I thought it would be neat to be able to modify the configuration file through Home Assistant, so I found out how.
The prerequisite is that you have an FTP server installed on whatever you have Home Assistant installed on that is accessible externally.
Step 1: Setup FTP server.
Step 2: Port Foward port 21 so you can access it externally.
Step 3: Connect to your FTP Server using Pydio.
Step 4: Display the files by ‘Details’ so you can list them easier:
Step 5: Set the default editor to ‘Source Editor’. I already set mine, so you have to go to ‘Choose Other’:
Step 6: Add a panel to Home Assistant with a shortcut that goes straight to the configuration file.
panel_iframe:
configuration:
title: 'Configuration'
url: 'https://webftp.dreamhost.com/ws-WebFTP/?goto=WebFTP%2Fconfiguration.yaml'
I’m thinking the URL will be the same as mine, but you get it here:
Step 7: Restart Home Assistant so the panel shows up
Now you can view your files through Home Assistant and modify them by double clicking them:
