It depends on what controller you are using, but you need to change the Parameters 1 and 3. This is an action done on the controller itself so I can’t tell you exactly how to do it.
The manual of the Fibaro Motion sensor will tell you some more information on the available settings, and the manual of the controller itself should explain how to set parameters. Just remember to wake the motion sensor to apply them (or you’ll have to wait up to 5 hours for the device to wake periodically)
@Danny: Many thanks for your excellent Entity Controller project and the helpful posts on your site. I am excited about the prospect of setting up intelligent lighting in my home and look forward to utilizing the resources you have so thoughtfully shared with the community.
Quick question… Have you (or anyone else here) tried the “Mini” version of the Kerui motion sensor? I’m curious whether it works as well as the model you recommended here previously.
Thanks for your kind words, it means a lot to see everyone benefit from my component!
Ihave not tried that mini version. If its the same brand its probably using the same parts. Only the battery life may not be as good if its using a different battery. It may also be missing the micro-USB port, which is nice.
Two of my sensors are always plugged in. one into the TV, the other into the modem. It is very good to have that option.
Good point – I hadn’t thought about that. Looking at this photo, it seems a similar DC5V USB port is present on the Mini version as well. I assume that is just for power, but you mentioned plugging the sensors into your TV and modem. Would you be so kind as to elaborate as to how and why you have your sensors connected via USB to your TV and modem?
@Danny: I want to create a motion-based lighting system in my home with Home Assistant + Entity Controller, along the lines of the system that you have outlined and presumably use in your home. I’m still a bit unclear, however, what I need to do to get started. Specifically, at the moment, I am trying to understand which hardware I need to procure in addition to motion sensors, smart bulbs, and smart power switches (for lamps).
I assume the Kerui motion sensors you recommended do not connect directly via WiFi and thus require some kind of intermediary device in order to be used with Home Assistant + Entity Controller. Is that right? If that is indeed the case, what device(s) do you recommend? Is there any other additional hardware that I need to procure?
I have automated the lighting in the hallways by swapping out the bulbs with smart bulbs. I have a ceiling light and wall light on the stairs on each floor. So it was pretty easy. Then disabled the light switches to prevent accidentally turning power off to the lights.
But then in the entrance hallway I have a table lamp with smart bulb. And in the kitchen I have a mix of a table lamp in the table, 2 wifi led strip lights and an IKEA GU10 mounted under a cupboard.
Once the radio signal is converted to MQTT message, home assistant will be able to process it. I wrote another custom component called mqtt_payload_processor. It will read the MQTT messages and convert them to Home Assistant events. You can also put basic automations right in the components config, rather than creating an automation elsewhere. (check out the repository for plenty of examples).
For use wth EC, you can set up binary sensors like the ones I copy/pasted below:
@patrick_jane THANK YOU for the good comparison and overview what needs to be considered.
Would be great to have this in a comparison matrix for all sensors ;-).
@all
I’m looking for a multi sensor (movement, light, temp, humidity) that ensures the light while walking through the rooms ans stairs.
Is there now a “acutal champion” (or some) ?
Thank you in advance
PS: I would rate reliability more important than the price.
I moved to HA in order to do away with intermediate bridges and external cloud involvement. So I use these zwave motion sensors. Bonus points they’re pet friendly so our cats don’t set them off. They are super simple, simply has a jumper that is used to set 3 levels of sensitivity and being zwave simply work with HA.
