Hi all, I thought I’d share this project.
This was inspired by (and credited to) @Vance terrific motion-controlled lights.
- In my setup I’m using
forked_daapd
(AKA OwnTone) integration for multiroom sync. I’m sure someone can adapt this blueprint to usesonos.join
or similar for your own use-case - This would be much more streamlined once the new(-ish)
media_player.join
is implemented by these integrations
See my gist for two blueprints.
To enable motion-control, you will need to create one of each, for every media_player
- Blueprint #1 configures a
presence_entity
(= motion sensor) which will trigger playback for the player, and stop playback once no motion detected for [x] minutes - Blueprint #2 creates the override: if the media player is turned on/off manually, it will
turn_off
the automation above for a [x] minutes
So if you’re sitting still and reading, and the music turns off… you can manually turn on the speaker next to you, and it won’t turn off just because there’s no motion in the room
Again, lots of credit to @Vance
Thoughts and/or improvements are more than welcome!
