crlogic
August 9, 2022, 12:28pm
385
You mean this!!?
text_sensor:
icon: mdi:clock-start
update_interval: 60s
On my computer of course! Dunno where that bit went when copy/paste. It isn’t required for the sensor in any way.
Likely have an update tomorrow with additional configuration parameter synchronization once I have a good day under my belt…
Chipsa
(Chipsa)
August 9, 2022, 12:41pm
386
Hi, so with the proposed orientation (GPIO pins on the bottom, 3pads up, 2 pads wide) the 100° are horizontal and 40° vertical? thanks for clearing this up
skycryer
(Skycryer)
August 9, 2022, 12:51pm
387
So I adapted the config from top to my because I attached some other sensor too. Like PIR, temp and others. The mmWave sensor detects if someone is there, great. But I can not make the configuration work. SO I can change sensitivity, distance, led but nothing changes. When clicking the buttons for get range, get latency they show nothing. As far as I understood they should show the saved values, right?
Can someone check my config if I missed something? The config runs without other problems, only while compiling I get a warning about “$JYRPO”.
Also num_targets stays at 0.0 even if move sensor goes to “on” because someone was detects. Same for target distance.
Here is my code
substitutions:
device_name: workingroom
esphome:
platform: ESP32
board: esp32dev
includes:
- uart_read_line_sensor.h # https://esphome.io/cookbook/uart_text_sensor.html
# Enable logging
logger:
logs:
text_sensor: INFO
sensor: INFO
# Enable Home Assistant API
api:
services:
# Service to send a command directly to the display. Useful for testing
- service: send_command
variables:
cmd: string
then:
- uart.write: !lambda
std::string command = to_string(cmd) +"\r";
return std::vector<uint8_t>(command.begin(), command.end());
http_request:
useragent: esphome/${device_name}
timeout: 2s
ota:
password: "xxxxxxxxxxxxxxxxxxxxxxxx"
wifi:
ssid: !secret wifi_ssid
ap:
ssid: "${device_name}-Multisensor"
captive_portal:
web_server:
port: 80
version: 2
include_internal: true
ota: true
uart:
tx_pin: GPIO19
rx_pin: GPIO18
baud_rate: 115200
debug:
direction: BOTH
after:
delimiter: "\n"
sequence:
- lambda: UARTDebug::log_string(direction, bytes);
i2c:
sda: GPIO21
scl: GPIO22
scan: true
- platform: bme280
temperature:
name: "${device_name} Temperature"
oversampling: 16x
pressure:
name: "${device_name} Pressure"
humidity:
name: "${device_name} Humidity"
address: 0x76
- platform: bh1750
name: "${device_name} Illuminance"
address: 0x23
update_interval: 1s
filters:
- or:
- throttle: 10s
- delta: 1.0
internal: true
internal: true
internal: true
internal: true
internal: true
internal: true
internal: true
internal: true
# internal: true
binary_sensor:
- platform: gpio
pin: GPIO23
filters:
- delayed_on: 100ms
- delayed_off: 2000ms
name: "${device_name} PIR Sensor"
device_class: motion
- platform: gpio
pin:
number: GPIO23
mode: INPUT_PULLDOWN
on_state:
- if:
condition:
- binary_sensor.is_off: mmwave_in_${device_name}
then:
- sensor.template.publish:
state: 0.0
state: 0.0
state: 0.0
switch:
- platform: safe_mode
entity_category: diagnostic
entity_category: config
optimistic: true
restore_state: true
assumed_state: true
turn_on_action:
- uart.write: "sensorStart"
turn_off_action:
- uart.write: "sensorStop"
optimistic: true
restore_state: true
assumed_state: true
turn_on_action:
- switch.turn_off: mmwave_sensor
- delay: 1s
- uart.write: "setLedMode 1 0"
- delay: 1s
- uart.write: "saveConfig"
- delay: 3s
- switch.turn_on: mmwave_sensor
- delay: 1s
turn_off_action:
- delay: 1s
- uart.write: "setLedMode 1 1"
- delay: 1s
- delay: 3s
- delay: 1s
optimistic: true
restore_state: true
assumed_state: true
turn_on_action:
- delay: 1s
- uart.write: "setUartOutput 1 1"
- delay: 1s
- delay: 3s
- delay: 1s
turn_off_action:
- delay: 1s
- uart.write: "setUartOutput 1 0"
- delay: 1s
- delay: 3s
- delay: 1s
optimistic: true
restore_state: true
assumed_state: false
turn_on_action:
- delay: 1s
- delay: 1s
- uart.write: "setUartOutput 2 1 1 3"
- delay: 1s
- delay: 3s
- delay: 1s
turn_off_action:
- delay: 1s
- uart.write: "setUartOutput 2 0"
- delay: 1s
- delay: 3s
- delay: 1s
number:
min_value: 0.15
max_value: 9.45
initial_value: 3.15
optimistic: true
step: 0.15
restore_value: true
unit_of_measurement: M
mode: box
set_action:
- delay: 1s
std::string range = "setRange 0 " + str_sprintf("%.2f", x);
return std::vector<unsigned char>(range.begin(), range.end());
- delay: 1s
- delay: 1s
- delay: 1s
min_value: 1
max_value: 600
initial_value: 90
optimistic: true
step: 1
restore_value: true
unit_of_measurement: s
mode: box
set_action:
- delay: 1s
std::string setL = "setLatency 0.1 " + str_sprintf("%.0f", x);
return std::vector<unsigned char>(setL.begin(), setL.end());
- delay: 1s
- delay: 1s
min_value: 0
max_value: 9
initial_value: 9
optimistic: true
step: 1
restore_value: true
set_action:
- delay: 1s
std::string mss = "setSensitivity " + to_string((int)x);
return std::vector<unsigned char>(mss.begin(), mss.end());
- delay: 1s
- delay: 1s
button:
- platform: restart
name: Restart $device_name
internal: true
on_press:
std::string getS = "getSensitivity";
return std::vector<unsigned char>(getS.begin(), getS.end());
internal: true
on_press:
std::string getL = "getLatency";
return std::vector<unsigned char>(getL.begin(), getL.end());
internal: true
on_press:
std::string getR = "getRange";
return std::vector<unsigned char>(getR.begin(), getR.end());
on_press:
- delay: 1s
- uart.write: "resetCfg"
- delay: 3s
text_sensor:
- platform: custom
lambda: |-
auto my_custom_sensor = new UartReadLineSensor(id(uart_bus));
App.register_component(my_custom_sensor);
return {my_custom_sensor};
text_sensors:
internal: true
on_value:
lambda: |-
std::string line = id(uart_readline).state;
if (id(uart_target_output).state && line.substr(0, 6) == "$JYRPO")
auto publishTarget = [](std::string idx, float dist, float snr) {
auto sens = App.get_sensors();
for(int i = 0; i < sens.size(); i++) {
auto name = sens[i]->get_name();
auto target = "target_" + to_string(idx);
if(name.size() > 10 && name.substr(0, 8) == target) {
if(name.substr(9, 3) == "dis") {
sens[i]->publish_state(dist);
} else if(name.substr(9, 3) == "SNR") {
sens[i]->publish_state(snr);
line = line.substr(6);
std::vector<std::string> v;
for(int i = 0; i < line.length(); i++) {
if(line[i] == ',') {
v.push_back("");
} else {
v.back() += line[i];
id(num_targets).publish_state(parse_number<float>(v[0]).value());
publishTarget(v[1], parse_number<float>(v[2]).value(), parse_number<float>(v[4]).value());
for(int i = parse_number<int>(v[0]).value() +1 ; i < 9; i++) publishTarget(to_string(i), 0, 0);
crlogic
August 9, 2022, 12:57pm
388
Checked your RX/TX. Turn on uart_target_output
, do you see output on the logs?
Sounds like your RX/TX are not correct. You will see a response in the logs.
All symptoms points to incorrect RX/TX.
skycryer
(Skycryer)
August 9, 2022, 1:01pm
389
The RX/TX can be just free GPIO Pins correct? Or do I need to use the TX/RX on my board? Because I only got it working when the TX/RX are from free GPIO Pins
The answer may depend on the specifics of your board…
So all good now?
skycryer
(Skycryer)
August 9, 2022, 2:30pm
391
No, it is still the same, not sure what GPIO Ports I should use for the TX/RX. Does it have to be the designated from board or can I use free GPIO Pins?
I have this esp32dev board. I only got the mmWave sensor working when I use free gpis pins but then the config, buttons, target data does not show up. Any hint what ports are the correct ones?
And I only use the “102” port on the mmWave sensor to connect to my esp32. Do I need the other too? I saw nowhere that both GPIO are configured.
hjmcnew
(Herb McNew)
August 9, 2022, 3:50pm
392
IO2 on the mmWave sensor is purely binary. It goes high if it senses motion and low when it stops. In order to read/change the configuration on the sensor you also need to connect TX/RX to UART TX/RX on the ESP32. Depending on the board you can use other GPIOs for UART TX/RX, but generally I use pins labeled TX/RX if they’re there.
skycryer
(Skycryer)
August 9, 2022, 4:43pm
393
Hope this pictures make it more clear, I use tx/rx pins and also tried the other tx/rx on the board same for just on 25/26 as tx/rx. But the buttons never return values. Config (distance/sensitivity) does not change and also the num_targets or target_1_xxx show no values.
The part_readline is mostly empty, I had it between that it show the number 1 but nothing more.
Swapped out a DFRobot (aka HS2A43A 100×40) for a HS2BC3A (1x0×1x0) today and all working as expected
The datasheet says 110x120 but Ali seller notes 100x100 so testing is in order…
TX goes to RX and vice versa
skycryer
(Skycryer)
August 9, 2022, 6:09pm
396
Wait what? so tx from mmWave should be Rx on esp?
Noob mistake, don’t feel bad… I ended up buying a USB to TTL because I was doing my connections wrong with my ESP
liminal
(Shane)
August 10, 2022, 11:56am
399
So just got my DFRobot sensor and going to solder this up this weekend.
Am I missing something, someone mentioned a wiring diagram that was in the OP, but I cant see it. And people talking about putting this on Github.
Has that happened and I missed it? Is the OP the best YAML to grab? Wiring diagram?
Also hooked up an Acura FP1 this week, that thing is so sensitive that it thinks my Echo Show playing music is enough movement to constitute occupancy LOL
crlogic
August 11, 2022, 10:08pm
400
A big shout-out to @hjmcnew for providing us with a simplied installation method (in the OP).
S3D
(dES)
August 14, 2022, 8:25am
401
Hi there.
I have set the latency to 1sec. but it turn off in 10sec. How can i change it to turn off immediately?
crlogic
August 15, 2022, 12:45am
402
Reduce the latency.
Check your UART wiring/configuration. Correct UART communication is required for distance/latency/sensitivity/LED changes.
S3D
(dES)
August 15, 2022, 7:14am
403
The latency i have changed to 1 sec and the UART is working. I can change the LED on/off. But it turns off in 4-6 seconds. Well I saw in the video of Everything Smart Home that it turn off immediately.
Thnx crlogic
crlogic
August 15, 2022, 11:44am
404
LED turning on/off confirms UART so that’s good.
The problem sounds like a difference between you deciding when you think motion stopped and the sensor actually no longer detects motion.
Latency only controls the time after the time when the sensor stops detecting motion.
