HASSIO has been crashing every several days for me. The only way for me to get it back up is to restart the system. When that happens though HASSIO resets the logs.
Any suggestions on how to keep the logs even after a reboot? I believe this is a known issue.
Unfortunately my Pi crashes almost everyday and it did last night after I had this script running, but it did not catch any errors or warning prior to crashing
Just a tip, when you see weird crashed and reboots without any error logs on a Pi. Check/Replace your USB-Power cable and maybe even charger. My cable was working fine mostly but apparently sometimes HA would just draw a bit too much power. It was driving me crazy, after replacing my cable everything is smooth now
I know it’s been a while since your post but maybe you still have this problem or it might help someone else
