Hi all i have similary issue with my ha…
i use:
homeassistant 0.104.3
System Health
| arch |
armv7l |
| dev |
false |
| docker |
true |
| hassio |
true |
| os_name |
Linux |
| python_version |
3.7.6 |
| timezone |
Europe/Rome |
| version |
0.104.3 |
| virtualenv |
false |
Lovelace
| mode |
storage |
| resources |
2 |
| views |
11 |
mosquitto broker addon 5.1
and this is some log:
2020-01-29T15:26:48.453022085Z 1580311608: Client btn_comodino-tano has exceeded timeout, disconnecting.
2020-01-29T15:26:48.475525586Z 1580311608: Client ctr_lavastoviglie has exceeded timeout, disconnecting.
2020-01-29T15:26:48.496725796Z 1580311608: Client btn_scala-interna has exceeded timeout, disconnecting.
2020-01-29T15:26:48.516782675Z 1580311608: Client btn_comodino-cameretta has exceeded timeout, disconnecting.
2020-01-29T15:26:48.535395192Z 1580311608: Client dst_bagno has exceeded timeout, disconnecting.
2020-01-29T15:26:49.457206528Z 1580311609: Client ctr_cappa has exceeded timeout, disconnecting.
2020-01-29T15:26:49.475004781Z 1580311609: Client btn_finestra-bagno has exceeded timeout, disconnecting.
2020-01-29T15:26:49.492982142Z 1580311609: Client ctr_luci has exceeded timeout, disconnecting.
2020-01-29T15:26:49.493781220Z 1580311609: Client btn_cancellino has exceeded timeout, disconnecting.
2020-01-29T15:26:51.417167381Z 1580311611: Client btn_cortile has exceeded timeout, disconnecting.
2020-01-29T15:26:51.435712306Z 1580311611: Client ctr_cantina has exceeded timeout, disconnecting.
2020-01-29T15:26:51.454013161Z 1580311611: Client btn_cantina has exceeded timeout, disconnecting.
2020-01-29T15:26:57.383900390Z 1580311617: Client shellydimmer-DB2E2B has exceeded timeout, disconnecting.
2020-01-29T15:26:59.282893044Z 1580311619: New connection from 10.10.10.22 on port 1883.
2020-01-29T15:26:59.286712864Z 1580311619: New client connected from 10.10.10.22 as ctr_pcottura (p2, c1, k30, u'cg-mqtt').
2020-01-29T15:26:59.286847992Z 1580311619: New connection from 10.10.10.42 on port 1883.
2020-01-29T15:26:59.286911991Z 1580311619: New client connected from 10.10.10.42 as dst_living-1 (p2, c1, k30, u'cg-mqtt').
2020-01-29T15:26:59.286970971Z 1580311619: New connection from 10.10.10.80 on port 1883.
2020-01-29T15:26:59.290236412Z 1580311619: New client connected from 10.10.10.80 as shellydimmer-DB2E2B (p2, c0, k60, u'cg-mqtt').
2020-01-29T15:26:59.455247843Z 1580311619: New connection from 10.10.10.14 on port 1883.
2020-01-29T15:26:59.470127593Z 1580311619: New client connected from 10.10.10.14 as ctr_cameretta (p2, c1, k30, u'cg-mqtt').
2020-01-29T15:27:01.168454738Z 1580311621: New connection from 10.10.10.70 on port 1883.
2020-01-29T15:27:01.168698363Z 1580311621: New client connected from 10.10.10.70 as btn_ingresso (p2, c1, k30, u'cg-mqtt').
2020-01-29T15:27:08.350704279Z 1580311628: New client connected from 10.10.10.19 as ctr_cantina (p2, c1, k30, u'cg-mqtt').
2020-01-29T15:27:08.439959410Z 1580311628: New connection from 10.10.10.82 on port 1883.
2020-01-29T15:27:08.440329978Z 1580311628: New client connected from 10.10.10.82 as btn_cantina (p2, c1, k30, u'cg-mqtt').
2020-01-29T15:27:08.589366697Z 1580311628: New connection from 172.30.32.1 on port 1883.
2020-01-29T15:27:08.589904798Z 1580311628: New client connected from 172.30.32.1 as mqtt_1890188e.a4e0f7 (p1, c1, k60, u'cg-mqtt').
2020-01-29T15:28:11.595420261Z 1580311691: New connection from 10.10.10.83 on port 1883.
2020-01-29T15:28:12.533130768Z [INFO] found cg-mqtt on Home Assistant
2020-01-29T15:28:12.534542113Z 1580311692: New client connected from 10.10.10.83 as btn_scala-esterna (p2, c1, k30, u'cg-mqtt').
2020-01-29T15:30:32.436542644Z 1580311832: Client btn_antibagno has exceeded timeout, disconnecting.
2020-01-29T15:30:49.015295071Z 1580311849: New connection from 10.10.10.73 on port 1883.
2020-01-29T15:30:49.017030577Z 1580311849: New client connected from 10.10.10.73 as btn_antibagno (p2, c1, k30, u'cg-mqtt').
2020-01-29T15:30:53.443545709Z 1580311853: Client mqtt_1890188e.a4e0f7 has exceeded timeout, disconnecting.
2020-01-29T15:31:28.417879976Z 1580311888: Client ctr_living-2 has exceeded timeout, disconnecting.
2020-01-29T15:31:28.418187026Z 1580311888: Client btn_scala-esterna has exceeded timeout, disconnecting.
2020-01-29T15:31:30.462025666Z 1580311890: Client ctr_ups has exceeded timeout, disconnecting.
2020-01-29T15:31:52.405612803Z 1580311912: Client btn_cancellino has exceeded timeout, disconnecting.
2020-01-29T15:31:58.419700686Z 1580311918: Client dst_living-2 has exceeded timeout, disconnecting.
2020-01-29T15:32:05.455807376Z 1580311925: Client btn_cucina has exceeded timeout, disconnecting.
2020-01-29T15:32:05.494332125Z 1580311925: Client btn_area-comune has exceeded timeout, disconnecting.
2020-01-29T15:32:05.534628342Z 1580311925: Client ctr_frigo has exceeded timeout, disconnecting.
2020-01-29T15:32:20.090398854Z 1580311940: Socket error on client btn_antibagno, disconnecting.
2020-01-29T15:32:21.420163215Z 1580311941: Client btn_ingresso has exceeded timeout, disconnecting.
2020-01-29T15:32:21.460592171Z 1580311941: Client ctr_forno has exceeded timeout, disconnecting.
2020-01-29T15:32:21.501020941Z 1580311941: Client ctr_bagno has exceeded timeout, disconnecting.
2020-01-29T15:33:49.423517928Z 1580312029: Client btn_finestra-bagno has exceeded timeout, disconnecting.
2020-01-29T15:38:27.694144608Z 1580312307: New connection from 10.10.10.80 on port 1883.
2020-01-29T15:38:28.643399506Z [INFO] found cg-mqtt on Home Assistant
2020-01-29T15:38:28.644843165Z 1580312308: New client connected from 10.10.10.80 as shellydimmer-DB2E2B (p2, c0, k60, u'cg-mqtt').
2020-01-29T15:38:28.645473173Z 1580312308: New connection from 10.10.10.83 on port 1883.
2020-01-29T15:38:28.645917239Z 1580312308: New connection from 10.10.10.70 on port 1883.
2020-01-29T15:38:28.646093236Z 1580312308: New connection from 10.10.10.42 on port 1883.
2020-01-29T15:38:28.646367305Z 1580312308: New connection from 10.10.10.76 on port 1883.
2020-01-29T15:38:28.646883351Z 1580312308: New connection from 10.10.10.14 on port 1883.
2020-01-29T15:38:28.651995890Z 1580312308: New client connected from 10.10.10.11 as ctr_bagno (p2, c1, k30, u'cg-mqtt').
2020-01-29T15:38:28.652018945Z 1580312308: New client connected from 172.30.32.1 as mqtt_1890188e.a4e0f7 (p1, c1, k60, u'cg-mqtt').
2020-01-29T15:38:28.654881209Z 1580312308: New client connected from 172.30.32.1 as mqttjs_fc4fe6c9 (p2, c1, k60, u'cg-mqtt').
2020-01-29T15:38:30.742545707Z 1580312310: New connection from 10.10.10.73 on port 1883.
2020-01-29T15:38:30.742624520Z 1580312310: New connection from 10.10.10.85 on port 1883.
2020-01-29T15:38:30.742807609Z 1580312310: New connection from 10.10.10.74 on port 1883.
2020-01-29T15:38:30.742873571Z 1580312310: New connection from 10.10.10.19 on port 1883.
2020-01-29T15:38:30.742901608Z 1580312310: New connection from 10.10.10.21 on port 1883.
2020-01-29T15:38:30.743109419Z 1580312310: New connection from 10.10.10.71 on port 1883.
2020-01-29T15:38:30.869429038Z 1580312310: New client connected from 10.10.10.71 as btn_cucina (p2, c1, k30, u'cg-mqtt').
2020-01-29T15:38:30.870121451Z 1580312310: New client connected from 10.10.10.90 as btn_finestra-bagno (p2, c1, k30, u'cg-mqtt').
2020-01-29T15:38:30.870800217Z 1580312310: New client connected from 10.10.10.26 as ctr_frigo (p2, c1, k30, u'cg-mqtt').
2020-01-29T15:38:30.871577055Z 1580312310: New client connected from 10.10.10.72 as btn_soggiorno (p2, c1, k30, u'cg-mqtt').
2020-01-29T15:38:30.872459391Z 1580312310: New client connected from 10.10.10.15 as ctr_ups (p2, c1, k30, u'cg-mqtt').
2020-01-29T15:38:31.501894858Z 1580312311: New connection from 10.10.10.40 on port 1883.
2020-01-29T15:38:31.540961699Z 1580312311: New client connected from 10.10.10.40 as dst_camera01 (p2, c1, k30, u'cg-mqtt').
2020-01-29T15:39:06.158073773Z 1580312346: New connection from 10.10.10.81 on port 1883.
2020-01-29T15:39:06.160689707Z 1580312346: New client connected from 10.10.10.81 as btn_scala-interna (p2, c1, k30, u'cg-mqtt').
2020-01-29T15:39:18.207310189Z 1580312358: New connection from 10.10.10.24 on port 1883.
2020-01-29T15:39:18.207472371Z 1580312358: New client connected from 10.10.10.24 as ctr_lavatrice (p2, c1, k30, u'cg-mqtt').
2020-01-29T15:40:29.416858585Z 1580312429: New connection from 10.10.10.78 on port 1883.
I went home last night and the devices were not working, I had to reinstall mosquitto and redo the integration. from this morning continues to connect and disconnect the devices
