I should add that I have not connected to my AC yet, as I cannot find my pigtail wires, and it ain’t exactly a priority over keeping staff working (from home) and some money coming in!
so you do not know if you will actually get any data from AC? I have successfully compiled, connected, I can see it in home assistant, I just do not get any data from AC and it also do not responds to my commands.
For cabling I just found some od 2x8 pin similar connecto that was used to connect keyboard to some old electronics and cutted it down to keep only 4 pins.
I apologize in advance, I’m sure this will seem like very basic stuff but I’m struggling. Any advice would be appreciated. I have my Wemos D1 Minis connected to the AC units as per way back in this thread (built out as per the SwiCago/HeatPump README), and I can update them OTA.
I’m running Home Assistant 0.107.7 as a VDI within Virtualbox. I added the https://github.com/esphome/hassio repository to the add-on store, which gives me the ESPHome, ESPHome (beta) and ESPHome (dev) Add-ons, but all three show as release v1.14.3. I understand that this needs the 1.15.0-dev or greater, and presumably the 1.14.3 (dev) won’t do it. Are there steps someone I can follow to install the 1.15.0-dev version?
Because I’m running Home Assistant as a VDI image, and I can get to the command line via a Terminal / SSH add-on, by I suspect that I need console access to run the commands:
I haven’t been able to get console access to work; at the “~ $” prompt I type ‘login’ and then get a “core-ssh login:” prompt. I give it the username ‘root’ and get a ‘Login incorrect’ return. Obviously I’m not doing the right thing here - any advice?
For the YAML configuration, in my configuration.yaml file I’ve included a line “esphome: !include esphome.yaml” and then created an esphome.yaml file in the same directory as my configuration.yaml file. In the esphome.yaml file I have put the ‘Example Configuration’ from Geoff Davis’ page (which I will then tailor). Will this approach work? (see below for what the file starts with…).
I have 5 Mitsubishi units - all been working fine for more than month with
Couple days back I noticed that 1-2 of them got offline without any visible reason.
After some time offline they got back online without any intervention.
I did not use or re-flash them since March.
This morning 3 out of 5 are offline.
Units are working perfectly from remote control and permanently connected to power.
We did not have any power outage at all.
I tried this on my Mitsubishi a couple of weeks ago and it didn’t work well at all… Everything was out of whack and the control/feedback did not work as expected at all… Put things back to the way they were. Will set up a seperate esp just to try this again when I have some time. I think I have some screenshots showing how it presented completely differently under Home Assistant too… I’ll post later.
Has anyone been able to source pigtails (or even the 2mm JST plugs) locally in Australia? Revolectrix now looks to be charging $14+ shipping for the $1.99 item. And the only AU based seller I can find is charging $23 (for a $0.28).
I did - it works great. Was able to work through / learn about all of my issues above, and after flashing my Wemos D1 Mini Pro with something generic the first time round to make sure that OTA was working properly, I then used @nickrout 's yaml file shown above as my template, and everything works fine. Updates on my dashboard about 10 seconds after any input or temperature change.
