Hi @barban,
Just dl and i try to install now ;-))
I wonder if the update it include a solution for house with multiple deshumidifier ?
I am in that case with @HVPereira (post 74 & 75 Dec20)
Hi @barban,
Actually, as per my understanding someone implemented a better solution for the multiple devices.
Credits to gianluca.
in init .py, I pushed into hass.data new client for each appliace:
if not deviceId:
if appliances is not None:
for a in appliances:
if a["type"] == "0xA1":
deviceId = str(a["id"])
targetDevice = a
client_for_device = MideaClient(username, password, sha256password, cacheTimeInSeconds = 0)
res = await hass.async_add_executor_job(client_for_device.login)
if res != -1:
sessionId = client_for_device.current["sessionId"]
_LOGGER.info("midea-dehumi: login success, sessionId=%s", sessionId)
hass.data[MIDEA_API_CLIENT + "_" + a["id"]] = client_for_device
_LOGGER.info("midea-dehumidifier: loading humidifier entity sub-component...")
load_platform(hass, 'humidifier', DOMAIN, {MIDEA_TARGET_DEVICE: targetDevice}, config)
_LOGGER.info("midea-dehumidifier: loading sensor entity sub-component...")
load_platform(hass, 'sensor', DOMAIN, {MIDEA_TARGET_DEVICE: targetDevice}, config)
_LOGGER.info("midea_dehumidifier: platform successfuly initialized.")
else:
if a["type"] == "0xA1" and deviceId == str(a["id"]):
targetDevice = a
the key is: hass.data[MIDEA_API_CLIENT + "_" + a["id"]] = client_for_device
In humidifier.py, I changed the way to get client:
self._client = hass.data[MIDEA_API_CLIENT + "_" + targetDevice['id']]
Hope it helps
I belive this is a much better solution I haven’t tested it myself but will try it this weekend.
Best Regards,
HP
Hello again,
For those of you who are trying to have several devices with different humidity sensors. Please find my init.py and humidifier,py in attachment.
All the credits should go to gianluca and barban of course as they were the ones who managed to get here
I’m very happy to share these files, Hope you find it as useful as I did.
init.py
Custom integation based on humidifer and sensor platforms for EVA II PRO WiFi Smart Dehumidifier appliance by Midea/Inventor.
For more details please refer to the documentation at
https://github.com/barban-dev/midea_inventor_dehumidifier
VERSION = '1.0.0'
DOMAIN = "midea_dehumidifier"
MIDEA_API_CLIENT = "midea_api_client"
MIDEA_TARGET_DEVICE = "midea_target_device"
import logging
import voluptuous as vol
import homeassistant.helpers.config_validation as cv
from homeassistant.helpers.discovery import load_platform
from homeassistant.const import CONF_USERNAME, CONF_PASSWORD
import asyncio
from homeassistant.config_entries import ConfigEntry
_LOGGER = logging.getLogger(__name__)
CONF_SHA256_PASSWORD = 'sha256password'
CONF_DEVICEID = 'deviceId'
CONFIG_SCHEMA = vol.Schema({
DOMAIN: vol.Schema({
vol.Required(CONF_USERNAME): cv.string,
vol.Optional(CONF_PASSWORD): cv.string,
vol.Optional(CONF_SHA256_PASSWORD): cv.string,
vol.Optional(CONF_DEVICEID): cv.string
}, extra=vol.ALLOW_EXTRA)
async def async_setup(hass, config):
"""Set up client for Midea API based on configuration entries."""
_LOGGER.info("midea_dehumidifier: initializing platform...")
_LOGGER.debug("midea_dehumidifier: starting async_setup")
if DOMAIN not in config:
_LOGGER.error("midea_dehumi: cannot find midea_dehumi platform on configuration.yaml")
return False
from midea_inventor_lib import MideaClient
username = config[DOMAIN].get(CONF_USERNAME)
password = config[DOMAIN].get(CONF_PASSWORD)
sha256password = config[DOMAIN].get(CONF_SHA256_PASSWORD)
deviceId = config[DOMAIN].get(CONF_DEVICEID)
#_LOGGER.debug("midea_dehumi: CONFIG PARAMS: username=%s, password=%s, sha256password=%s, deviceId=%s", username, password, sha256password, deviceId)
if not password and not sha256password:
_LOGGER.error("midea_dehumi: either plain-text password or password's sha256 hash should be specified in config entries.")
return False
#Create client
client = MideaClient(username, password, sha256password, cacheTimeInSeconds = 0)
#Log-in to the Midea cloud Web Service and get the list of configured Midea/Inventor appliances for the user.
_LOGGER.info("midea_dehumi: logging into Midea API Web Service...")
#res = client.login()
res = await hass.async_add_executor_job(client.login)
if res == -1:
_LOGGER.error("midea-dehumi: login error")
return False
else:
sessionId = client.current["sessionId"]
appliances = {}
#appliances = client.listAppliances()
appliances = await hass.async_add_executor_job(client.listAppliances)
appliancesStr = ""
appliancesStr = "[id="+a["id"]+" type="+a["type"]+" name="+a["name"]+"]"
if a["onlineStatus"] == "1":
appliancesStr += " is online,"
else:
appliancesStr += " is offline,"
if a["activeStatus"] == "1":
appliancesStr += " is active.\n"
else:
appliancesStr += " is not active.\n"
_LOGGER.info("midea-dehumi: "+appliancesStr)
#The first appliance having type="0xA1" is returned for default (TODO: otherwise, 'deviceId' configuration option can be used)
hass.data[MIDEA_API_CLIENT] = client
targetDevice = None
if not deviceId:
targetDevice = a
if res != -1:
else:
targetDevice = a
if targetDevice:
# _LOGGER.info("midea-dehumidifier: device type 0xA1 found.")
# hass.data[MIDEA_API_CLIENT] = client
# _LOGGER.info("midea-dehumidifier: loading humidifier entity sub-component...")
# load_platform(hass, 'humidifier', DOMAIN, {MIDEA_TARGET_DEVICE: targetDevice}, config)
# _LOGGER.info("midea-dehumidifier: loading sensor entity sub-component...")
# load_platform(hass, 'sensor', DOMAIN, {MIDEA_TARGET_DEVICE: targetDevice}, config)
# _LOGGER.info("midea_dehumidifier: platform successfuly initialized.")
return True
else:
_LOGGER.error("midea-dehumidifier: device type 0xA1 not found.")
return False
humidifier.py
VERSION = '1.0.1'
import logging
from typing import List, Optional
from custom_components.midea_dehumidifier import DOMAIN, MIDEA_API_CLIENT, MIDEA_TARGET_DEVICE
from homeassistant.components.humidifier import HumidifierEntity
from homeassistant.components.humidifier.const import (
ATTR_AVAILABLE_MODES,
ATTR_HUMIDITY,
ATTR_MAX_HUMIDITY,
ATTR_MIN_HUMIDITY,
ATTR_MODE,
DEFAULT_MAX_HUMIDITY,
DEFAULT_MIN_HUMIDITY,
DEVICE_CLASS_DEHUMIDIFIER,
SERVICE_SET_HUMIDITY,
SERVICE_SET_MODE,
SUPPORT_MODES
#import asyncio
#from homeassistant.helpers import config_validation as cv, entity_platform, service
from homeassistant.helpers import service
from homeassistant.helpers.dispatcher import async_dispatcher_connect, async_dispatcher_send
from homeassistant.core import callback
ATTR_ENTITY_ID = "entity_id"
SERVICE_SET_FAN_SPEED = "set_fan_speed"
ATTR_FAN_SPEED = "fan_speed"
SERVICE_SET_FAN_SPEED_SCHEMA = vol.Schema({
vol.Required(ATTR_ENTITY_ID): cv.entity_id,
vol.Required(ATTR_FAN_SPEED): cv.string,
SERVICE_SET_ION_STATE = "set_ion_state"
ATTR_ION_STATE = "ion_state"
SERVICE_SET_ION_STATE_SCHEMA = vol.Schema({
vol.Required(ATTR_ION_STATE): cv.boolean,
SERVICE_SET_MODE = "set_mode"
ATTR_MODE = "mode"
SERVICE_SET_MODE_SCHEMA = vol.Schema({
vol.Required(ATTR_MODE): cv.string,
#SUPPORT_FLAGS = 0
SUPPORT_FLAGS = SUPPORT_MODES
#TODO: in midea_dehumi python lib the range 30-70 is hard coded (fix it)
MIN_HUMITIDY = 35
MAX_HUMITIDY = 70
DEHUMI_MODES_DICT = { 'TARGET_HUMIDITY' : 1, 'CONTINUOS' : 2, 'SMART' : 3, 'DRYER' : 4}
DEHUMI_MODES_LIST = [ 'Target_humidity', 'Continuos', 'Smart', 'Dryer']
DEHUMI_FAN_SPEED_DICT = { 'SILENT' : 40, 'MEDIUM' : 60, 'HIGH' : 80 }
DEHUMI_FAN_SPEED_LIST = [ 'Silent', 'Medium', 'High' ]
#States Attributes
ATTR_ION_SET_SWITCH = "ion"
#ATTR_MODE = "mode"
ATTR_FAN_SPEED_MODE = "fan_speed_mode"
#ATTR_FAN_SPEED = "fan_speed"
ATTR_CURRRENT_HUMIDITY = "current_humidity"
ATTR_TANK_SHOW = 'tank_show'
PROP_TO_ATTR = {
"ionSetSwitch": ATTR_ION_SET_SWITCH,
"mode": ATTR_MODE,
"windSpeedMode": ATTR_FAN_SPEED_MODE,
"windSpeed": ATTR_FAN_SPEED,
"current_humidity": ATTR_CURRRENT_HUMIDITY,
"tank_show": ATTR_TANK_SHOW,
async def async_setup_platform(hass, config, async_add_entities, discovery_info=None):
"""Set up Midea/Inventor dehumidifier platform based on config_entry."""
_LOGGER.info("midea_dehumidifier: initializing humidifier platform")
_LOGGER.debug("midea_dehumidifier: starting async_setup_platform")
_LOGGER.debug("midea_dehumidifier: MIDEA_API_CLIENT="+MIDEA_API_CLIENT)
_LOGGER.debug("midea_dehumidifier: MIDEA_TARGET_DEVICE="+MIDEA_TARGET_DEVICE)
#ref: https://developers.home-assistant.io/docs/en/creating_component_generic_discovery.html
client = hass.data[MIDEA_API_CLIENT]
targetDevice = discovery_info[MIDEA_TARGET_DEVICE]
_LOGGER.debug("midea_dehumidifier: targetDevice = %s", targetDevice)
if targetDevice is not None:
#Add entity
async_add_entities([MideaDehumidifierDevice(hass, client, targetDevice)])
_LOGGER.info("midea_dehumidifier: humidifier entity initialized.")
else:
_LOGGER.error("midea_dehumidifier: error initializing humidifier entity.")
#Register services
#https://community.home-assistant.io/t/registering-a-service/40327/11
async def async_service_set_fan_speed(call):
entity_id = call.data[ATTR_ENTITY_ID]
speed_mode = call.data[ATTR_FAN_SPEED]
async_dispatcher_send(hass, SERVICE_SET_FAN_SPEED.format(entity_id), speed_mode)
async def async_service_set_ion_state(call):
ion_state = call.data[ATTR_ION_STATE]
async_dispatcher_send(hass, SERVICE_SET_ION_STATE.format(entity_id), ion_state)
async def async_service_set_mode(call):
mode_name = call.data[ATTR_MODE]
async_dispatcher_send(hass, SERVICE_SET_MODE.format(entity_id), mode_name)
hass.services.async_register(DOMAIN, SERVICE_SET_FAN_SPEED, async_service_set_fan_speed, SERVICE_SET_FAN_SPEED_SCHEMA)
hass.services.async_register(DOMAIN, SERVICE_SET_ION_STATE, async_service_set_ion_state, SERVICE_SET_ION_STATE_SCHEMA)
hass.services.async_register(DOMAIN, SERVICE_SET_MODE, async_service_set_mode, SERVICE_SET_MODE_SCHEMA)
return True
async def async_setup_entry(hass, config_entry, async_add_entities):
"""Set up the Dehumidifier device config entry."""
await async_setup_platform(hass, {}, async_add_entities)
class MideaDehumidifierDevice(HumidifierEntity):
"""Representation of a Midea/Inventor dehumidifier device."""
def __init__(self, hass, client, targetDevice):
_LOGGER.debug("midea_dehumidifier: initializing MideaDehumidifierDevice...")
self._hass = hass
self._supported_features = SUPPORT_FLAGS
#Fan modes
self._fan_dict = DEHUMI_FAN_SPEED_DICT
self._fan_list = DEHUMI_FAN_SPEED_LIST
#Device modes
self._modes_dict = DEHUMI_MODES_DICT
self._available_modes = DEHUMI_MODES_LIST
self._device = targetDevice
self._name = "midea_dehumidifier_"+targetDevice['id']
self._unique_id = 'midea_dehumidifier_' + targetDevice['id']
#Default values for device state
self._powerMode = None # 0:off, 1:on
self._mode = None # device's current mode ['Target_humidity', 'Continuos', 'Smart', 'Dryer']
self._ionSetSwitch = None # 0:off, 1:on
self._humidity = None # current humidity
self._humidity_set = None # target hunidity
self._humidity_dot = None # current humidity (decimal)
self._humidity_dot_set = None # target humidity (decimal)
self._windSpeed = None # fan speed [1..99]
self._windSpeedMode = None # fan speed mode (Silent:40, Medium:60, High:80)
self._isDisplay = None
self._filterShow = False
self._tankShow = False
self._dryClothesSetSwitch = None
self._upanddownSwing = None
self._device_class = DEVICE_CLASS_DEHUMIDIFIER
##Get appliance's status to set initial values for the device
#_LOGGER.debug("midea-client: querying appliance status via Web API...")
#res = self._client.get_device_status(self._device['id'])
#if res == 1:
# _LOGGER.debug("midea_dehumidifier: get_device_status suceeded: "+self._client.deviceStatus.toString())
# #Set initial values for device's status
# self.__refresh_device_status()
#else:
# _LOGGER.error("midea_dehumidifier: get_device_status error")
@property
def unique_id(self):
"""Return the unique id."""
return self._unique_id
@property
def name(self):
"""Return the name of the humidity device."""
return self._name
@property
def supported_features(self):
"""Return the list of supported features."""
return self._supported_features
@property
def should_poll(self):
"""Return the polling state."""
#get device's status by polling it: Midea Web API lacks of notification capability
return True
@property
def target_humidity(self):
"""Return the humidity we try to reach."""
return self._humidity_set
@property
def mode(self):
"""Return current mode."""
return self._mode
@property
def available_modes(self):
"""Return available modes."""
return self._available_modes
@property
def is_on(self):
"""Return true if the device is on."""
return self._powerMode
@property
def device_class(self):
"""Return the device class of the humidifier."""
return self._device_class
@property
def ionSetSwitch(self):
return self._ionSetSwitch
@property
def windSpeed(self):
return self._windSpeed
@property
def windSpeedMode(self):
return self._windSpeedMode
@property
def current_humidity(self):
"""Return the current humidity."""
@property
def tank_show(self):
"""Return the current Tank Value."""
return self._tankShow
@property
def min_humidity(self):
"""Return the min humidity set."""
return 40
@property
def max_humidity(self):
"""Return the max humidity set."""
return 85
@property
def device_state_attributes(self):
"""Return entity specific state attributes."""
data = {}
for prop, attr in PROP_TO_ATTR.items():
value = getattr(self, prop)
if value is not None:
data[attr] = value
return data
#asycn methods
async def async_added_to_hass(self):
"""Run when about to be added to hass."""
async_dispatcher_connect(self.hass, SERVICE_SET_FAN_SPEED.format(self.entity_id), self.service_set_fan_speed)
async_dispatcher_connect(self.hass, SERVICE_SET_ION_STATE.format(self.entity_id), self.service_set_ion_state)
async_dispatcher_connect(self.hass, SERVICE_SET_MODE.format(self.entity_id), self.service_set_mode)
# def __hass_update_state_attribute(self, _state, _attr, _value):
# """Update attribute on state obtained via hass.states.get() and return dict containing all the state attributes."""
# data = {}
# for attr, value in _state.attributes.items():
# #_LOGGER.info("(attr, value) = (%s,%s)", attr, value)
# if attr == _attr:
# data[attr] = _value
# else:
# data[attr] = value
# return data
@callback
async def service_set_fan_speed(self, speed_mode):
"""service_set_fan_speed"""
_LOGGER.info("service_set_fan_speed called, speed_mode = %s", speed_mode)
speed = self._fan_dict.get(speed_mode.upper(), 0)
_LOGGER.info("speed = %s", speed)
if self.is_on and self._windSpeed != speed and self._client.deviceStatus.setMode != 4:
_LOGGER.debug("midea-dehumidifier: sending send_fan_speed_command via Web API...")
res = await self.hass.async_add_executor_job(self._client.send_fan_speed_command, self._device["id"], speed)
if res is not None:
_LOGGER.debug("midea-dehumidifier: send_fan_speed_command suceeded: "+self._client.deviceStatus.toString())
self._windSpeed = speed
self._windSpeedMode = speed_mode
#Update state attribute
state = self._hass.states.get('humidifier.'+self._unique_id)
if state:
#attrs = self.__hass_update_state_attribute(state, ATTR_FAN_SPEED_MODE, speed)
attrs = state.attributes.copy()
attrs[ATTR_FAN_SPEED_MODE] = speed_mode
attrs[ATTR_FAN_SPEED] = speed
self._hass.states.async_set('humidifier.'+self._unique_id, state.state, attrs, force_update = True)
else:
_LOGGER.error("midea-dehumidifier: send_fan_speed_command ERROR.")
@callback
async def service_set_ion_state(self, ion_state):
"""service_set_ion_state"""
_LOGGER.info("service_set_ion_state called, ion_state = %s", ion_state)
if self.is_on and self._ionSetSwitch != ion_state:
if ion_state:
_LOGGER.debug("midea-dehumidifier: sending send_ion_on_command via Web API...")
res = await self.hass.async_add_executor_job(self._client.send_ion_on_command, self._device["id"])
else:
_LOGGER.debug("midea-dehumidifier: sending send_ion_off_command via Web API...")
res = await self.hass.async_add_executor_job(self._client.send_ion_off_command, self._device["id"])
if res is not None:
_LOGGER.debug("midea-dehumidifier: send_ion_(on/off)_command suceeded: "+self._client.deviceStatus.toString())
self._ionSetSwitch = ion_state
if state:
#attrs = self.__hass_update_state_attribute(state, ATTR_ION_SET_SWITCH, ion_state)
attrs[ATTR_ION_SET_SWITCH] = ion_state
else:
@callback
async def service_set_mode(self, mode_name):
"""service_set_mode"""
_LOGGER.info("service_set_mode called, mode_name = %s", mode_name)
mode = self._modes_dict.get(mode_name.upper(), 0)
_LOGGER.info("mode = %s", mode)
if self.is_on and self._mode != mode:
_LOGGER.debug("midea-dehumidifier: sending send_mode_command via Web API...")
res = await self.hass.async_add_executor_job(self._client.send_mode_command, self._device["id"], mode)
if res is not None:
_LOGGER.debug("midea-dehumidifier: send_mode_command suceeded: "+self._client.deviceStatus.toString())
self._mode = mode_name
#Dryer mode set speed_mode to High too
if mode == 4:
self._windSpeedMode = 'High'
self._windSpeed = self._fan_dict.get('HIGH', 0)
if state:
attrs[ATTR_MODE] = mode_name
if mode == 4:
attrs[ATTR_FAN_SPEED_MODE] = 'High'
attrs[ATTR_FAN_SPEED] = self._fan_dict.get('HIGH', 0)
#attrs = self.__hass_update_state_attribute(state, ATTR_MODE, mode)
else:
_LOGGER.error("midea-dehumidifier: send_mode_command ERROR.")
async def async_update(self):
"""Retrieve latest state from the appliance and keep UI updated with respect to the updated status."""
_LOGGER.info("midea-dehumidifier: async_update called.")
if self._client.security.access_token:
_LOGGER.debug("midea-dehumidifier: sending get_device_status via Web API...")
res = await self.hass.async_add_executor_job(self._client.get_device_status, self._device['id'])
if res == 1:
_LOGGER.info(self._device['id']+" - "+self._client.deviceStatus.toString())
#Refresh device status
else:
_LOGGER.error("midea-dehumidifier: get_device_status ERROR.")
def __refresh_device_status(self):
"""Called by async_update(self): keep UI updated with respect to the updated status."""
if self._client.deviceStatus is not None:
self._powerMode = self._client.deviceStatus.powerMode
self._ionSetSwitch = self._client.deviceStatus.ionSetSwitch
#Current mode
#self._mode = self._client.deviceStatus.setMode
self._mode = self._available_modes[self._client.deviceStatus.setMode - 1]
self._windSpeed = self._client.deviceStatus.windSpeed
if self._windSpeed == 40:
self._windSpeedMode = self._fan_list[0]
elif self._windSpeed == 60:
self._windSpeedMode = self._fan_list[1]
elif self._windSpeed == 80:
self._windSpeedMode = self._fan_list[2]
else:
self._windSpeedMode = "unknown"
self._humidity = self._client.deviceStatus.humidity
self._humidity_set = self._client.deviceStatus.humidity_set
self._humidity_dot = self._client.deviceStatus.humidity_dot
self._humidity_dot_set = self._client.deviceStatus.humidity_dot_set
self._isDisplay = self._client.deviceStatus.isDisplay
self._filterShow = self._client.deviceStatus.filterShow
self._tankShow = self._client.deviceStatus.tankShow
self._dryClothesSetSwitch = self._client.deviceStatus.dryClothesSetSwitch
self._upAndDownSwing = self._client.deviceStatus.upAndDownSwing
#Useful or useless ?
#self.async_update_ha_state()
#self.async_schedule_update_ha_state()
#PROVE
#async_update_entity(self._hass, self._name)
#async_update_entity(self._hass, 'humidifier.midea_dehumidifier_17592186063322')
#ALTERNATIVA DA PROVARE: self.async_update_entity(self._hass, self._unique_id)
# state = hass.states.get(entity_id)
# if state:
# attrs = state.attributes
# self._hass.states.set(self._unique_id, state, state.attributes, force_update=True)
async def async_turn_on(self, **kwargs):
"""Turn the device on."""
_LOGGER.info("midea-dehumidifier:async_turn_on called.")
if not self.is_on:
_LOGGER.debug("midea-dehumi: sending power-on command via Web API...")
#res = self._client.send_poweron_command(self._device["id"])
res = await self.hass.async_add_executor_job(self._client.send_poweron_command, self._device["id"])
if res is not None:
_LOGGER.debug("midea-dehumidifier: send_poweron_command suceeded: "+self._client.deviceStatus.toString())
else:
_LOGGER.error("midea-dehumidifier: send_poweron_command ERROR.")
async def async_turn_off(self, **kwargs):
"""Turn the device off."""
_LOGGER.info("midea-dehumidifier: async_turn_off called.")
if self.is_on:
_LOGGER.debug("midea-dehumi: sending power-off command via Web API...")
#res = self._client.send_poweroff_command(self._device["id"])
res = await self.hass.async_add_executor_job(self._client.send_poweroff_command, self._device["id"])
if res is not None:
_LOGGER.debug("midea-dehumidifier: send_poweroff_command suceeded: "+self._client.deviceStatus.toString())
else:
_LOGGER.error("climate.midea-dehumi: send_poweroff_command ERROR.")
async def async_set_humidity(self, humidity):
"""Set new humidity level."""
_LOGGER.info("midea-dehumidifier: async_set_humidity called.")
if self.is_on:
if self._humidity_set != humidity:
_LOGGER.debug("midea-dehumidifier: setting new target hunidity value via Web API...")
#res = self._client.send_target_humidity_command(self._device["id"], humidity)
res = await self.hass.async_add_executor_job(self._client.send_target_humidity_command, self._device["id"], humidity)
if res is not None:
_LOGGER.info("midea-dehumidifier: send_target_humidity_command succeeded: "+self._client.deviceStatus.toString())
else:
_LOGGER.error("midea-dehumidifier: send_target_humidity_command ERROR")
async def async_set_mode(self, mode):
"""Update mode."""
_LOGGER.info("midea-dehumidifier: async_set_mode called; current_mode=%s, new mode=%s", self._mode, mode)
if self.is_on:
mode_num = self._modes_dict.get(mode.upper(), 0)
_LOGGER.debug("midea-dehumi: sending update status command via Web API...")
#res = self._client.send_mode_command(self._device["id"], mode_num)
res = await self.hass.async_add_executor_job(self._client.send_mode_command, self._device["id"], mode_num)
if res is not None:
self._client.deviceStatus._setMode = mode_num
else:
_LOGGER.error("climate.midea-dehumi: send_mode_command ERROR.")
Hello, do you get any info about compatibility of Atmosphere with this component?
Update: Inventor Atmosphere use Tuya as communication, so you can use TuyaSmart app instead
Inventor Control. Even Tuya has a native support in HA, the Tuya dehumidifier’s doesn’t supported yet, so you can just have scenes defined in Tuya which you can trigger from HA but this is one way communication. I hope HA will get support for Tuya dehumidifier’s in the near feature.
Hello fellow home-assistant enthusiasts!
I have a quick question, did anybody (or is it even possible?) used a Wemos Mini (Esp8266) and Tasmota to controll the device cloud-free?
I have found projects for ESP8266 but not with the Wemos version or Tasmota
Update:
I got the cloud-free control through https://github.com/Hypfer/esp8266-midea-dehumidifier
I also didn’t use a USB Adapter since I cut the USB female connector and connected direct the cables on ESP-01
Hello! A couple of days now the integration stopped working. I believe something changed to the midea API.
Problem resolved without any changes.
Problem integation log pase:
Logger: homeassistant.setup
Source: setup.py:308
First occurred: 20:52:44 (2 occurrences)
Last logged: 20:52:45
My product Inventor Eva II PRO WiFi, everything was working so far with HACS
Help, please…
My sistem:
Versión | core-2021.4.3 |
Tipo de instalación | Home Assistant OS |
Desarrollo | false |
Supervisor | true |
Docker | true |
Entorno virtual | false |
Versión de Python | 3.8.7 |
Nombre del Sistema Operativo | Linux |
Versión del Sistema Operativo | 5.4.83-v7l |
Arquitectura de CPU | armv7l |
Zona horaria | Europe/Madrid |
Try to update your integration. There were some recent changes in the repository which do fix the issue.
I had the same problem using it as a manual added custom component and after installing the new files it is working perfectly again.
I have a question. Is possible have a sensor, to know when the tank is water full ?
Hello Barban,
please do you think this integration would work with the new “ion” version? seems same and I dont care about automating the ioniser… just dehumidifying.
BR,
Dusan
It seems that there is compatibility, based on this issue.
Although, it would be great if we had an official response approving its full compatibility.
Hope to have a response as well.
thank you, i noted that eva 2 pro too had Ioniser on UK Amazon so I figured it could just be different markets naming. I ordered to Slovakia from German Amazon, as only one seller here offered it, and that for 350 eur, so ordering from Germany with 50 eur postage still saved me 100 eur :).
now let’s hope it works :D, as it’s the main reason I got this model
Please inform us about its compatibility with the integration, as soon as it arrives.
Thank you
Anyone know if this works with the Media 50 Pint Cube dehumidifier?
MAD50S1QWT
So, does anyone know if the Eva ION Pro is compatible with this integration?
It works! I can set target humidity and modes and so on!
Thank you barban,
I confirm this custom component works also with “Eva ION Pro Wi-Fi“
I can confirm that it works for “50 Pint Cube Smart Dehumidifier” : MC50MSWBA3RCM
The only function that has a quirk is ‘Fan Mode’. The Cube model mentioned only has two fan speeds - Low and High. Using the the ‘Medium’ input_select changes the Fan Mode to ‘Low’ - so no real issue there just have to remember.
All other functions work as expected.
Hello, so I tried out quite a bit of what I’ve read here.
First that works with the integration of several devices.
Now to the problems it depends on which card is used. If you use the recommended card, you can’t change Fan Made at all.
But if you use a different card you can change the Fan Mod and the mode, but with me it happens on all devices at the same time. Sometimes all devices turn on.
