Hi all!!
Im doing a project to read the information of my seplos BMS with a ESP32 and RS485 converter, and I have some problems and Im blocked for now (Im new with esphome).
I review all connection and the are ok, Im sure because i had connected the cable to the usb converter and works fine with the laptop and the battery monitor.
For now I received some information in the log, but honestly I not really sure if Im doing well and what I need for read and give format to the data.
this my script:
substitutions:
device_name: battery
esphome:
platformio_options:
platform: https://github.com/platformio/platform-espressif32.git#feature/arduino-upstream
platform_packages:
- framework-arduinoespressif32 @ https://github.com/espressif/arduino-esp32.git#2.0.0
build_flags:
- -DCONFIG_ARDUINO_LOOP_STACK_SIZE=32768
esp32:
board: nodemcu-32s
framework:
type: arduino
version: 2.0.0
# Enable logging
logger:
level: DEBUG
# Enable Home Assistant API
api:
# encryption:
ota:
password: "xxxxxx"
wifi:
ssid: !secret wifi_ssid
ap:
ssid: "Battery Fallback Hotspot"
password: "xxxxxxx"
captive_portal:
web_server:
port: 80
uart:
tx_pin: GPIO17
rx_pin: GPIO16
baud_rate: 19200
stop_bits: 1
data_bits: 8
parity: NONE
rx_buffer_size: 384
debug:
dummy_receiver: false
direction: BOTH
after:
delimiter: "\r"
sequence:
- lambda: UARTDebug::log_string(direction, bytes);
modbus:
uart_id: mod_bus
send_wait_time: 500ms
modbus_controller:
- id: epever
address: 0
modbus_id: modbus1
setup_priority: -10
update_interval: 10s
- platform: wifi_signal
update_interval: 3600s
and I received in the log the next warning:
[22:05:43][C][logger:293]: Logger:
[22:05:43][C][logger:294]: Level: DEBUG
[22:05:43][C][logger:295]: Log Baud Rate: 115200
[22:05:43][C][logger:296]: Hardware UART: UART0
[22:05:43][C][uart.arduino_esp32:108]: UART Bus 1:
[22:05:43][C][uart.arduino_esp32:109]: TX Pin: GPIO17
[22:05:43][C][uart.arduino_esp32:110]: RX Pin: GPIO16
[22:05:43][C][uart.arduino_esp32:112]: RX Buffer Size: 384
[22:05:43][C][uart.arduino_esp32:114]: Baud Rate: 19200 baud
[22:05:43][C][uart.arduino_esp32:115]: Data Bits: 8
[22:05:43][C][uart.arduino_esp32:116]: Parity: NONE
[22:05:43][C][uart.arduino_esp32:117]: Stop bits: 1
[22:05:43][C][modbus:139]: Modbus:
[22:05:43][C][modbus:141]: Send Wait Time: 500 ms
[22:05:44][C][captive_portal:088]: Captive Portal:
[22:05:44][C][web_server:125]: Web Server:
[22:05:44][C][web_server:126]: Address: battery.local:80
[22:05:44][C][mdns:103]: mDNS:
[22:05:44][C][mdns:104]: Hostname: battery
[22:05:44][C][ota:093]: Over-The-Air Updates:
[22:05:44][C][ota:094]: Address: battery.local:3232
[22:05:44][C][ota:097]: Using Password.
[22:05:44][C][api:138]: API Server:
[22:05:44][C][api:139]: Address: battery.local:6053
[22:05:44][C][api:143]: Using noise encryption: NO
[22:05:44][C][wifi_signal.sensor:009]: WiFi Signal 'modbus rssi'
[22:05:44][C][wifi_signal.sensor:009]: Device Class: 'signal_strength'
[22:05:44][C][wifi_signal.sensor:009]: State Class: 'measurement'
[22:05:44][C][wifi_signal.sensor:009]: Unit of Measurement: 'dBm'
[22:05:44][C][wifi_signal.sensor:009]: Accuracy Decimals: 0
[22:05:44][C][modbus_controller:275]: ModbusController:
[22:05:44][C][modbus_controller:276]: Address: 0x00
[22:05:44][D][uart_debug:158]: <<< "~20004642E00200FD37\r"
[22:05:44][W][modbus:105]: Modbus CRC Check failed! F0D2!=4330
[22:05:44][D][uart_debug:158]: <<< "~2000460010960001100CCA0CCA0CC80CCB0CCB0CCA0CCB0CCA0CCA0CCB0CC90CC90CCA0CCA0CCB0CCA060B700B700B710B710B830B77FDB814762A050A76C0016176C0000203E81474000"
[22:05:44][D][uart_debug:158]: <<< "0000000000000DC84\r"
[22:05:44][D][uart_debug:158]: <<< "~20004644E00200FD35\r"
[22:05:44][W][modbus:105]: Modbus CRC Check failed! E68!=3630
[22:05:44][W][modbus:105]: Modbus CRC Check failed! 229B!=3030
[22:05:44][D][uart_debug:158]: <<< "~20004600806200011000000000000000000000000000000000060000000000000000140000000000000300000100000000000000000001EB32\r"
[22:05:45][D][uart_debug:158]: <<< "~20004642E00200FD37\r"
[22:05:45][W][modbus:105]: Modbus CRC Check failed! F0D2!=4330
[22:05:45][D][uart_debug:158]: <<< "~2000460010960001100CCA0CCA0CC80CCB0CCB0CCA0CCB0CCA0CCA0CCB0CC90CC90CCA0CCA0CCB0CCA060B700B700B710B710B830B77FDD914762A040A76C0016176C0000203E81474000"
[22:05:45][D][uart_debug:158]: <<< "0000000000000DC82\r"
[22:05:45][D][uart_debug:158]: <<< "~20004644E00200FD35\r"
[22:05:45][W][modbus:105]: Modbus CRC Check failed! E68!=3630
[22:05:45][W][modbus:105]: Modbus CRC Check failed! 229B!=3030
[22:05:45][D][uart_debug:158]: <<< "~20004600806200011000000000000000000000000000000000060000000000000000140000000000000300000100000000000000000001EB32\r"
[22:05:46][D][uart_debug:158]: <<< "~20004642E00200FD37\r"
[22:05:46][W][modbus:105]: Modbus CRC Check failed! 71D0!=4330
[22:05:47][D][uart_debug:158]: <<< "~2000460010960001100CCA0CCA0CC80CCB0CCC0CCA0CCB0CCA0CCB0CCB0CCA0CC90CCA0CCA0CCB0CCA060B700B700B710B710B830B77FDF214762A040A76C0016176C0000203E81475000"
[22:05:47][D][uart_debug:158]: <<< "0000000000000DC7C\r"
[22:05:47][D][uart_debug:158]: <<< "~20004644E00200FD35\r"
[22:05:47][W][modbus:105]: Modbus CRC Check failed! E68!=3630
[22:05:47][W][modbus:105]: Modbus CRC Check failed! 229B!=3030
[22:05:47][D][uart_debug:158]: <<< "~20004600806200011000000000000000000000000000000000060000000000000000140000000000000300000100000000000000000001EB32\r"
[22:05:48][D][uart_debug:158]: <<< "~20004642E00200FD37\r"
[22:05:48][W][modbus:105]: Modbus CRC Check failed! F0D2!=4330
Please, if you can help me and give me some tricks to understand this world… is very complicated form me
Thanks in advance and have a nice day.
