I decided to start afresh with a new installation of the Hass.io release.
It installed uneventfully, however when comparing to the version in Ben’s video, my version is missing the HASS.IO tab in the home assistant home page.
I downloaded the version “resinos-hassio-1.0-raspberrypi3” and followed the instructions.
Is there something I need to activate to get the tab to appear?
You mean there’s no Hass.io menu after a fresh install? Sorry, thought you have already edited the configuration file.
Maybe @pvizeli missed something in the image.
Don’t know if you can access the OS via putty.
I would look on the SD Card (where you wrote the image) for the configuration.yaml and edit it.
On the original image with no changes made is a strange one, as you’d imagine it would be the same image for everybody. Unless something has changed with the image very recently.
If you connect your SD card to a PC and it lets you access the configuration.yaml (never tried it personally) that may be the way to go
Yeah it is definitely a fresh install downloaded from the installation shortcut. I assume the configuration file is the default one.
I will try accessing my SD card directly on my PC. Although last time I plugged in my microSD card, windows was whining that the card needed to be formatted, and the files on the disk were not in the structure I recognised from my previous home assistant file structure.
Right - managed to get access to my home assistant config file via WinSCP.
I tried adding
hassio:
to the config file, but I am unable to get permission to edit this file
I have tried some suggestions in WinSCP (in advanced options under environment>shell changing it to sudo su-), but I stil can’t get permission
Hi! I have Hassbian but I don´t see the “HASSIO” tab in my home assistant, I´ve alredy add the hassio: to the configuration.yaml but still don´t work. How can I fixed it? Hassio is alredy installed with Hassbian or do I need to install it over hassbian?
If you are installing home assistant via ANY other methods than flashing HASSIO to an sd card, then you WILL NOT have a hassio tab. It is that simple. If you installed home assistant manually, or if you installed hassbian, you WILL 100% NOT have a hassio tab, because you are not running hassio.
With HASSIO you literally just flash an sd card and boot it up…if you performed ANY other steps that involved SSH/command line, python, or anything of the sort, you didn’t install HASSIO.
