Mount hosts /proc & /sys into add on container
Hi there!
I’m developing an addon for monitoring your home assistant box using Grafana and Prometheus; part of this is installing things like node-exporter and cAdvisor to collect all the metrics about the host. And part of that is needing access to the hosts /proc and /sys filesystems - is there a way to mount them into the add on container?
Cheers
Tom
Looks like this can’t be done as-is; do you think the maintainers would be open to adding “sys” and “proc” mounts for add ons? The code is here supervisor/supervisor/docker/addon.py at 4c108eea6411df12e9292e4171c1ca2c8d8b129f · home-assistant/supervisor · GitHub, I think I could probably put something together…
+1, I just ran into this while making a datadog agent add-on. There is no way currently to mount /proc and /sys/fs/cgroup, specifically, into the agent container, which enables various monitoring capabilities.
I would like a way to enable this in config, even if it requires turning off every single security flag.
Happy to contribute a PR if maintainers can weigh in on if such a thing would be acceptable.
