Miele@home, miele@mobile component
Ho avuto lo stesso problema, rimosso tutto e installato HACS e boom tutto funziona.
I keep getting
“Unable to find services.yaml for the miele integration
4:27 PM helpers/service.py (WARNING)”
I have deleted and reinstalled and rebooted multiple times. Any advice?
Cheers
Stuart
same here, reinstalled but the same warning keeps re-appearing:
Log Details (WARNING)
Logger: homeassistant.helpers.service
First occured: 2:42:39 PM (4 occurences)
Last logged: 2:42:39 PM
I see this message every time I restart HA. But it doesn’t matter. The Miele integration works like a charm. So my advice is to ignore this warning.
I will try to look into why that is this week, but it should work normally.
Just solved the issue, add this to HACS : https://github.com/HomeAssistant-Mods/home-assistant-miele
I just added an empty file which solves the error in the log. The error comes from the fact that the integration is adding service dynamically. But these are not needed in services.yaml for now and it would also be hard since they are dynamic ;-)!
I tried installing HA as a direct image, (vhdx), but I don’t understand how i do this part : "The requests_oauthlib library as part of your HA installation. Please install via pip3 install requests_oauthlib" the virtual machine only has the HA-cli available?
please read the description of the repo : https://github.com/HomeAssistant-Mods/home-assistant-miele
I have, the question is about something that is in the installation instructions of the repo. (under the “prerequisite”-part.)
You could try to use this to get more access : Home Assistant Community Add-on: SSH & Web Terminal , let me know if it works ;-)!
Receiving this error. Component suddenly stopped working.
Anyone knows what to do?
using hassio 0.107.7
2020-04-26 23:30:33 ERROR (MainThread) [homeassistant.setup] Error during setup of component miele
File “/config/custom_components/miele/init.py”, line 112, in async_setup
File “/config/custom_components/miele/miele_at_home.py”, line 103, in init
File “/config/custom_components/miele/miele_at_home.py”, line 128, in refresh_token
@kloknibor
First of all thank you once again for taking up this project.
i am getting this error after updating to 109.
2020-04-30 11:54:45 WARNING (MainThread) [homeassistant.util.async_] Detected I/O inside the event loop. This is causing stability issues. Please report issue to the custom component author for miele doing I/O at custom_components/miele/miele_at_home.py, line 128: refresh_token=self._token['refresh_token'])
2020-04-30 11:54:45 WARNING (MainThread) [homeassistant.util.async_] Detected I/O inside the event loop. This is causing stability issues. Please report issue to the custom component author for miele doing I/O at custom_components/miele/miele_at_home.py, line 21: devices = self._session._session.get(MieleClient.DEVICES_URL, params={'language':lang})
I just read thru the release log and noticed this, so just to let you know.
Detection of blocking I/O in the event loop
This is a bit technical, but some things happening in Home Assistant, like fetching data from an API or website, can lock up Home Assistant for a small moment, if not done correctly. Until now, this has been hard to detect.
This release adds logic in the core of Home Assistant that is able to detect if an integration does one of those blocking calls and writes a messages to the logs.
io.png751×226
Screenshot of an example log entry.
If you see such a message in your logs, please report the issue on our GitHub 4 so we can fix those cases. If a custom component causes the log, it should be reported with the author of that custom integration.
By addressing these issues, we are able to greatly improve the performance, responsiveness and stability of Home Assistant.
Hi, I get the following warning:
Logger: homeassistant.util.async_
Source: util/async_.py:120
First occurred: 3:23:51 PM (2 occurrences)
Last logged: 3:23:52 PM
  • Detected I/O inside the event loop. This is causing stability issues. Please report issue to the custom component author for miele doing I/O at custom_components/miele/miele_at_home.py, line 128: refresh_token=self._token[‘refresh_token’])
  • Detected I/O inside the event loop. This is causing stability issues. Please report issue to the custom component author for miele doing I/O at custom_components/miele/miele_at_home.py, line 21: devices = self._session._session.get(MieleClient.DEVICES_URL, params={‘language’:lang})
any help to get rid of this warning would be welcome!
Same error here in home assistant 0.109.2. Miele component isn’t working yet.
And also:
  File "/usr/src/homeassistant/homeassistant/setup.py", line 171, in _async_setup_component
    hass, processed_config
  File "/config/custom_components/miele/__init__.py", line 112, in async_setup
    cache_path=cache)
  File "/config/custom_components/miele/miele_at_home.py", line 103, in __init__
    self.refresh_token()
  File "/config/custom_components/miele/miele_at_home.py", line 128, in refresh_token
  File "/usr/local/lib/python3.7/site-packages/requests_oauthlib/oauth2_session.py", line 446, in refresh_token
    self.token = self._client.parse_request_body_response(r.text, scope=self.scope)
  File "/usr/local/lib/python3.7/site-packages/oauthlib/oauth2/rfc6749/clients/base.py", line 421, in parse_request_body_response
    self.token = parse_token_response(body, scope=scope)
  File "/usr/local/lib/python3.7/site-packages/oauthlib/oauth2/rfc6749/parameters.py", line 431, in parse_token_response
    validate_token_parameters(params)
  File "/usr/local/lib/python3.7/site-packages/oauthlib/oauth2/rfc6749/parameters.py", line 441, in validate_token_parameters
    raise MissingTokenError(description="Missing access token parameter.")
oauthlib.oauth2.rfc6749.errors.MissingTokenError: (missing_token) Missing access token parameter.
Hi, I am getting the following messages after updating Hass.io to .0110.1
Logger: homeassistant.components.binary_sensor
Source: components/binary_sensor/init.py:174
Integration: Binary Sensor (documentation, issues)
First occurred: 12:45:52 (1 occurrences)
Last logged: 12:45:52
BinarySensorDevice is deprecated, modify MieleBinarySensor to extend BinarySensorEntity
Logger: homeassistant.components.light
Source: components/light/init.py:451
Integration: Light (documentation, issues)
Light is deprecated, modify MieleLight to extend LightEntity
Can someone help getting rid of these messages?
… and here is another warning that came up when restarting HA
First occurred: 13:37:15 (2 occurrences)
Last logged: 13:37:15
So does it work with the latest HA with just some warnings or isn’t it working at all? Also is someone already working on fixing them?
Hi, at least I haven’t found a solution to get it working after the update. But that doesn’t mean anything :wink:
Is there a way to avoid the errors or are you using an alternative now?
Thank you in advance
Everything seems to be working but the warning messages keep coming upend are quiet annoying.
hey guys, just pushed a fix for the I/O error problem here : https://github.com/HomeAssistant-Mods/home-assistant-miele
It seems to be working fine on my end. There are still some more errors, I’ll take a look later
EDIT: Seems like I only fixed 1 out of 2… Sorry… Will check this later
