All error messages should be fixed including both I/O errors. Let me know if there are any problems left. Update from HACS from this source : https://github.com/HomeAssistant-Mods/home-assistant-miele
good morning, thanks for fixing most messages, I still got one just now:
Log Details (ERROR)
Logger: homeassistant.setup
Source: custom_components/miele/init.py:124
First occurred: 9:00:19 (1 occurrences)
Last logged: 9:00:19
Error during setup of component miele
File “/usr/src/homeassistant/homeassistant/setup.py”, line 171, in _async_setup_component
hass, processed_config
File “/config/custom_components/miele/init.py”, line 124, in async_setup
client = MieleClient(hass.data[DOMAIN][DATA_OAUTH])
TypeError: init() missing 1 required positional argument: ‘session’
Same error here.
I deleted the token and authorized again but the error remaibd.
Same here (repeated authorization):
__init__() missing 1 required positional argument: 'session'
File "/usr/src/homeassistant/homeassistant/components/websocket_api/commands.py", line 130, in handle_call_service
connection.context(msg),
File "/usr/src/homeassistant/homeassistant/core.py", line 1253, in async_call
task.result()
File "/usr/src/homeassistant/homeassistant/core.py", line 1288, in _execute_service
await handler.func(service_call)
File "/usr/src/homeassistant/homeassistant/components/configurator/__init__.py", line 235, in async_handle_service_call
await self.hass.async_add_job(callback, call.data.get(ATTR_FIELDS, {}))
File "/config/custom_components/miele/__init__.py", line 75, in miele_configuration_callback
await async_setup(hass, config)
File "/config/custom_components/miele/__init__.py", line 124, in async_setup
TypeError: __init__() missing 1 required positional argument: 'session'
Sorry guys. My local testing and github branche seem to have gotten out of sync… And I forgot to restart my HA after updating the plugin from HACS… Issue should be fixed now :)! @martinweu also did a PR with the solution. Please report back when you find any more issues
No more messages. Thanks!
That’s good to hear :)!
Thank you. It’s running perfect now.
Thank you for the adjustments and the I / O error has been fixed. However, I am now stuck on a new bug and cannot get any further. I would be very grateful to you for a hint:
Source: custom_components/miele/miele_at_home.py:46
First occurred: 21:54:53 (1 occurrences)
Last logged: 21:54:53
File “/config/custom_components/miele/init.py”, line 126, in async_setup
data_get_devices = await client.get_devices(lang)
File “/config/custom_components/miele/miele_at_home.py”, line 46, in get_devices
for home_device in home_devices:
TypeError: ‘coroutine’ object is not iterable
This seems to be a bug on my side… I must have missed an await somewhere Will take a look tonight.
For future problems. Please just open an issue here since the original developer seens to not be working on this anymore : https://github.com/HomeAssistant-Mods/home-assistant-miele/issues please post the version you are running and the errors.
@Edus please let me know which version you are running. As far as I can see this isn’t possible to happen in the latest version. Please also try to reboot your hass after the update.
@kloknibor Thank you for your support. I tested the integration again in a new installation and it runs perfectly. My next attempt is to restore my configuration to an earlier state and I assume it will work.
Thanks again for your efforts!
Hi I am getting the following warning with the request to report this to the author of the component:
Log Details (WARNING)
Logger: homeassistant.components.http
Source: components/http/init.py:180
Integration: HTTP (documentation, issues)
First occurred: 15:59:40 (1 occurrences)
Last logged: 15:59:40
Detected use of deprecated base_url
property, use homeassistant.helpers.network.get_url
method instead. Please report issue to the custom component author for miele using this method at custom_components/miele/init.py, line 107: callback_url = ‘{}{}’.format(hass.config.api.base_url, AUTH_CALLBACK_PATH)
I pushed an update. Please try it and let me know
the message is gone, you are a star!
This installation step pip3 install requests_oauthlib…
Do we have to do that each time you upgrade HA? It is done inside a container so does it survive upgrades?
based on the way your system is set-up this could be the case. If your running everything in a container it might indeed get destroyed and you need to reinstall. I can see if I can get Home assistant to install the dependency in the future later on :)!
Hi all!
My component stopped working after HA update. Am I alone?
Source: custom_components/miele/miele_at_home.py:24
First occurred: 12:46:27 (1 occurrences)
Last logged: 12:46:27
File "/usr/local/lib/python3.8/site-packages/requests_oauthlib/oauth2_session.py", line 477, in request
url, headers, data = self._client.add_token(
File "/usr/local/lib/python3.8/site-packages/oauthlib/oauth2/rfc6749/clients/base.py", line 198, in add_token
raise TokenExpiredError()
oauthlib.oauth2.rfc6749.errors.TokenExpiredError: (token_expired)
File "/usr/src/homeassistant/homeassistant/setup.py", line 191, in _async_setup_component
result = await task
File "/config/custom_components/miele/__init__.py", line 127, in async_setup
File "/config/custom_components/miele/miele_at_home.py", line 41, in get_devices
home_devices = await self._get_devices_raw(lang)
File "/config/custom_components/miele/miele_at_home.py", line 24, in _get_devices_raw
devices = await self.hass.async_add_executor_job(func)
File "/usr/local/lib/python3.8/concurrent/futures/thread.py", line 57, in run
File "/usr/local/lib/python3.8/site-packages/requests/sessions.py", line 543, in get
return self.request('GET', url, **kwargs)
File "/usr/local/lib/python3.8/site-packages/requests_oauthlib/oauth2_session.py", line 496, in request
token = self.refresh_token(
File "/usr/local/lib/python3.8/site-packages/requests_oauthlib/oauth2_session.py", line 446, in refresh_token
self.token = self._client.parse_request_body_response(r.text, scope=self.scope)
File "/usr/local/lib/python3.8/site-packages/oauthlib/oauth2/rfc6749/clients/base.py", line 421, in parse_request_body_response
self.token = parse_token_response(body, scope=scope)
File "/usr/local/lib/python3.8/site-packages/oauthlib/oauth2/rfc6749/parameters.py", line 431, in parse_token_response
validate_token_parameters(params)
File "/usr/local/lib/python3.8/site-packages/oauthlib/oauth2/rfc6749/parameters.py", line 441, in validate_token_parameters
raise MissingTokenError(description="Missing access token parameter.")
oauthlib.oauth2.rfc6749.errors.MissingTokenError: (missing_token) Missing access token parameter.
