Mine have done the same a couple of times.
I just delete the miele token, hidden file in the config folder and then restart.
to reconfigure the component again.
Thatās what Iāve done the last few times I saw this error.
Thank you Salkin! It worked!
Where is the hidden Miele token hidden thanks as have looked and cant see it?
it is a hidden file in your config folder, so where your configuration.yaml lives.
it is called .miele-token-cache
thanks! worked for me too
Hey, now miele has implemented control of the ventilation hood through miele@home-api (finally), does this work with the plugin? I am really looking forward to this as this is actually useful, I can control it with my light switches.
Hi!
at first, many thanks for this Great Integration!
I have a problem with the sensor programType. This habe always the state āeigenes Programmā. What is wrong in my config? The other sensors all Fine.
Thanks and regards
Frank
Iām trying to setup a state trigger to notify me once the washingmachine is done. However the state trigger never seems to fire. Iām really new to home assistant so I hope I did this trigger configuration right:
platform: state
entity_id: sensor.waschmaschine_status
to: Finished
Anyone got any idea why this might not work?
Thnx in advance!
In my German version it looks like this:
- platform: state
to: 'Ende'
Maybe you should change Finished
to 'Finished'
It is possible to create a sensor for the detergent level and display the prgramname?
No, the detergent level isnāt available via the API.
Also there are programPhase and programType, but no programName in the API.
Here you can find whatās available by device.
Great, thanks for the Information!
But the programType is always 1. Is that correct too?
ProgramType: Eigenes Programm
rawProgramType: 1
Yes, at least for my washing machine.
My tumble dryer always shows
programType: Reinigungs-/ Pflegeprogramm
rawProgramType: 3
Auch lustig - Vielleicht Ƥndert sich das ja in den zukĆ¼nftigen API Updates
Yes, Iām quite sure. The API is still in Beta. But most important for me is āremaing Timeā and the info, that the program has finished (which trigger an automation).
Thatās true. Thatās enough for me at first
Thnx for the response (sorry for my late one but well it takes some time to fill the machine ':)), it didnāt seem to help unfortunately.
This is the automation as defined in my automations.yaml
- id: '1601539751186'
alias: Washmachine Klaar EN
- platform: state
to: 'Finished'
- service: tts.google_translate_say
message: De wasmachine is klaar
language: nl
entity_id: media_player.woonkamer_speaker
mode: single
However it doesnāt trigger when I check the logs.
And if you remove the line with from: 'In use'
