figure a separate post would make it easy to find.
The default more-info slider on the domains is way too fat for me and it even got fatter a couple of releases ago. In the modifications I use
more-info-control-thickness: 85px
which I set in my themes.
My themes are squared, so I like the slider/toggles to be squared also (even the small details like the track handle …)
Also, in my dark themes, I can not read the slider popup, so I had to set a different color/background
Hope this helps people that look to do the same
Below my current set of card_mod modifications to the more-info dialogs on the domains I use:
light (all 3 modes required for card-mod to pick up)
switch
input_boolean
fan
cover
siren
alarm_panel
card-mod-more-info-yaml: |
ha-dialog-header: |
{# adding this, because Kiosk-mode does not apply to /config dashboards #}
.breadcrumb {
{% if is_state('input_boolean.hide_dialog_header_breadcrumb_navigation','on') %}
display: none !important
{% endif %};
ha-more-info-info $ more-info-content $:
more-info-input_boolean,more-info-switch,more-info-siren $:
ha-state-control-toggle $: |
ha-control-switch {
--control-switch-border-radius: var(--border-radius-square) !important;
--control-switch-thickness: var(--more-info-control-thickness) !important;
more-info-fan $:
ha-control-select-menu $: |
.select-anchor {
ha-state-control-fan-speed $: |
ha-control-slider {
--control-slider-border-radius: var(--border-radius-square) !important;
--control-slider-thickness: var(--more-info-control-thickness) !important;
ha-state-control-fan-speed $ ha-control-slider $: |
.slider .slider-track-bar::after {
border-radius: var(--border-radius-square) !important; /* --slider-track-bar-border-radius*/
.tooltip {
background: var(--card-background-color) !important;
/*color: var(--primary-text-color) !important;*/
more-info-alarm_control_panel $:
ha-state-control-alarm_control_panel-modes $: |
ha-control-select {
--control-select-border-radius: var(--border-radius-square) !important;
--control-select-thickness: var(--more-info-control-thickness) !important;
more-info-cover $:
ha-state-control-cover-position $: |
ha-control-slider {
ha-state-control-cover-position $ ha-control-slider $: |
.tooltip {
more-info-light $:
ha-state-control-light-brightness $: |
ha-control-slider {
ha-state-control-light-brightness $ ha-control-slider $: |
.tooltip {
light-color-rgb-picker $: |
.native-color-picker {
color: var(--primary-color) !important;
light-color-temp-picker $: |
ha-control-slider {
/*--control-slider-background: red !important;
--control-slider-color: red !important;*/
light-color-temp-picker $ ha-control-slider $: |
.slider {
--handle-size: 4px;
.slider .slider-track-cursor {
--cursor-size: 14px !important;
/*background: yellow !important;*/
.slider .slider-track-cursor::after {
.tooltip {
.select-anchor {
.mdc-dialog {
backdrop-filter: blur(17px) !important;
-webkit-backdrop-filter: blur(17px) !important;
.mdc-dialog .mdc-dialog__content {
/*padding: var(--dialog-content-padding, 24px);*/
the children on the more-info panels are tile cards, and I have set those with their own modifications, there’s a other post I did on that
