Did any one try and did it work?
I just restarted my HA because of another sensor, and now i see all the miele sensors
So i think the api is up and running agian.
Got this from Miele:
“We’ve an issue cause by a server movement.
From our point everything is running again.”
So I restarted HA and voilà, it is working again!
I got my miele tumbler 2 days ago and sent email to [email protected] to get access but still no response.
How long did you guys wait to get the access token ?
I waited 5 hours, but that was immediately after they opened the beta, so I guess I was almost the first one
bummer for me, good for you
I get the following message: Unable to find services.yaml for the miele integration
Can anyone please explain what this means? Also i do not see any sensors, but maybe that’s linked to the error message. Any help would be greatly appreciated
Now it is working again for me as well I have not made any changes or edits, just restarted HA.
I got my keys now - yay.
but during setup I get this issue https://github.com/docbobo/home-assistant-miele/issues/12
I get the following error messages: can anyone post me in the right directions to solve this?
2019-06-02 16:51:15 ERROR (SyncWorker_17) [custom_components.miele.miele_at_home] Failed to retrieve devices: 504
2019-06-02 16:51:15 ERROR (SyncWorker_17) [custom_components.miele] Did not receive Miele devices
2019-06-02 16:51:46 ERROR (SyncWorker_11) [custom_components.miele.miele_at_home] Failed to retrieve devices: 500
2019-06-02 16:51:46 ERROR (SyncWorker_11) [custom_components.miele] Did not receive Miele devices
2019-06-02 17:23:49 ERROR (SyncWorker_9) [custom_components.miele.miele_at_home] Failed to retrieve devices: 504
2019-06-02 17:23:49 ERROR (SyncWorker_9) [custom_components.miele] Did not receive Miele devices
2019-06-02 17:24:03 ERROR (SyncWorker_3) [custom_components.miele.miele_at_home] Failed to retrieve devices: 500
2019-06-02 17:24:03 ERROR (SyncWorker_3) [custom_components.miele] Did not receive Miele devices
2019-06-02 17:24:51 ERROR (SyncWorker_0) [custom_components.miele.miele_at_home] Failed to retrieve devices: 500
2019-06-02 17:24:51 ERROR (SyncWorker_0) [custom_components.miele] Did not receive Miele devices
forget my post above, I now finally can see the sensors!
This is too good! Followed the instructions and it worked flawlessly. I can now see my new Miele washing machine in HA! Woo-Hoo! I can’t wait to do a load of washing now
I am so impressed, I created this - this thing should be an official component! Please up vote.
Great work @docbobo.
I get this error now. Is this because of the new 1.0 API?
Error during setup of component miele
File “/usr/src/homeassistant/homeassistant/setup.py”, line 153, in _async_setup_component
hass, processed_config)
File “/config/custom_components/miele/init.py”, line 116, in async_setup
cache_path=cache)
File “/config/custom_components/miele/miele_at_home.py”, line 103, in init
self.refresh_token()
File “/config/custom_components/miele/miele_at_home.py”, line 128, in refresh_token
refresh_token=self._token[‘refresh_token’])
File “/usr/local/lib/python3.7/site-packages/requests_oauthlib/oauth2_session.py”, line 374, in refresh_token
self.token = self._client.parse_request_body_response(r.text, scope=self.scope)
File “/usr/local/lib/python3.7/site-packages/oauthlib/oauth2/rfc6749/clients/base.py”, line 415, in parse_request_body_response
self.token = parse_token_response(body, scope=scope)
File “/usr/local/lib/python3.7/site-packages/oauthlib/oauth2/rfc6749/parameters.py”, line 425, in parse_token_response
validate_token_parameters(params)
File “/usr/local/lib/python3.7/site-packages/oauthlib/oauth2/rfc6749/parameters.py”, line 435, in validate_token_parameters
raise MissingTokenError(description=“Missing access token parameter.”)
oauthlib.oauth2.rfc6749.errors.MissingTokenError: (missing_token) Missing access token parameter.
Exact same problem here. I suppose that they changed something.
Does someone has a solution for this because I’m really missing my link with HA. It doesn’t work anymore and I loved it
Thanks!
How did you fix this @Trouble-51 ?
I’m also on Hassio. Created folder custom_components/miele under the config folder and copied the files over.
Added the following at the end of the configuration.yaml file:
miele:
client_id: ***
client_secret: ***
lang: en
Finally I checked to see if the requests_oauthlib library existed:
When I do “check config” it just keeps spinning forever. If I press “restart server” it will not do it. I have not tried disconnecting the power and forcing a restart that way.
As there are no errors it’s very difficult to troubleshoot Any ideas?
Goede morgen,
Ik was op reis, vandaar de late reactie. Ik denk dat je de file .miele-token-cache in config moet deleten en de voor miele regels in the configuration file even een # moet zetten dan hassio opnieuw starten, de # weer weghalen en weer starten. Dan krijg je waarschijnlijk het scherm van Miele dat vraagt om het land etc. Als dat allemaal niet lukt kun je een nieuwe client_id en client_secret aanvragen en het opnieuw proberen weer na dat de .miele-token-cache eerst is gedeelte.
groet,
Jos
Heel erg bedankt voor je reactie. Ik test het zo snel mogelijk
Did you get it working?
