Ok, so I have enabled the debug. And results are what I expected (if I understand that correctly) - query and processing combined takes fraction of a single second.
Just out of curiosity: you are using 4011 as sampler for documentation - Is that something that you have on your own ? → I do not know what a platform are you using for the HA itself but I am pretty sure that issue lays somewhere on the HA side - some kind of worker configuration or so.
Summary
2023-02-14 14:08:13.765 DEBUG (SyncWorker_2) [custom_components.mikrotik_router.mikrotikapi] API query: /system/resource
2023-02-14 14:08:13.771 DEBUG (SyncWorker_2) [custom_components.mikrotik_router.apiparser] Processing source [{'uptime': '1d2h53m4s', 'version': '6.49.7 (stable)', 'build-time': 'Oct
2023-02-14 14:08:13.772 DEBUG (SyncWorker_2) [custom_components.mikrotik_router.apiparser] Processing entry {'uptime': '1d2h53m4s', 'version': '6.49.7 (stable)', 'build-time': 'Oct/1
2023-02-14 14:08:13.773 DEBUG (SyncWorker_2) [custom_components.mikrotik_router.mikrotikapi] API query: /system/package/update
2023-02-14 14:08:14.778 DEBUG (SyncWorker_2) [custom_components.mikrotik_router.mikrotikapi] API query: /system/package/update
2023-02-14 14:08:14.781 DEBUG (SyncWorker_2) [custom_components.mikrotik_router.apiparser] Processing source [{'channel': 'stable', 'installed-version': '6.49.7', 'latest-version': '
2023-02-14 14:08:14.782 DEBUG (SyncWorker_2) [custom_components.mikrotik_router.apiparser] Processing entry {'channel': 'stable', 'installed-version': '6.49.7', 'latest-version': '6.
2023-02-14 14:08:14.785 DEBUG (SyncWorker_7) [custom_components.mikrotik_router.mikrotikapi] API query: /system/health
2023-02-14 14:08:14.789 DEBUG (SyncWorker_7) [custom_components.mikrotik_router.apiparser] Processing source [{'voltage': 24, 'temperature': 43}]
2023-02-14 14:08:14.789 DEBUG (SyncWorker_7) [custom_components.mikrotik_router.apiparser] Processing entry {'voltage': 24, 'temperature': 43}
2023-02-14 14:08:14.792 DEBUG (SyncWorker_7) [custom_components.mikrotik_router.mikrotikapi] API query: /ip/dhcp-client
2023-02-14 14:08:14.797 DEBUG (SyncWorker_7) [custom_components.mikrotik_router.apiparser] Processing source [{'.id': '*2', 'interface': 'WAN1', 'add-default-route': False, 'use-pee
2023-02-14 14:08:14.798 DEBUG (SyncWorker_7) [custom_components.mikrotik_router.apiparser] Processing entry {'.id': '*2', 'interface': 'WAN1', 'add-default-route': False, 'use-peer-
2023-02-14 14:08:14.798 DEBUG (SyncWorker_7) [custom_components.mikrotik_router.apiparser] Processing entry {'.id': '*5', 'interface': 'WAN2', 'add-default-route': False, 'use-peer-
2023-02-14 14:08:14.802 DEBUG (SyncWorker_3) [custom_components.mikrotik_router.mikrotikapi] API query: /interface
2023-02-14 14:08:14.845 DEBUG (SyncWorker_3) [custom_components.mikrotik_router.apiparser] Processing source [{'.id': '*1', 'name': 'WAN1', 'default-name': 'ether1', 'type': 'ether',
2023-02-14 14:08:14.846 DEBUG (SyncWorker_3) [custom_components.mikrotik_router.apiparser] Processing entry {'.id': '*1', 'name': 'WAN1', 'default-name': 'ether1', 'type': 'ether', '
2023-02-14 14:08:14.846 DEBUG (SyncWorker_3) [custom_components.mikrotik_router.apiparser] Processing entry {'.id': '*6', 'name': 'WAN2', 'default-name': 'sfp1', 'type': 'ether', 'mt
2023-02-14 14:08:14.847 DEBUG (SyncWorker_3) [custom_components.mikrotik_router.apiparser] Processing entry {'.id': '*2', 'name': 'ether2', 'default-name': 'ether2', 'type': 'ether',
2023-02-14 14:08:14.847 DEBUG (SyncWorker_3) [custom_components.mikrotik_router.apiparser] Processing entry {'.id': '*3', 'name': 'ether3', 'default-name': 'ether3', 'type': 'ether',
2023-02-14 14:08:14.848 DEBUG (SyncWorker_3) [custom_components.mikrotik_router.apiparser] Processing entry {'.id': '*4', 'name': 'ether4', 'default-name': 'ether4', 'type': 'ether',
2023-02-14 14:08:14.848 DEBUG (SyncWorker_3) [custom_components.mikrotik_router.apiparser] Processing entry {'.id': '*5', 'name': 'ether5', 'default-name': 'ether5', 'type': 'ether',
2023-02-14 14:08:14.848 DEBUG (SyncWorker_3) [custom_components.mikrotik_router.apiparser] Processing entry {'.id': '*7', 'name': 'ether6', 'default-name': 'ether6', 'type': 'ether',
2023-02-14 14:08:14.849 DEBUG (SyncWorker_3) [custom_components.mikrotik_router.apiparser] Processing entry {'.id': '*8', 'name': 'ether7', 'default-name': 'ether7', 'type': 'ether',
2023-02-14 14:08:14.849 DEBUG (SyncWorker_3) [custom_components.mikrotik_router.apiparser] Processing entry {'.id': '*9', 'name': 'ether8', 'default-name': 'ether8', 'type': 'ether',
2023-02-14 14:08:14.850 DEBUG (SyncWorker_3) [custom_components.mikrotik_router.apiparser] Processing entry {'.id': '*A', 'name': 'ether9', 'default-name': 'ether9', 'type': 'ether',
2023-02-14 14:08:14.850 DEBUG (SyncWorker_3) [custom_components.mikrotik_router.apiparser] Processing entry {'.id': '*B', 'name': 'ether10', 'default-name': 'ether10', 'type': 'ether'
2023-02-14 14:08:14.853 DEBUG (SyncWorker_3) [custom_components.mikrotik_router.mikrotikapi] API query: /interface/ethernet
2023-02-14 14:08:14.925 DEBUG (SyncWorker_3) [custom_components.mikrotik_router.apiparser] Processing source [{'.id': '*1', 'name': 'WAN1', 'default-name': 'ether1', 'mtu': 1500, 'l2m
2023-02-14 14:08:14.926 DEBUG (SyncWorker_3) [custom_components.mikrotik_router.apiparser] Processing entry {'.id': '*1', 'name': 'WAN1', 'default-name': 'ether1', 'mtu': 1500, 'l2mtu
2023-02-14 14:08:14.927 DEBUG (SyncWorker_3) [custom_components.mikrotik_router.apiparser] Processing entry {'.id': '*6', 'name': 'WAN2', 'default-name': 'sfp1', 'mtu': 1500, 'l2mtu':
2023-02-14 14:08:14.927 DEBUG (SyncWorker_3) [custom_components.mikrotik_router.apiparser] Processing entry {'.id': '*2', 'name': 'ether2', 'default-name': 'ether2', 'mtu': 1500, 'l2m
2023-02-14 14:08:14.928 DEBUG (SyncWorker_3) [custom_components.mikrotik_router.apiparser] Processing entry {'.id': '*3', 'name': 'ether3', 'default-name': 'ether3', 'mtu': 1500, 'l2m
2023-02-14 14:08:14.928 DEBUG (SyncWorker_3) [custom_components.mikrotik_router.apiparser] Processing entry {'.id': '*4', 'name': 'ether4', 'default-name': 'ether4', 'mtu': 1500, 'l2m
2023-02-14 14:08:14.929 DEBUG (SyncWorker_3) [custom_components.mikrotik_router.apiparser] Processing entry {'.id': '*5', 'name': 'ether5', 'default-name': 'ether5', 'mtu': 1500, 'l2m
2023-02-14 14:08:14.929 DEBUG (SyncWorker_3) [custom_components.mikrotik_router.apiparser] Processing entry {'.id': '*7', 'name': 'ether6', 'default-name': 'ether6', 'mtu': 1500, 'l2m
2023-02-14 14:08:14.929 DEBUG (SyncWorker_3) [custom_components.mikrotik_router.apiparser] Processing entry {'.id': '*8', 'name': 'ether7', 'default-name': 'ether7', 'mtu': 1500, 'l2m
2023-02-14 14:08:14.930 DEBUG (SyncWorker_3) [custom_components.mikrotik_router.apiparser] Processing entry {'.id': '*9', 'name': 'ether8', 'default-name': 'ether8', 'mtu': 1500, 'l2m
2023-02-14 14:08:14.930 DEBUG (SyncWorker_3) [custom_components.mikrotik_router.apiparser] Processing entry {'.id': '*A', 'name': 'ether9', 'default-name': 'ether9', 'mtu': 1500, 'l2m
2023-02-14 14:08:14.931 DEBUG (SyncWorker_3) [custom_components.mikrotik_router.apiparser] Processing entry {'.id': '*B', 'name': 'ether10', 'default-name': 'ether10', 'mtu': 1500, 'l
2023-02-14 14:08:14.932 DEBUG (SyncWorker_3) [custom_components.mikrotik_router.mikrotikapi] API query: /interface/ethernet
2023-02-14 14:08:14.932 DEBUG (SyncWorker_3) [custom_components.mikrotik_router.mikrotikapi] API query: /interface/ethernet, monitor, {'.id': '*1', 'once': True}
2023-02-14 14:08:14.944 DEBUG (SyncWorker_3) [custom_components.mikrotik_router.apiparser] Processing source [{'name': 'WAN1', 'status': 'link-ok', 'auto-negotiation': 'done', 'rate':
2023-02-14 14:08:14.944 DEBUG (SyncWorker_3) [custom_components.mikrotik_router.apiparser] Processing entry {'name': 'WAN1', 'status': 'link-ok', 'auto-negotiation': 'done', 'r
2023-02-14 14:08:14.945 DEBUG (SyncWorker_3) [custom_components.mikrotik_router.mikrotikapi] API query: /interface/ethernet
2023-02-14 14:08:14.945 DEBUG (SyncWorker_3) [custom_components.mikrotik_router.mikrotikapi] API query: /interface/ethernet, monitor, {'.id': '*6', 'once': True}
2023-02-14 14:08:14.954 DEBUG (SyncWorker_3) [custom_components.mikrotik_router.apiparser] Processing source [{'name': 'WAN2', 'status': 'no-link', 'auto-negotiation': 'done', 'advert
2023-02-14 14:08:14.954 DEBUG (SyncWorker_3) [custom_components.mikrotik_router.apiparser] Processing entry {'name': 'WAN2', 'status': 'no-link', 'auto-negotiation': 'done', 'adver
2023-02-14 14:08:14.954 DEBUG (SyncWorker_3) [custom_components.mikrotik_router.mikrotikapi] API query: /interface/ethernet
2023-02-14 14:08:14.955 DEBUG (SyncWorker_3) [custom_components.mikrotik_router.mikrotikapi] API query: /interface/ethernet, monitor, {'.id': '*2', 'once': True}
2023-02-14 14:08:14.959 DEBUG (SyncWorker_3) [custom_components.mikrotik_router.apiparser] Processing source [{'name': 'ether2', 'status': 'link-ok', 'auto-negotiation': 'don
2023-02-14 14:08:14.959 DEBUG (SyncWorker_3) [custom_components.mikrotik_router.apiparser] Processing entry {'name': 'ether2', 'status': 'link-ok', 'auto-negotiation': 'do
2023-02-14 14:08:14.959 DEBUG (SyncWorker_3) [custom_components.mikrotik_router.mikrotikapi] API query: /interface/ethernet
2023-02-14 14:08:14.960 DEBUG (SyncWorker_3) [custom_components.mikrotik_router.mikrotikapi] API query: /interface/ethernet, monitor, {'.id': '*3', 'once': True}
2023-02-14 14:08:14.964 DEBUG (SyncWorker_3) [custom_components.mikrotik_router.apiparser] Processing source [{'name': 'ether3', 'status': 'no-link', 'auto-negotiation': 'don
2023-02-14 14:08:14.964 DEBUG (SyncWorker_3) [custom_components.mikrotik_router.apiparser] Processing entry {'name': 'ether3', 'status': 'no-link', 'auto-negotiation': 'don
2023-02-14 14:08:14.964 DEBUG (SyncWorker_3) [custom_components.mikrotik_router.mikrotikapi] API query: /interface/ethernet
2023-02-14 14:08:14.964 DEBUG (SyncWorker_3) [custom_components.mikrotik_router.mikrotikapi] API query: /interface/ethernet, monitor, {'.id': '*4', 'once': True}
2023-02-14 14:08:14.968 DEBUG (SyncWorker_3) [custom_components.mikrotik_router.apiparser] Processing source [{'name': 'ether4', 'status': 'link-ok', 'auto-negotiation':
2023-02-14 14:08:14.969 DEBUG (SyncWorker_3) [custom_components.mikrotik_router.apiparser] Processing entry {'name': 'ether4', 'status': 'link-ok', 'auto-negotiation
2023-02-14 14:08:14.969 DEBUG (SyncWorker_3) [custom_components.mikrotik_router.mikrotikapi] API query: /interface/ethernet
2023-02-14 14:08:14.969 DEBUG (SyncWorker_3) [custom_components.mikrotik_router.mikrotikapi] API query: /interface/ethernet, monitor, {'.id': '*5', 'once': True}
2023-02-14 14:08:14.973 DEBUG (SyncWorker_3) [custom_components.mikrotik_router.apiparser] Processing source [{'name': 'ether5', 'status': 'link-ok', 'auto-negotiation': '
2023-02-14 14:08:14.974 DEBUG (SyncWorker_3) [custom_components.mikrotik_router.apiparser] Processing entry {'name': 'ether5', 'status': 'link-ok', 'auto-negotiation':
2023-02-14 14:08:14.974 DEBUG (SyncWorker_3) [custom_components.mikrotik_router.mikrotikapi] API query: /interface/ethernet
2023-02-14 14:08:14.974 DEBUG (SyncWorker_3) [custom_components.mikrotik_router.mikrotikapi] API query: /interface/ethernet, monitor, {'.id': '*7', 'once': True}
2023-02-14 14:08:14.978 DEBUG (SyncWorker_3) [custom_components.mikrotik_router.apiparser] Processing source [{'name': 'ether6', 'status': 'link-ok', 'auto-negotia
2023-02-14 14:08:14.978 DEBUG (SyncWorker_3) [custom_components.mikrotik_router.apiparser] Processing entry {'name': 'ether6', 'status': 'link-ok', 'auto-negoti
2023-02-14 14:08:14.979 DEBUG (SyncWorker_3) [custom_components.mikrotik_router.mikrotikapi] API query: /interface/ethernet
2023-02-14 14:08:14.979 DEBUG (SyncWorker_3) [custom_components.mikrotik_router.mikrotikapi] API query: /interface/ethernet, monitor, {'.id': '*8', 'once': True}
2023-02-14 14:08:14.982 DEBUG (SyncWorker_3) [custom_components.mikrotik_router.apiparser] Processing source [{'name': 'ether7', 'status': 'no-link',
2023-02-14 14:08:14.983 DEBUG (SyncWorker_3) [custom_components.mikrotik_router.apiparser] Processing entry {'name': 'ether7', 'status': 'no-link', '
2023-02-14 14:08:14.983 DEBUG (SyncWorker_3) [custom_components.mikrotik_router.mikrotikapi] API query: /interface/ethernet
2023-02-14 14:08:14.983 DEBUG (SyncWorker_3) [custom_components.mikrotik_router.mikrotikapi] API query: /interface/ethernet, monitor, {'.id': '*9', 'once': True}
2023-02-14 14:08:14.987 DEBUG (SyncWorker_3) [custom_components.mikrotik_router.apiparser] Processing source [{'name': 'ether8', 'status':
2023-02-14 14:08:14.988 DEBUG (SyncWorker_3) [custom_components.mikrotik_router.apiparser] Processing entry {'name': 'ether8', 'status':
2023-02-14 14:08:14.988 DEBUG (SyncWorker_3) [custom_components.mikrotik_router.mikrotikapi] API query: /interface/ethernet
2023-02-14 14:08:14.988 DEBUG (SyncWorker_3) [custom_components.mikrotik_router.mikrotikapi] API query: /interface/ethernet, monitor, {'.id': '*A', 'once': True}
2023-02-14 14:08:14.992 DEBUG (SyncWorker_3) [custom_components.mikrotik_router.apiparser] Processing source [{'name': 'ether9',
2023-02-14 14:08:14.993 DEBUG (SyncWorker_3) [custom_components.mikrotik_router.apiparser] Processing entry {'name': 'ether9',
2023-02-14 14:08:14.993 DEBUG (SyncWorker_3) [custom_components.mikrotik_router.mikrotikapi] API query: /interface/ethernet
2023-02-14 14:08:14.993 DEBUG (SyncWorker_3) [custom_components.mikrotik_router.mikrotikapi] API query: /interface/ethernet, monitor,
2023-02-14 14:08:14.997 DEBUG (SyncWorker_3) [custom_components.mikrotik_router.apiparser] Processing source [{'name': 'ether10',
2023-02-14 14:08:14.997 DEBUG (SyncWorker_3) [custom_components.mikrotik_router.apiparser] Processing entry {'name': 'ether10',
2023-02-14 14:08:15.000 DEBUG (SyncWorker_3) [custom_components.mikrotik_router.mikrotikapi] API query: /caps-man/regist
2023-02-14 14:08:15.003 DEBUG (SyncWorker_0) [custom_components.mikrotik_router.mikrotikapi] API query: /interface/wireless
2023-02-14 14:08:15.005 DEBUG (SyncWorker_1) [custom_components.mikrotik_router.mikrotikapi] API query: /interface/wirel
2023-02-14 14:08:15.007 DEBUG (SyncWorker_7) [custom_components.mikrotik_router.mikrotikapi] API query: /interface/bridge
