When I was putting together examples for the Template Select Cookbook entry I tried every way I could think of to get a trigger-based version to work, but none of them were fully functional… Since it requires a triggering event to update the state, they required multiple triggers. Each additional trigger made the template more complicated and added edge cases that made it less reliable.
I ended up with the same combination that you did; a trigger-based Template sensor (for its restart resistance) with a state-based Template select (for the frontend control).
- trigger:
- platform: event
event_type: custom_set_selected_window
- name: Selected Window
state: "{{ trigger.event.data.window }}"
- select:
- name: Window Selector
state: "{{ states('sensor.selected_window')}}"
options: "{{ state_attr('binary_sensor.all_window_sensors', 'entity_id') }}"
select_option:
- event: custom_set_selected_window
event_data:
window: "{{ option }}"
