I just adapted the new modbus config style before I updated to 2021.7.1.
Configuration passes the checks, but all sensors are unavailable.
Here is the config:
Hi All
I have the same challenge, after 2021.7 I have lost connection to my modbus devices …
have corrected according to the new instructions … I use serial (rs485) via USB …
Same here. Out of three identical SMA solar inverters, set up identically with HA, one (not always the same one) stops receiving data after a few hours. Since update to 2021.7. Other setups with OpenHAB working without any problems. Seems mdobus in HA is broken now somehow.
Any ideas?
I did switch over to the SMA integration now. Did not before since early on there was only one instance of the SMA integration allowed. Modbus was the trick to get the other ones in…
