Still having the same problems. Everything’s up to date, uninstall and re-install, restarts, check the yaml files and I have nothing out of wack. I try to start it and nothing starts, logs show nothing. I try going back to old back-ups and try it there, still get the same issue. I have no idea and am completely stuck.
s6-rc: info: service s6rc-oneshot-runner: starting
s6-rc: info: service s6rc-oneshot-runner successfully started
s6-rc: info: service fix-attrs: starting
s6-rc: info: service fix-attrs successfully started
s6-rc: info: service legacy-cont-init: starting
cont-init: info: running /etc/cont-init.d/mosquitto.sh
[21:29:38] INFO: SSL is not enabled
cont-init: info: /etc/cont-init.d/mosquitto.sh exited 0
cont-init: info: running /etc/cont-init.d/nginx.sh
cont-init: info: /etc/cont-init.d/nginx.sh exited 0
s6-rc: info: service legacy-cont-init successfully started
s6-rc: info: service legacy-services: starting
services-up: info: copying legacy longrun mosquitto (no readiness notification)
services-up: info: copying legacy longrun nginx (no readiness notification)
s6-rc: info: service legacy-services successfully started
[21:29:39] INFO: Starting NGINX for authentication handling...
[21:29:39] INFO: Starting mosquitto MQTT broker...
2022-11-03 21:29:39: Warning: Mosquitto should not be run as root/administrator.
[21:29:40] INFO: Successfully send discovery information to Home Assistant.
[21:29:41] INFO: Successfully send service information to the Supervisor.
2022-11-03 21:29:39: mosquitto version 2.0.11 starting
2022-11-03 21:29:39: Config loaded from /etc/mosquitto/mosquitto.conf.
2022-11-03 21:29:39: Loading plugin: /usr/share/mosquitto/go-auth.so
2022-11-03 21:29:39: ├── Username/password checking enabled.
2022-11-03 21:29:39: ├── TLS-PSK checking enabled.
2022-11-03 21:29:39: └── Extended authentication not enabled.
2022-11-03 21:29:39: Opening ipv4 listen socket on port 1883.
2022-11-03 21:29:39: Opening ipv6 listen socket on port 1883.
2022-11-03 21:29:39: Opening websockets listen socket on port 1884.
2022-11-03 21:29:39: mosquitto version 2.0.11 running
2022-11-03 21:29:40: New connection from 127.0.0.1:55912 on port 1883.
2022-11-03 21:29:40: Client <unknown> closed its connection.
2022-11-03 21:31:40: New connection from 172.30.32.1:47851 on port 1883.
2022-11-03 21:31:40: New client connected from 172.30.32.1:47851 as 0QtTQCU7FmQ0Xr4IwP39UL (p2, c1, k60, u'homeassistant').
2022-11-03 21:59:40: Saving in-memory database to /data//mosquitto.db.
2022-11-03 22:29:41: Saving in-memory database to /data//mosquitto.db.
2022-11-03 22:59:42: Saving in-memory database to /data//mosquitto.db.
2022-11-03 23:29:43: Saving in-memory database to /data//mosquitto.db.
2022-11-03 23:44:22: New connection from 167.248.133.119:56656 on port 1883.
error: received null username or password for unpwd check
2022-11-03 23:44:22: Client <unknown> disconnected, not authorised.
2022-11-03 23:59:44: Saving in-memory database to /data//mosquitto.db.
2022-11-04 00:29:45: Saving in-memory database to /data//mosquitto.db.
2022-11-04 00:59:46: Saving in-memory database to /data//mosquitto.db.
2022-11-04 01:29:47: Saving in-memory database to /data//mosquitto.db.
2022-11-04 01:59:48: Saving in-memory database to /data//mosquitto.db.
2022-11-04 02:29:49: Saving in-memory database to /data//mosquitto.db.
2022-11-04 02:59:50: Saving in-memory database to /data//mosquitto.db.
2022-11-04 03:29:51: Saving in-memory database to /data//mosquitto.db.
2022-11-04 03:59:52: Saving in-memory database to /data//mosquitto.db.
2022-11-04 04:29:53: Saving in-memory database to /data//mosquitto.db.
2022-11-04 04:59:54: Saving in-memory database to /data//mosquitto.db.
2022-11-04 05:29:55: Saving in-memory database to /data//mosquitto.db.
2022-11-04 05:59:56: Saving in-memory database to /data//mosquitto.db.
2022-11-04 06:29:57: Saving in-memory database to /data//mosquitto.db.
2022-11-04 06:59:58: Saving in-memory database to /data//mosquitto.db.
2022-11-04 07:29:59: Saving in-memory database to /data//mosquitto.db.
2022-11-04 08:00:00: Saving in-memory database to /data//mosquitto.db.
2022-11-04 08:17:51: New connection from 64.62.197.32:37914 on port 1883.
