate 6000i, but not every features on the 3000i (fan speed and oscillation don’t seems to work .
Can you tell me if with your 3000i, with features of your remote are working (same model W26E) ?
Thank you for your feedback.
