New To Mosquitto Broker
Mosquitto Broker won’t start all of a sudden. New to all of this wondering how I should go about checking it? I click the start button on the add-on and it spins and doesn’t do anything logs below
s6-rc: info: service s6rc-oneshot-runner: starting
s6-rc: info: service s6rc-oneshot-runner successfully started
s6-rc: info: service fix-attrs: starting
s6-rc: info: service fix-attrs successfully started
s6-rc: info: service legacy-cont-init: starting
cont-init: info: running /etc/cont-init.d/mosquitto.sh
[13:34:41] INFO: SSL is not enabled
cont-init: info: /etc/cont-init.d/mosquitto.sh exited 0
cont-init: info: running /etc/cont-init.d/nginx.sh
cont-init: info: /etc/cont-init.d/nginx.sh exited 0
s6-rc: info: service legacy-cont-init successfully started
s6-rc: info: service legacy-services: starting
services-up: info: copying legacy longrun mosquitto (no readiness notification)
services-up: info: copying legacy longrun nginx (no readiness notification)
s6-rc: info: service legacy-services successfully started
[13:34:42] INFO: Starting NGINX for authentication handling...
[13:34:43] INFO: Starting mosquitto MQTT broker...
2022-10-18 13:34:43: Warning: Mosquitto should not be run as root/administrator.
[13:34:44] INFO: Successfully send discovery information to Home Assistant.
[13:34:45] INFO: Successfully send service information to the Supervisor.
Is it a NGINX Problem? I went into that and it was gray, pressed start and got this dialog box:
Missing required option 'domain' in NGINX Home Assistant SSL proxy (core_nginx_proxy).
Like I said, brand new to this so any guidance will help.
Won't help but have the same issue ;) HP t630 in my case.
Still having the same issues and don’t really know where to go next at this point.
I think you might get lost in this, but this guy presented it in a good way (almost everything works).
If you have cc2531 it should help together with translator. Please keep in mind that some [zigbee2mqtt] options are already in the panel instead of configuration tab in add-ons.
Hope this will help.
I appreciate the webpage but still having the same problems. Everything’s up to date, uninstall and re-install, restarts, check the yaml files and I have nothing out of wack. I try to start it and nothing starts, logs show nothing. I try going back to old back-ups and try it there, still get the same issue. I have no idea and am completely stuck.
