Mitsubishi MELCLOUD integration with Home Assistant
good morning, I also have the same problem, I can’t find a way to send the power on/off command to the machine, help
Thank you
I agree, any chance to have the flow temperature implemented? have you resolved it in a different way?
There is no way to do it; what you can do is set a lower target temperature (for example 18°).
I did the integration with melcloud and from time to time this message appears:
023-09-10 00:05:17.211 WARNING (MainThread) [homeassistant.helpers.entity] Update of sensor.ac_sala_room_temperature is taking over 10 seconds
I have 2 air conditioners and the message for both appears.
They are 2 meters from the WiFi router and I have no network problems at home.
Is there any parameter that I can change to make these messages disappear?
Hi all.
I want to use MelCloud or other system to control my Mitsubishi HeatPumps.
I got an Air/Air HeatPump with two splits and one Air/Water with one internal module (ecodan).
In melcloud integration, the Air/Air is well reporting total energy used (for both splits) and the daily consumption (a total on one split for both splits).
But for the Air/Water One, i do not have the energy used or consumption.
In melcloud web, with devlopper tools from firefox or chorme, i got this values:
  1. DailyHeatingEnergyConsumed: 8.04
  2. DailyHeatingEnergyProduced: 29.18
The integration does not seems to work well.
Where do you put your curl command and how do you use it.
I tried in command_line.yaml, but the sensors created report “unknown”.
Maybe we can try with a rest command, but where ?
Kind regards
Hello StreetChat,
I have created some sensors based on the REST interface.
Look at MELCLOUD REST integration example , if it could be of any help.
I have to say, that although, the api polls every 60 sec, not all attributes get updated so often.
It seems that the Ecodan reports only “changing values” and the current energy consume and produce are rounded to integer values.
I hope this is helpful.
many thanks for your help and you work on this.
i tried by adding your code with my values from melcloud in sensors.yaml and rebooted HA.
but i got nothing in HA.
nothing in dev tools/States.
sensors.yam is included in configuration.yaml.
do y miss something ?
Can you paste your code and don’t forget to anonomise your credentials.
Hi @Chrissi28 , how do you create this fancy graph?
of course, here is my sensors.yaml:
- platform: rest
  resource: https://app.melcloud.com/Mitsubishi.Wifi.Client/user/ListDevices?id=88506454&buildingID=660070
  method: GET
  headers:
      X-MitsContextKey: 'XXXXXXXXXXXXXXXXXXXXXX'
  value_template: "OK"
  scan_interval: 60
  force_update: true
  unique_id: "heat_pump_api1"
  json_attributes_path: "$..Devices[?(@.DeviceID==88506454)].Device"
  json_attributes:
    - CurrentEnergyConsumed
    - CurrentEnergyProduced
    - DefrostMode
    - RoomTemperatureZone1
    - RoomTemperatureZone2
    - OutdoorTemperature
    - FlowTemperature
    - FlowTemperatureZone1
    - FlowTemperatureZone2
    - FlowTemperatureBoiler
    - ReturnTemperature
    - ReturnTemperatureZone1
    - ReturnTemperatureZone2
    - ReturnTemperatureBoiler
    - TankWaterTemperature
    - SetTankWaterTemperature
    - MixingTankWaterTemperature
    - TargetHCTemperatureZone1
    - TargetHCTemperatureZone2
    - CondensingTemperature
    - HeatPumpFrequency
    - DailyHeatingEnergyConsumed
    - DailyHotWaterEnergyConsumed
    - DailyHeatingEnergyProduced
    - DailyHotWaterEnergyProduced
    - DailyLegionellaActivationCounter
    - BoilerStatus
    - BoosterHeater1Status
    - BoosterHeater2Status
    - BoosterHeater2PlusStatus
    - ImmersionHeaterStatus
    - WaterPump1Status
    - WaterPump2Status
    - WaterPump3Status
    - ValveStatus3Way
    - ValveStatus2Way
    - WaterPump4Status
    - ValveStatus2Way2a
    - ValveStatus2Way2b
    - ThermostatStatusZone1
    - ThermostatStatusZone2
  sensors:
    heat_pump_currentenergyconsumedpower:
        friendly_name: "CurrentEnergyConsumed"
        # availability_template: "{{ is_state('sensor.heat_pump_api', 'OK') }}"
        availability_template: >-
          {{ (states("sensor.heat_pump_api") not in ["unknown", "unavailable"]) and (state_attr('sensor.heat_pump_api', 'CurrentEnergyConsumed') != None) }}
        value_template: "{{ state_attr('sensor.heat_pump_api', 'CurrentEnergyConsumed') }}"
        device_class: power
        unit_of_measurement: "kW"
        unique_id: "CurrentEnergyConsumed1"
    heat_pump_currentenergyproduced:
        friendly_name: "CurrentEnergyProduced"
          {{ (states("sensor.heat_pump_api") not in ["unknown", "unavailable"]) and (state_attr('sensor.heat_pump_api', 'CurrentEnergyProduced') != None) }}
        value_template: "{{ state_attr('sensor.heat_pump_api', 'CurrentEnergyProduced') }}"
        device_class: power
        unique_id: "CurrentEnergyProduced1"
    heat_pump_dailyheatingenergyconsumed:
      friendly_name: "DailyHeatingEnergyConsumed"
        {{ (states("sensor.heat_pump_api") not in ["unknown", "unavailable"]) and (state_attr('sensor.heat_pump_api', 'DailyHeatingEnergyConsumed') != None) }}
      value_template: "{{ state_attr('sensor.heat_pump_api', 'DailyHeatingEnergyConsumed') }}"
      device_class: energy
      unit_of_measurement: "kWh"
      unique_id: "DailyHeatingEnergyConsumed1"
    heat_pump_dailyhotwaterenergyconsumed:
      friendly_name: "DailyHotWaterEnergyConsumed"
        {{ (states("sensor.heat_pump_api") not in ["unknown", "unavailable"]) and (state_attr('sensor.heat_pump_api', 'DailyHotWaterEnergyConsumed') != None) }}
      value_template: "{{ state_attr('sensor.heat_pump_api', 'DailyHotWaterEnergyConsumed') }}"
      unique_id: "DailyHotWaterEnergyConsumed1"
    heat_pump_dailyheatingenergyproduced:
      friendly_name: "DailyHeatingEnergyProduced"
        {{ (states("sensor.heat_pump_api") not in ["unknown", "unavailable"]) and (state_attr('sensor.heat_pump_api', 'DailyHeatingEnergyProduced') != None) }}
      value_template: "{{ state_attr('sensor.heat_pump_api', 'DailyHeatingEnergyProduced') }}"
      unique_id: "DailyHeatingEnergyProduced1"
    heat_pump_dailyhotwaterenergyproduced:
      friendly_name: "DailyHotWaterEnergyProduced"
        {{ (states("sensor.heat_pump_api") not in ["unknown", "unavailable"]) and (state_attr('sensor.heat_pump_api', 'DailyHotWaterEnergyProduced') != None) }}
      value_template: "{{ state_attr('sensor.heat_pump_api', 'DailyHotWaterEnergyProduced') }}"
      unique_id: "DailyHotWaterEnergyProduced1"
    heat_pump_heatpumpfrequency:
      friendly_name: "HeatPumpFrequency"
        {{ (states("sensor.heat_pump_api") not in ["unknown", "unavailable"]) and (state_attr('sensor.heat_pump_api', 'HeatPumpFrequency') != None) }}
      value_template: "{{ state_attr('sensor.heat_pump_api', 'HeatPumpFrequency') }}"
      device_class: frequency
      unit_of_measurement: "Hz"
      unique_id: "HeatPumpFrequency1"
    heat_pump_defrostmode:
      friendly_name: "DefrostMode"
        {{ (states("sensor.heat_pump_api") not in ["unknown", "unavailable"]) and (state_attr('sensor.heat_pump_api', 'DefrostMode') != None) }}
      value_template: "{{ state_attr('sensor.heat_pump_api', 'DefrostMode') }}"
      device_class: aqi
      unit_of_measurement: ""
      unique_id: "DefrostMode1"
    heat_pump_roomtemperaturezone1:
      friendly_name: "RoomTemperatureZone1"
        {{ (states("sensor.heat_pump_api") not in ["unknown", "unavailable"]) and (state_attr('sensor.heat_pump_api', 'RoomTemperatureZone1') != None) }}
      value_template: "{{ state_attr('sensor.heat_pump_api', 'RoomTemperatureZone1') }}"
      device_class: temperature
      unit_of_measurement: "°C"
      unique_id: "RoomTemperatureZone1_1"
    heat_pump_roomtemperaturezone2:
      friendly_name: "RoomTemperatureZone2"
        {{ (states("sensor.heat_pump_api") not in ["unknown", "unavailable"]) and (state_attr('sensor.heat_pump_api', 'RoomTemperatureZone2') != None) }}
      value_template: "{{ state_attr('sensor.heat_pump_api', 'RoomTemperatureZone2') }}"
      unique_id: "RoomTemperatureZone2_1"
    heat_pump_outdoortemperature:
      friendly_name: "OutdoorTemperature"
        {{ (states("sensor.heat_pump_api") not in ["unknown", "unavailable"]) and (state_attr('sensor.heat_pump_api', 'OutdoorTemperature') != None) }}
      value_template: "{{ state_attr('sensor.heat_pump_api', 'OutdoorTemperature') }}"
      unique_id: "OutdoorTemperature_1"
    heat_pump_flowtemperature:
      friendly_name: "FlowTemperature"
        {{ (states("sensor.heat_pump_api") not in ["unknown", "unavailable"]) and (state_attr('sensor.heat_pump_api', 'FlowTemperature') != None) }}
      value_template: "{{ state_attr('sensor.heat_pump_api', 'FlowTemperature') }}"
      unique_id: "FlowTemperature_1"
    heat_pump_tankwatertemperature:
      friendly_name: "TankWaterTemperature"
        {{ (states("sensor.heat_pump_api") not in ["unknown", "unavailable"]) and (state_attr('sensor.heat_pump_api', 'TankWaterTemperature') != None) }}
      value_template: "{{ state_attr('sensor.heat_pump_api', 'TankWaterTemperature') }}"
      unique_id: "TankWaterTemperature_1"
    heat_pump_mixingtankwatertemperature:
      friendly_name: "MixingTankWaterTemperature"
        {{ (states("sensor.heat_pump_api") not in ["unknown", "unavailable"]) and (state_attr('sensor.heat_pump_api', 'MixingTankWaterTemperature') != None) }}
      value_template: "{{ state_attr('sensor.heat_pump_api', 'MixingTankWaterTemperature') }}"
      unique_id: "MixingTankWaterTemperature_1"
    heat_pump_condensingtemperature:
      friendly_name: "CondensingTemperature"
        {{ (states("sensor.heat_pump_api") not in ["unknown", "unavailable"]) and (state_attr('sensor.heat_pump_api', 'CondensingTemperature') != None) }}
      value_template: "{{ state_attr('sensor.heat_pump_api', 'CondensingTemperature') }}"
      unique_id: "CondensingTemperature_1"
    heat_pump_returntemperature:
      friendly_name: "ReturnTemperature"
        {{ (states("sensor.heat_pump_api") not in ["unknown", "unavailable"]) and (state_attr('sensor.heat_pump_api', 'ReturnTemperature') != None) }}
      value_template: "{{ state_attr('sensor.heat_pump_api', 'ReturnTemperature') }}"
      unique_id: "ReturnTemperature_1"
hi,
i just tried and the same code but in configuration.yaml is working.
it does not work in sensors.yaml.
did you include the
sensor: !include sensors.yaml
Hi @RTJC
I use custom:apexcharts-card from HACS, but I currently have custom:history-explorer-card, because you can zoom with the mouse and move the graph.
Is there any known issue to use both the MelCloud integration and sensors that use the rest API at the same time? As soon as I start to pull data from the rest API my wifi adaptor stops updating tank temperature changes and such to MelCloud, only solution for it is to reboot my wifi-adaptor connected to my Ecodan and turn of my REST-sensors. :frowning: Would really like to pull the Hz data from the API.
Nope I haven’t had problems but I only pull every second hour. The HZ updates very seldom and consumption only once a day.
Hello.
Found this thread adn I’ll try to get it to work.
One question, not directly related, but when I looked in all the settings for my heat pump I found one a bit disturbing. There is a LastLegionellaActivationTime and the time mine was activated is “2022-12-25T01:52:00Z”. I thought that would be once a day. Got a bit worried if something isn’t working correctly. Anyone that can check on their what they have stated there?
Much appreciated, Henke
Anyone having problems with MELcloud integration & REST sensors?
I just installed the utility meter helper and everythng MELcloud related has stopped working. Not sure whether the 2 events are related…
I’m having issues.
Mobile phone app is working fine.
Home assistant integration states “unavailable”
Same for me
Same for me too.
