boydo
(Richard Boyd)
March 24, 2021, 2:04pm
1
Hi All,
I am currently working on a community energy project and trying to integrate the Solis inverter via direct modbus connection RTU, not over TCP.
In discussions with the manufacture it would appear that I need to be sending modbus commands using different modbus function codes not just the standard ones specified in the doc below.
Modbus - Home Assistant (home-assistant.io)
Would some genus be able to update the modbus integration to allow for the specifying of the function code?
Thanks,
Richard.
via2326
(Nico)
May 12, 2021, 6:14pm
2
Yes please, got the same issue with some Chinese modbus RTU’s
what code do you need to send to modbus rtu?
Modbus is a data communications protocol originally published by Modicon (now Schneider Electric) in 1979 for use with its programmable logic controllers (PLCs). Modbus has become a de facto standard communication protocol and is now a commonly available means of connecting industrial electronic devices.
Modbus is popular in industrial environments because it is openly published and royalty-free. It was developed for industrial applications, is relatively easy to deploy and maintain compared to ...
example:
read code function 1 = coil,
switches:
- name: switch1
slave: 1
address: 128
- name: switch2
slave: 1
address: 129
if you need custom preference, you can use cover and device_class
or maybe you need HMI ( Human Machine Interface ) or SCADA
weilhexe
(Susanne)
August 4, 2023, 10:25am
4
Modbus TCP has Format
Slave ID; Function Code; Adress, num of coils
so function code is a must have
slave: 1
Function: 2
address: 1002
coils: 5
that is the goal
Data send to ip: 01 02 03 ea 00 05
see About Modbus TCP | Simply Modbus Software
