On my phone there was an update for the Android version of Smart-M-air.
In the updated app there was a firmware update for the Wifi modules.
Installed it 22 hours ago. WF-RAC module has been connected for 22 hours, no more hourly disconnects (so far)
complex1
(Frank)
November 17, 2023, 9:31pm
163
I can confirm that after the firmware upgrade to version 131 of the built-in WiFi modules, there are no more hourly disconnects.
loovanloon
(Ton van Loon)
November 22, 2023, 11:37pm
164
@rubenejbr How did you change the name of the Airco device? Mine named 4 digits of its MAC address and I canāt find an option to change it in the smart air app
Cees_2023
(Cees)
November 23, 2023, 10:36am
165
That would be so great. I tried āBetter Thermostatā in combination with your hack. My plan is to use a separate temperature sensor so that can control my AC behaviour
Unfortunately āBetter Thermostatā did not work with the Mitsubishi Wifi Module WF-RAC devices.
complex1
(Frank)
November 23, 2023, 3:04pm
166
Iām not @rubenejbr , but I will answer your question.
If you want to change the name of the air conditioner displayed in the app, tap āDetailsā to display the detailed air conditioner window.
Hold the air conditioner name (1 second). The āEdit air conditioner nameā dialog box opens. Here you can change the name.
Cees_2023
(Cees)
December 8, 2023, 2:10pm
167
I tried the Better Thermostat too. But were not able to heat it cook the MHI acās. Are you still using the Better Thermostat?
RogerNL
December 11, 2023, 1:34pm
168
Yes I am. Not used the AC much lately, I guess something to further investigate when outside temperatures go up again.
JohanS12
(Johan S12)
December 31, 2023, 2:12pm
169
Hi all,
I plan to create an automation to set the target temperature. What is the sensor of this itegration where save the wanted target temperature?
complex1
(Frank)
December 31, 2023, 3:47pm
170
Maybe something like this?
- service: climate.set_temperature
temperature: '{{ temperature }}'
hvac_mode: '{{ hvac_mode }}'
entity_id: 'climate.{{ unit_name }}'
Is it posible to change the Fan Mode when a target has been reached?
complex1
(Frank)
January 1, 2024, 11:42am
172
Do you mean the Fan speed or the (Hor/Vert) Swing mode?
Both can be changed.
Nice, can you telll me how?
complex1
(Frank)
January 1, 2024, 1:27pm
174
Does this help you?
# Fan speed
- service: climate.set_fan_mode
fan_mode: '{{ fan_mode }}'
# Vertical swing direction
- service: climate.set_swing_mode
swing_mode: '{{ ver_swing }}'
# Horizontal swing direction
- service: select.select_option
option: '{{ hor_swing }}'
entity_id: 'select.{{ unit_name }}_horizontal_swing_direction'
I now have this and does not work:
alias: Test airco fan
description: āā
platform: time
at: ā11:52:00ā
condition:
condition: device
device_id: 4f13dce548f87e50d49936f9efc6c7fb
domain: climate
entity_id: e8d45bbeccc144421527966c4f12e14b
type: is_hvac_mode
hvac_mode: heat
domain: climate
type: set_hvac_mode
hvac_mode: āoffā
enabled: false
fan_mode: Low
mode: single
Kai-18
January 4, 2024, 11:46am
176
Here below is the code⦠Iāve as well added a dropdown list to select the horizontal swing mode
type: custom:stack-in-card
mode: vertical
cards:
- type: custom:simple-thermostat
entity: climate.airco_rdc
layout:
mode:
names: true
icons: true
headings: false
footer: true
step: row
sensors:
- entity: sensor.airco_rdc_outdoor
icon: mdi:thermometer
- entity: sensor.airco_rdc_energy_usage_cycle
icon: mdi:lightning-bolt
control:
preset: true
fan:
auto:
icon: mdi:fan-auto
1 Lowest:
icon: mdi:fan
2 Low:
icon: mdi:fan-speed-1
3 High:
icon: mdi:fan-speed-2
4 Highest:
icon: mdi:fan-speed-3
swing:
Up/Down Auto:
icon: mdi:swap-vertical-variant
Highest:
icon: mdi:arrow-top-right
Middle:
icon: mdi:arrow-right
Normal:
icon: mdi:arrow-bottom-right
Lowest:
icon: mdi:arrow-down
3D Auto:
icon: mdi:rotate-3d
hvac:
'off':
icon: mdi:power
heat:
icon: mdi:fire
cool:
icon: mdi:snowflake
auto:
icon: mdi:autorenew
dry:
icon: mdi:water-percent
fan_only:
icon: mdi:fan
style: |
ha-card {
--st-font-size-xl: 60px;
--st-font-size-m: 30px;
--st-font-size-title: 20px;
--st-font-size-sensors: 20px;
--st-spacing: 3px;
--st-fault-active-color: green;
border: none;
- type: entities
entities:
- entity: select.airco_rdc_horizontal_swing_direction
name: 'Oscillation Horizontale:'
style: |
ha-card {
border: none;
Kai-18
January 4, 2024, 11:51am
177
You can control all with the code Iāve shared above and with the āSimple Thermostatā Card (including vertical swing mode). Horizontal swing is a bit different since itās a drop down list. Thererfore you have to put the āSimple Thermostatā card and this dropdown list into a vertcal stack in card.
FYI, the last 2024.01 HA update brings a new feature to the āThermostat Cardā. It is now possible to add the fan mode to the card. But vertical swing mode is still not there.
Hi, can you tell how to install on HA?
I would like to connect my SRK35ZS-WF to HA.
Whatās the procedure? Whatās the file I have to include in HA?
Tx in advance.
SanderKo85
(Sander Koorneef)
January 15, 2024, 10:06pm
179
jainpankaj
(Pankaj Jain)
March 10, 2024, 7:52pm
180
Hi
I am trying to login to the Smart M Air app but I am unable to login. When I enter the username and password, it says:
"A communication error has occurred, Do you want to try again? [04215-900]
I am on iPhone IODS 17.3.1
I tried on Android 9 too. It throws the same error. Would I be able to add the wifi adapters to HA without the Smart M Air app.
JohanS12
(Johan S12)
March 10, 2024, 8:06pm
181
Iām facing the same problem. Maybe there are problems with the server.
