tibmart
(Tiberio Martinez)
January 19, 2019, 2:09am
1
in case this is useful for someone, this how I monitor my NVR from Home Assistant via SNMP.
This is the final result:
Process:
1.- Enable SNMP in your Hikvision NVR:
2.- Create your sensors: (sensors.yaml)
################# HIKVISIOn NVR ##############################
- platform: snmp
community: public
host: 192.168.86.40
baseoid: 1.3.6.1.2.1.1.3.0
accept_errors: true
unit_of_measurement: 'days'
value_template: '{{((value | int) / 8640000) | int}}'
- platform: snmp
host: 192.168.86.40
baseoid: 1.3.6.1.4.1.50001.1.102.0
accept_errors: true
value_template: >-
{% if value is equalto "1" %}
Online
{% else %}
Offline
{% endif %}
- platform: snmp
host: 192.168.86.40
baseoid: 1.3.6.1.4.1.50001.1.230.0
accept_errors: true
value_template: >-
Online
{% else %}
Offline
{% endif %}
- platform: snmp
host: 192.168.86.40
baseoid: 1.3.6.1.4.1.50001.1.241.1.4.1.0
accept_errors: true
unit_of_measurement: 'MB'
value_template: '{{((value | int) / 1024) | int}}'
- platform: snmp
host: 192.168.86.40
baseoid: 1.3.6.1.4.1.50001.1.241.1.5.1.0
accept_errors: true
- platform: snmp
host: 192.168.86.40
baseoid: 1.3.6.1.4.1.50001.1.201.0
accept_errors: true
sensors:
nvr_disk_free_percent:
friendly_name: 'NVR Disk Free'
unit_of_measurement: '%'
value_template: '{{ (((states.sensor.nvr_disk_free_space.state | float) / (states.sensor.nvr_disk_size.state | float)) * 100) | round(1) }}'
3.- Customize the icons: (customize.yaml)
sensor.nvr_cpu_frequency:
icon: mdi:chip
sensor.nvr_disk_free_percent:
icon: mdi:harddisk
sensor.nvr_uptime:
icon: mdi:timer
sensor.nvr_hikdevice_status:
icon: mdi:cctv
sensor.nvr_hikonline:
icon: mdi:security-network
4.- Lovelace Card (iu-lovelace.yaml)
- type: glance
title: Hikvision NVR
icon: mdi:cctv
entities:
- entity: sensor.nvr_hikdevice_status
- entity: sensor.nvr_hikonline
- entity: sensor.nvr_uptime
- entity: sensor.nvr_disk_free_percent
- entity: sensor.nvr_cpu_frequency
Can you get your NVR cameras URI streaming?
I have ds-7216 and I can’t get them.
Edit: it was misconfigured. I get them.
tibmart
(Tiberio Martinez)
January 26, 2019, 12:17pm
4
Cool!
I have been trying and enabled the access to the cameras but it keeps asking for credentials when I’m using the :65001+ ports but none of my credentials seems to work.
Is this similar to the issue you had?
No, I just tried to use live view via RTSP. My problem was that I hadn’t valid web user.
Why do you use 65000+ ports? Why don’t you use RTSP?
tibmart
(Tiberio Martinez)
January 26, 2019, 10:43pm
6
Out of desperation mostly
I read somewhere that the lastest firmwares just do it that way.
I’ll give a shot to the RTSP to see how it goes
I read them too.
But now the live view works by RTSP and the HA Hikvision Binary Sensor not. It sees the sensors but the statement doesn’t change.
Do you know this User Guide ?
I upgreded the firmware and no SNMP.
tibmart
(Tiberio Martinez)
January 28, 2019, 3:14am
10
No, Thanks for that.
I’m checking now
tibmart
(Tiberio Martinez)
January 28, 2019, 3:16am
11
I’m in firmware V4.1.50 build 180423, all good with the SNMP
What kind of NVR do you have?
tibmart
(Tiberio Martinez)
January 28, 2019, 12:12pm
13
I have a DS-7608NI-I2 / 8P. I checked the firmware and it says I’m in the latest one.
Both the SNMP and the sensors work for me, and RSTP now works using your link.
macfox
(Macfox)
March 8, 2019, 11:20am
14
Notice they removed it from one version then reinstated in the next.
markpuls
(Mark Puls)
April 29, 2019, 2:18am
15
Took me a few hours to figure out all the details- might help someone else if your trying to get RTSP or HTTP Pictures from your Hikvision NVR:
Just remove () and insert your data- such as your RTSP port or HTTP port from your NVR network page under configuration of your NVR.
rtsp://(IPAddress):(RTSP Port)/Streaming/Channels/101/
http://(IPAddress):65001/PSIA/Streaming/channels/1/picture
http://(IPAddress):(HTTPPort80?)/PSIA/Streaming/channels/101/picture
http://(IPAddress):(HTTPPort80?)/PSIA/Custom/SelfExt/ContentMgmt/DynStreaming/channels/101/picture
http://(IPAddress):(HTTPPort80?)/PSIA/Streaming/channels/101/picture?videoResolutionWidth=1920&videoResolutionHeight=1080
http://(IPAddress):(HTTPPort80?)/ISAPI/Streaming/channels/101/picture
http://(IPAddress):(HTTPPort80?)/ISAPI/ContentMgmt/StreamingProxy/channels/101/picture
shabz
May 4, 2019, 11:27pm
16
Thank you worked flawlessly.
smoothy
(Alex Maiorano)
October 18, 2019, 11:49am
19
Just gave this a go with my NVR. I cant even get it to pickup sensors. I’ve updated the Hikvision 7616 6ch POE to enable SNMP without issue. Is the method in the first post still working?
tibmart
(Tiberio Martinez)
October 18, 2019, 12:16pm
20
Yes, it works flawlessly for me.
Just make sure you have the right IP addresses.
ricq
(Ric)
October 26, 2019, 5:59am
21
I tried your code. I can’t get it to show up in lovelace. Can you help me ? Thanks.
Ric
kslb
(KSLBe)
November 21, 2019, 5:31pm
22
You should use icon for the sensor not card…
