Modbus of extrnal device no longer working!
after Update from rel 2021.5.4 to 2021.7 modbus ends with error!
my configuration.yaml:
modbus:
type: tcp
host: 192.168.0.14
port: 502
sensors:
unit_of_measurement: W
slave: 1
address: 1066
count: 1
address: 1067
‘and some more’
values are ‘unavalaible’ with error message:
Logger: homeassistant.components.modbus.modbus
Source: components/modbus/modbus.py:237
Integration: Modbus (documentation, issues)
First occurred: 19:30:16 (1 occurrences)
Last logged: 19:30:16
Pymodbus: Exception Response(131, 3, IllegalAddress)
However:
modbus of another device is working without errors!
what is wrong?
tom_l
July 9, 2021, 6:24am
2
Please format your pasted configuration correctly. See point 11 here .
modbus:
- name: varta
type: tcp
host:192.168.0.14
port: 502
sensors:
- name: 'Wirkleistung'
slave: 1
address: 1066
count:1
type error in last reply!
correct:
modbus:
- name: varta
type: tcp
host: 192.168.0.14
port: 502
sensors:
slave: 1
address: 1066
count: 1
- name: 'Scheinleistung'
address: 1067
Hi all,
same here, Modbus TCP stopped after latest update.
Second playground system with old SW still catches data.
Please let us know how to get it back.
Mike
FXS
(Nigel)
July 9, 2021, 11:30am
6
My Modbus “serial” connection has also stopped working in 2021.7 and 2021.7.1. I believe that I am using the latest/correct syntax. The Modbus “tcp” connections are working fine.
My error is: Pymodbus: Exception Response(131, 3, GatewayPathUnavailable)
The problematic section in my modbus.yaml file is shown below:
# The following line is in the configuration.yaml file, so *not* repeated below
# modbus:
- name: "em24"
close_comm_on_error: true
type: serial
method: rtu
# port: /dev/ttyUSB1
port: /dev/serial/by-id/usb-FTDI_FT232R_USB_UART_AK08M9Q7-if00-port0
baudrate: 9600
stopbits: 1
bytesize: 8
parity: N
timeout: 2
sensors:
- name: "Total Imported Energy"
scan_interval: 30
unit_of_measurement: "kWh"
count: 2 # INT32/double-word value (otherwise values > 3276.7kWh go negative)
swap: word # EM24 uses reverse word order
scale: 0.1
slave: 1
address: 62
precision: 1
Note that I have tried both the “serial-by-id” and “/dev/ttyUSB1” options for the port, without success.
The problem goes away if I revert back to 2021.6.
chris-kuhr
(Christoph Kuhr)
July 9, 2021, 12:30pm
7
Related issue here Unavailable Sensors
niraviry
(Nir Aviry)
July 10, 2021, 11:55am
8
Same here. All devices (sensors, coils etc.) are no working. Checked the latest documentation which shows no change in syntax.
I have the same problem. After update to 2021.7.1 modbus no longer works. I have three devices running via modbus. All three interfaces are broken. An SDM630 electricity meter, a Corrigo ventilation unit and a Dimplex heat pump system. Pretty stupid, since all the important automatisms in the house are no longer running.
Someone knows what happened?
iway
(Chris)
July 10, 2021, 8:06pm
10
Same here. Out of three identical SMA solar inverters, set up identically with HA, one (not always the same one) stops receiving data after a few hours. Since update to 2021.7. Other setups with OpenHAB working without any problems. Seems mdobus in HA is broken now somehow.
dknt
(dknt)
July 11, 2021, 7:05pm
11
Looks like modbus integration now stops on error.
Try adding this to modbus config:
retry_on_empty: true
retries: 10
niraviry
(Nir Aviry)
July 12, 2021, 4:47am
12
I have downgraded to version 2021.6.6 and now the registers reading are OK but the coil writing is still faulty. I did not check @dknt recommendation yet.
BTW, I have 7 different TCP Modbus units, some are Advantech, some are King Pigeon and some are USR.
All act the same.
Correction - After fixing the code to the new syntax, all is working under 2021.6.6.
No change with adding the 2 lines. Same error:
Same issue on my Setup after upgrading to 2021.7.1.
Modbus-TCP to Wallbox (Wallbe Eco 2s) → still working
Modbus-TCP to Energy-Meter (Siemens PAC2200) → still working
Modbus-TCP to Li-Ion Battery / Inverter (E3DC S10) → not working
# MODBUS Start
modbus:
# E3DC S10
- name: E3DC
type: tcp
host: 192.168.85.55
port: 502
retries: 10
sensors:
- name: PV-Leistung
slave: 1
address: 66
count: 2
data_type: int
device_class: power
- name: hausverbrauch
slave: 1
address: 70
count: 2
data_type: int
device_class: power
- name: netzbezug
slave: 1
address: 72
count: 2
data_type: int
device_class: power
- name: batterieleistung
slave: 1
address: 68
count: 2
data_type: int
device_class: battery
- name: SoC
slave: 1
address: 82
unit_of_measurement: '%'
data_type: int
- name: NEA-Status
slave: 1
address: 83
data_type: int
- name: ems-status
slave: 1
address: 84
data_type: int
# PAC2200 Wallbox Carport
- name: pac2200_carport
type: tcp
host: 192.168.85.93
port: 502
sensors:
- name: pac2200_carport_spannungL1
input_type: holding
slave: 1
address: 1
unit_of_measurement: V
count: 2
data_type: float
- name: pac2200_carport_spannungL2
input_type: holding
slave: 1
address: 3
count: 2
data_type: float
- name: pac2200_carport_spannungL3
input_type: holding
slave: 1
address: 5
count: 2
data_type: float
- name: pac2200_carport_stromL1
input_type: holding
slave: 1
address: 13
unit_of_measurement: A
count: 2
data_type: float
- name: pac2200_carport_stromL2
input_type: holding
slave: 1
address: 15
count: 2
data_type: float
- name: pac2200_carport_stromL3
input_type: holding
slave: 1
address: 17
count: 2
data_type: float
- name: pac2200_carport_frequenz
input_type: holding
slave: 1
address: 55
unit_of_measurement: Hz
count: 2
data_type: float
- name: pac2200_carport_wirkleistung
input_type: holding
slave: 1
address: 65
count: 2
data_type: float
- name: pac2200_carport_wirkarbeit
input_type: holding
slave: 1
address: 801
unit_of_measurement: Wh
count: 4
data_type: float
# Modbus ENDE
FXS
(Nigel)
July 12, 2021, 8:55am
15
I have enabled the debug logs - which show the following errors:
2021-07-12 10:31:34 ERROR (SyncWorker_5) [homeassistant.components.modbus.modbus] Pymodbus: Exception Response(131, 3, GatewayPathUnavailable)
2021-07-12 10:31:34 DEBUG (SyncWorker_4) [pymodbus.client.sync] New Transaction state 'SENDING'
2021-07-12 10:31:34 DEBUG (SyncWorker_0) [pymodbus.client.sync] New Transaction state 'SENDING'
2021-07-12 10:31:34 DEBUG (SyncWorker_1) [pymodbus.client.sync] New Transaction state 'SENDING'
2021-07-12 10:31:34 DEBUG (SyncWorker_4) [homeassistant.components.modbus.modbus] Pymodbus: Exception Response(131, 3, GatewayPathUnavailable)
2021-07-12 10:31:34 DEBUG (SyncWorker_3) [pymodbus.client.sync] New Transaction state 'SENDING'
2021-07-12 10:31:34 DEBUG (SyncWorker_5) [pymodbus.client.sync] New Transaction state 'SENDING'
2021-07-12 10:31:35 DEBUG (SyncWorker_0) [homeassistant.components.modbus.modbus] Pymodbus: Exception Response(131, 3, GatewayPathUnavailable)
2021-07-12 10:31:44 DEBUG (SyncWorker_0) [pymodbus.client.sync] New Transaction state 'SENDING'
2021-07-12 10:31:44 DEBUG (SyncWorker_0) [homeassistant.components.modbus.modbus] Pymodbus: Exception Response(131, 3, GatewayPathUnavailable)
2021-07-12 10:31:44 DEBUG (SyncWorker_4) [pymodbus.client.sync] New Transaction state 'SENDING'
2021-07-12 10:31:44 DEBUG (SyncWorker_2) [pymodbus.client.sync] New Transaction state 'SENDING'
2021-07-12 10:31:44 DEBUG (SyncWorker_1) [pymodbus.client.sync] New Transaction state 'SENDING'
2021-07-12 10:31:44 DEBUG (SyncWorker_5) [pymodbus.client.sync] New Transaction state 'SENDING'
2021-07-12 10:31:44 DEBUG (SyncWorker_3) [pymodbus.client.sync] New Transaction state 'SENDING'
2021-07-12 10:31:44 DEBUG (SyncWorker_3) [homeassistant.components.modbus.modbus] Pymodbus: Exception Response(131, 3, GatewayPathUnavailable)
2021-07-12 10:31:45 DEBUG (SyncWorker_2) [pymodbus.client.sync] New Transaction state 'SENDING'
2021-07-12 10:31:45 DEBUG (SyncWorker_2) [homeassistant.components.modbus.modbus] Pymodbus: Exception Response(131, 3, GatewayPathUnavailable)
2021-07-12 10:31:54 DEBUG (SyncWorker_2) [pymodbus.client.sync] New Transaction state 'SENDING'
2021-07-12 10:31:54 DEBUG (SyncWorker_2) [homeassistant.components.modbus.modbus] Pymodbus: Exception Response(131, 3, GatewayPathUnavailable)
2021-07-12 10:31:54 DEBUG (SyncWorker_1) [pymodbus.client.sync] New Transaction state 'SENDING'
2021-07-12 10:31:54 DEBUG (SyncWorker_0) [pymodbus.client.sync] New Transaction state 'SENDING'
2021-07-12 10:31:54 DEBUG (SyncWorker_4) [pymodbus.client.sync] New Transaction state 'SENDING'
2021-07-12 10:31:55 DEBUG (SyncWorker_2) [homeassistant.components.modbus.modbus] Pymodbus: Exception Response(131, 3, IllegalAddress)
2021-07-12 10:31:55 DEBUG (SyncWorker_3) [pymodbus.client.sync] New Transaction state 'SENDING'
2021-07-12 10:31:55 DEBUG (SyncWorker_5) [pymodbus.client.sync] New Transaction state 'SENDING'
2021-07-12 10:31:55 DEBUG (SyncWorker_4) [pymodbus.client.sync] New Transaction state 'SENDING'
2021-07-12 10:31:55 DEBUG (SyncWorker_2) [pymodbus.client.sync] New Transaction state 'SENDING'
2021-07-12 10:31:55 DEBUG (SyncWorker_1) [pymodbus.client.sync] New Transaction state 'SENDING'
2021-07-12 10:31:55 DEBUG (SyncWorker_0) [pymodbus.client.sync] New Transaction state 'SENDING'
2021-07-12 10:31:55 DEBUG (SyncWorker_5) [homeassistant.components.modbus.modbus] Pymodbus: Exception Response(131, 3, IllegalAddress)
2021-07-12 10:31:55 DEBUG (SyncWorker_4) [homeassistant.components.modbus.modbus] Pymodbus: Exception Response(131, 3, GatewayPathUnavailable)
2021-07-12 10:31:55 DEBUG (SyncWorker_0) [homeassistant.components.modbus.modbus] Pymodbus: Exception Response(131, 3, IllegalAddress)
2021-07-12 10:31:55 DEBUG (SyncWorker_3) [homeassistant.components.modbus.modbus] Pymodbus: Exception Response(131, 3, IllegalAddress)
2021-07-12 10:31:55 DEBUG (SyncWorker_2) [homeassistant.components.modbus.modbus] Pymodbus: Exception Response(131, 3, GatewayPathUnavailable)
2021-07-12 10:31:55 DEBUG (SyncWorker_1) [homeassistant.components.modbus.modbus] Pymodbus: Exception Response(131, 3, GatewayPathUnavailable)
2021-07-12 10:31:55 DEBUG (SyncWorker_5) [homeassistant.components.modbus.modbus] Pymodbus: Exception Response(131, 3, GatewayPathUnavailable)
Same here, i downgraded to 2021.6.6 for the time beeing.
i had hoped to get a full month of reliabel data on my solar gain and solar battery performance… maybe in august then…
this upgrade also seems to have messed with automations… my inverter turned on 9,5h early which ran down the battery while charging at the same time… i exported more energy than i am allowed, so i guess i will get to hear from my utility next time they look at my energymeter
Upgrade to “Home Assistant 2021.7.2” did not fix the issue.
The same for me.
I have 5 PLC’s that use Modbus IP and a heat recovery unit that uses Modbus RTU.
Both protocols no longer work since update 2021.7.1 so for now I will stay on 2021.6.6
I’ve got it running, using this parameters on each Modbus Hub:
delay: 5
close_comm_on_error: false
retries: 10
Solved it for me!
Didn’t worked for long. At least now i become old frozen values instead of Zeros…
FXS
(Nigel)
July 16, 2021, 11:02am
20
My issue has been fixed in 2021.7.3
