Thanks! I look forward to it.
Can i use a socket instead of serial for the connection to the amp? example instead of /dev/ttyUSB0 socket://192.168.x.x:8080 ? I was able to get the custom amp integration added, but when trying to connect it, it errors. I get “Unexpected error”
I am guessing it is related to what you said you are updating?
@Littleaton, I’m also a new user and am getting the same error. In my case with /dev/ttyUSB0. The official Monoprice integration installs, configures, and runs fine for me.
Hi @thebradleysanders, great work from what I can see! Is this error related to the sync/async change on the platform?
Logger: custom_components.monoprice_custom.config_flow
Source: custom_components/monoprice_custom/config_flow.py:57
Integration: Monoprice 6-Zone Amplifier Custom (documentation, issues)
First occurred: 9:31:12 PM (4 occurrences)
Last logged: 10:13:29 PM
Unexpected exception
File "/config/custom_components/monoprice_custom/config_flow.py", line 78, in async_step_user
info = await validate_input(self.hass, user_input)
File "/config/custom_components/monoprice_custom/config_flow.py", line 57, in validate_input
await get_async_monoprice(data[CONF_PORT], hass.loop)
File "/usr/local/lib/python3.10/site-packages/pymonoprice/__init__.py", line 381, in get_async_monoprice
_, protocol = yield from create_serial_connection(loop, functools.partial(MonopriceProtocol, loop),
File "/usr/local/lib/python3.10/site-packages/serial_asyncio/__init__.py", line 449, in create_serial_connection
transport, protocol = await connection_for_serial(loop, protocol_factory, serial_instance)
File "/usr/local/lib/python3.10/site-packages/serial_asyncio/__init__.py", line 476, in connection_for_serial
protocol = protocol_factory()
File "/usr/local/lib/python3.10/site-packages/pymonoprice/__init__.py", line 350, in __init__
self._connected = asyncio.Event(loop=loop)
File "/usr/local/lib/python3.10/asyncio/locks.py", line 168, in __init__
super().__init__(loop=loop)
File "/usr/local/lib/python3.10/asyncio/mixins.py", line 17, in __init__
raise TypeError(
TypeError: As of 3.10, the *loop* parameter was removed from Event() since it is no longer necessary
Yup i get the same error, and the HA core integration works, but would love to se this one…
I’m currently researching how to replace the EOL SmartThings groovy integration to my Monoprice 6-Zone Amp. I also have a Hubitat hub and a Home Assistant implementation. Possible solutions may to run some devices on HA or HE and some devices on SmartThings or migrate to HA or HE completely.
To that end, I thought I’d create and share a one-stop list of all the home automation integrations to this great-value amp so that I could narrow down which direction to go.
Here it is: https://www.reddit.com/r/homeautomation/comments/x7njvw/monoprice_6zone_amp_integrations_list/
I’ve just read this after 3 years, and i just wanted to thanks all the contributors of this custom coponents !
I’m using this integration with a rpi connected via usb-serial connection, I can change the balance/bass/treble with the slider and the corresponding service:set_balance/bass/treble but the number.zone_balance/bass/treble entities all show up as unknown. The commands and replies seem to be received correctly but the number entities are being updated:
2024-01-21 09:01:49.168 DEBUG (SyncWorker_9) [pymonoprice] Sending “b’<11BL09\r’”
2024-01-21 09:01:49.181 DEBUG (SyncWorker_9) [pymonoprice] Received “b’<11BL09\r\n#'”
2024-01-21 09:01:49.184 DEBUG (SyncWorker_12) [pymonoprice] Sending “b’?11\r’”
2024-01-21 09:01:49.221 DEBUG (SyncWorker_12) [pymonoprice] Received “b’?11\r\n#>1100010000120014090600\r\r\n#'”
Hello. I followed your instructions on the GitHub page to try and install via HACS. I got a popup that the integration was already part of the store so I changed it to find and install via the Home Assistant Community Store.
I restarted HA afterward but I do not see the integration as installed.
Is there another process I should be following?
Thanks.
