Monoprice Multizone - bass, treble, balance controls?
I know that the functionality exists, and prior to using HA to control this amp, I used a windows application that provided similar functionality (minus the automations) but with controls for bass, treble, balance, etc.
Is there a way to make these audio adjustments currently, or will this require an update?
Thanks,
I would love to see this addition to the integration as well. It would be really nice to have those bass, treble, and balance controls. Announcement functionality also exists (i.e., to permit a message to be sent to all zones), but getting bass, treble, and balance going would be the highest priority. Thanks also go to those who have built this integration for Home Assistant!!!
Dave
If it can helps, i’ve coded (but i’m so bad) theses features on another integration (https://github.com/jaywax/domogik-plugin-mprsg6z).
Thanks, jaywax! I wish I could code so I could incorporate your work into HomeAssistant. Hopefully someone else who has the knowledge and skill can take this and run with it.
I’m very close to switching from Russound MCA5 over to two Monoprice 6 Zone Amps. Has anyone made any more progress or inquiries into how to bring these additional audio controls into HA? Are the Media Player Cards even capable of showing these settings?
Sorry, I wish I could report there was progress in integrating those additional controls, but to the best of my knowledge they are still not incorporated. My memory on this is a bit hazy, but I believe I used either the wired monoprice controllers to setup the missing configuration info (e.g., treble) for speaker zones, or the software developed by Mike Pisano, or a HomeSeer plugin developed by happnatious1. I believe the MP units will store the latest configuration setting. I still wish we could do this through Home Assistant, though.
I haven’t used Russound, but for my part I really do like the Monoprice units and would highly recommend them (I have three). For me they have been working pretty flawlessly in Home Assistant (I did encounter some issues in HomeSeer).
I have created a custom integration to fix this:
Thank you for working on this, Brad! It sounds wonderful.
I did try to give your code a go, but unfortunately could not get it to work. When I followed the instructions, from what I could see HA simply loaded the previous Monoprice integration (i.e., not the one with your updates). I tried disabling the prior Monoprice integration, deleting it, and making changes to configuration.yaml, but results were still the same (i.e., the prior Monoprice integration loaded each time). Do you have any suggestions? I would love to incorporate these new features into my setup.
Thanks,
Dave
Dang, sorry to hear that. This is my fist integration I have created that overrides a core integration. I will do my best to have a fix out today. I will post a message here one I have it fixed. Thanks for letting me know.
@DaveW42 When adding the custom integration the file structure should look like this:
/config/custom_components/monoprice
these should be within the root of the monoprice folder:
  • __init__.py
  • config_flow.py
  • const.py
  • manifest.json
  • media_player.py
  • services.yaml
  • strings.json
Thanks, Brad. If I am understanding this correctly, I can use the files I downloaded from github previously, but should rename init.py as you have indicated above.
I tried this approach as well. I should note that I also have a folder called translations under the monoprice folder. It is still a no-go (loads previous integration). As with the last time, I also tried disabling and deleting my prior Monoprice integration, and still no luck.
Also, I should note that–to understand whether this works–what I am doing is checking to see if there are any new services associated with the monoprice integration, and I also try to see what happens when I add a media control card (I am expecting to see the sound mode feature to become available on the media card).
Thanks again for keeping at this!
Dave
Sorry I fixed my comment above for the correct __init__.py, the translation folder is also correct.
What version of Home Assistant are your on, I have only tested this on mine: Docker Install: 2022.4.6
You should see some items in the log about the Monoprice Integration. can you post those here?
@DaveW42 I have updated the repo the custom integration will no longer override the core integration.
I hope this fixes it for you. Before you add it, be sure to disable the core integration.
Please let me know how this works for you.
The new integration name is: Monoprice 6-Zone Amplifier Custom
Hi, Brad.
Unfortunately still no luck. It keeps going to the original integration. I downloaded all of your github files again, including the py cache directory. I tried adding the integration with and without adding " - platform: monoprice_custom" to my configuration file (plus the corresponding port configuration line). I am running HA 2022.4.6 on a raspberry pi4 with Hass OS 7.6 and supervisor-2022.04.0 (i.e., the latest versions of each). After trying this in several ways, I then restore my HA instance to what it was before we started trying the new integration (i.e., it should provide a fresh start each time).
Just to confirm, when I choose to add your custom integration, should I be clicking the green add integration button at the bottom right of the configuration screen, and then selecting monoprice from the options presented? That’s what I have been doing. I did look to see if you placed this in HACS but i didn’t see it there. Additionally, even though the files are in the /config/custom_components directory, HA does not auto-discover the custom integration.
If there is anyone else out there who wants to give this a try that might be helpful too (in case I am missing something).
Lastly, is the DSStore file needed? I’ve seen some weird behavior with that file. In my previous tries I’ve included it certain times (I’ve tried running the code 10+ times), but I also noted that the file didn’t appear in your list above. The last time around it copied fine, but this time around–just before I posted this message–I tried things from scratch again and the file wouldn’t extract from the zipfile when I downloaded it using the “Download Code” option in github.
Thanks,
Dave
Just wanted to say thanks. I originally made this request in 2020.
I got it up and running, and as I had a lot of automations setup using the original integration, I had to first change the entity ids of the original integration zones, then rename the custom ones.
I’ll continue to test, but so far things seem to be fine once I changed the entity ids back to what they were.
Question: Is it possible to have UI sliders/controls for bass and treble? I see that we can set specific levels, but obviously this isn’t convenient for quick on-the-fly changes.
Thanks again, this is great even if we can’t get sliders.
Hi, coppertop.
Great to hear you got this going! Could you perhaps talk about what you did to get it going, that might have differed from what I was doing? I’ve probably run through the steps 15+ times at this point.
With regard to this, I have some specific questions as well:
  • How did you add this integration to your system?
  • Did you make any changes to configuration.yaml, to get it to work?
  • Did you disable or delete your prior Monoprice configuration?
  • DId you do anything with the DSStore file?
  • What is your setup (e.g., docker, raspberry pi with HA OS, etc.)
Any insight you might be able to share would be great, as I have been trying just about everything I could think of.
I agree as well that it would be really nice to see sliders if at all possible.
Thanks!
Dave
Thanks for your feedback, I am glad it is working for you! I will continue to work on the integration, I agree sliders would be a good idea. I will have to do some research and see if this is possible.
Awesome. Looking forward to any new developments
To be honest I didn’t do any yaml config changes, etc.
All I did was…
  • copy the “monoprice_custom” folder into my “custom_components” folder
  • disabled my Monoprice 6-Zone Amplifier integration in the config/integrations
  • restarted home assistant (not sure if it’s necessary)
  • clicked “add new integration” in config/integrations – selected the monoprice custom one
  • then set my input names and ports (same as the previous one)
  • finally, in order to avoid having to redo all my previous automations/scripts/etc, I renamed all the old monoprice entities by adding a “_old” to the end, and then renamed the new entities to what the old ones were
That’s it. Hopefully that helps.
Support has been added for Balance, Bass, Treble Slider entities. There are also now 3 sensors per zone for PA, Do Not Disturb & Keypad connection status.
