Hi Guys, I think I may be on to something here.
So, for build 0854 in this case. (It doesn’t matter what build, just don’t click my links if not a match)
I could be wrong but I would suggest trying the following:
Use these link to fetch the firmware you need. (Replace 0854 with your version, as required)
https://ota.hubble.in/ota1/0854_patch/0854-03.10.11.sig
https://ota.hubble.in/ota1/0854_patch/0854-03.10.11.tar.gz
For 0854, I’ve found that you do not need to rename file to fw.pkg or change the numbers of the fw version in the name space.
Access your router and restrict the following and use the following console command (DD-WRT i.e)
iptables -I FORWARD -p tcp -d 54.235.152.208 -m multiport --dports 80,443,8080
Basically this command states to block both http and https traffic to the specific website. Instead of ota.hubble.in we enter the IP address of ota.hubble.in which is 54.235.152.208
Navigate to this link:
http://YOURCAMIP:8080/fwupgrade.html
(Replace IPOFCAM with the i.p address)
Select browse and upload the .sig file first (You are priming the burn)
Once complete, hit the back button on your browser and select browse once again.
Upload the .tar.gz firmware file
(This should take ~5mins)
Note:
This should enable you to stream on 3rd party and the native Hubble app and prevent programming from accessing the firmware files required for an update.
The camera requires wan for the native app to function and possibly after power failure but can’t confirm as it only happened to me once. Prior to blocking firmware host ip I restricted internet traffic the cameras mac address and after a power failure it didn’t want to stream anymore, I removed the restrictions and naturally, firmware updated in an instant.
This is all preliminary and I could be wrong as none of this had been tested among others with the same issue.
Hope this helps and I didn’t steer anyone in the wrong direction.
