Hello, so I tried out quite a bit of what I’ve read here.
First that works with the integration of several devices.
Now to the problems it depends on which card is used. If you use the recommended card, you can’t change Fan Made at all.
But if you use a different card you can change the Fan Mod and the mode, but with me it happens on all devices at the same time. Sometimes all devices turn on.
