Moved From HA Docker To Hass.io Now Errors
Well i moved my HA docker On Ubnutu Server 18.04 NUC to Hass.io On Ubnutu Server 18.04 NUC
0.104.3.
The GUI gets very slow after about 2 Mins with all these errors.
Not sure if its my Network or something else.
Any help would be much appreciated.
2020-01-24 12:23:02 WARNING (MainThread) [homeassistant.components.sensor] Updating breaking_changes sensor took longer than the scheduled update interval 0:00:10
2020-01-24 12:23:02 WARNING (MainThread) [homeassistant.components.sensor] Updating rest sensor took longer than the scheduled update interval 0:00:30
2020-01-24 12:23:02 WARNING (MainThread) [homeassistant.components.sensor] Updating apcupsd sensor took longer than the scheduled update interval 0:00:30
2020-01-24 12:23:02 WARNING (MainThread) [homeassistant.components.sensor] Updating google_wifi sensor took longer than the scheduled update interval 0:00:30
2020-01-24 12:23:03 WARNING (MainThread) [homeassistant.components.sensor] Updating hive sensor took longer than the scheduled update interval 0:00:30
2020-01-24 12:23:03 WARNING (MainThread) [homeassistant.components.switch] Updating adguard switch took longer than the scheduled update interval 0:00:10
2020-01-24 12:23:03 ERROR (MainThread) [homeassistant.core] Error doing job: Exception in callback WebSocketResponse._send_heartbeat()
File "/usr/local/lib/python3.7/asyncio/events.py", line 88, in _run
self._context.run(self._callback, *self._args)
File "/usr/local/lib/python3.7/site-packages/aiohttp/web_ws.py", line 102, in _send_heartbeat
self._loop.create_task(self._writer.ping()) # type: ignore
AttributeError: 'NoneType' object has no attribute 'ping'
2020-01-24 12:23:03 WARNING (MainThread) [homeassistant.components.calendar] Updating google calendar took longer than the scheduled update interval 0:01:00
2020-01-24 12:23:03 WARNING (MainThread) [homeassistant.components.http.ban] Login attempt or request with invalid authentication from 172.30.32.2
2020-01-24 12:23:47 WARNING (MainThread) [homeassistant.components.sensor] Updating google_wifi sensor took longer than the scheduled update interval 0:00:30
2020-01-24 12:23:47 WARNING (MainThread) [homeassistant.components.sensor] Updating hive sensor took longer than the scheduled update interval 0:00:30
2020-01-24 12:23:47 WARNING (MainThread) [homeassistant.components.switch] Updating adguard switch took longer than the scheduled update interval 0:00:10
2020-01-24 12:24:30 WARNING (MainThread) [homeassistant.components.sensor] Updating breaking_changes sensor took longer than the scheduled update interval 0:00:10
2020-01-24 12:24:30 WARNING (MainThread) [homeassistant.components.sensor] Updating rest sensor took longer than the scheduled update interval 0:00:30
2020-01-24 12:24:30 WARNING (MainThread) [homeassistant.components.sensor] Updating apcupsd sensor took longer than the scheduled update interval 0:00:30
2020-01-24 12:24:30 WARNING (MainThread) [homeassistant.components.sensor] Updating hive sensor took longer than the scheduled update interval 0:00:30
2020-01-24 12:25:57 WARNING (MainThread) [homeassistant.components.switch] Updating hive switch took longer than the scheduled update interval 0:00:30
2020-01-24 12:25:57 WARNING (MainThread) [homeassistant.components.sensor] Updating google_wifi sensor took longer than the scheduled update interval 0:00:30
2020-01-24 12:25:57 WARNING (MainThread) [homeassistant.components.switch] Updating adguard switch took longer than the scheduled update interval 0:00:10
2020-01-24 12:25:58 WARNING (MainThread) [homeassistant.components.calendar] Updating google calendar took longer than the scheduled update interval 0:01:00
2020-01-24 12:25:58 INFO (MainThread) [homeassistant.components.binary_sensor] Setting up binary_sensor.cloud
2020-01-24 12:26:41 WARNING (MainThread) [homeassistant.components.sensor] Updating breaking_changes sensor took longer than the scheduled update interval 0:00:10
2020-01-24 12:26:41 WARNING (MainThread) [homeassistant.components.binary_sensor] Updating iss binary_sensor took longer than the scheduled update interval 0:00:30
2020-01-24 12:26:41 WARNING (MainThread) [homeassistant.components.sensor] Updating rest sensor took longer than the scheduled update interval 0:00:30
2020-01-24 12:26:41 WARNING (MainThread) [homeassistant.components.sensor] Updating apcupsd sensor took longer than the scheduled update interval 0:00:30
2020-01-24 12:26:41 WARNING (MainThread) [homeassistant.components.sensor] Updating google_wifi sensor took longer than the scheduled update interval 0:00:30
2020-01-24 12:26:41 WARNING (MainThread) [homeassistant.components.sensor] Updating hive sensor took longer than the scheduled update interval 0:00:30
2020-01-24 12:26:41 WARNING (MainThread) [homeassistant.components.switch] Updating adguard switch took longer than the scheduled update interval 0:00:10
2020-01-24 12:26:42 ERROR (MainThread) [homeassistant.components.webhook] Error processing webhook XXXXXXX Removed
File "/usr/src/homeassistant/homeassistant/components/webhook/__init__.py", line 77, in async_handle_webhook
response = await webhook["handler"](hass, webhook_id, request)
File "/usr/src/homeassistant/homeassistant/components/mobile_app/webhook.py", line 181, in handle_webhook
return await WEBHOOK_COMMANDS[webhook_type](hass, config_entry, webhook_payload)
File "/usr/src/homeassistant/homeassistant/components/mobile_app/webhook.py", line 126, in validate_and_run
return await func(hass, config_entry, data)
File "/usr/src/homeassistant/homeassistant/components/mobile_app/webhook.py", line 406, in webhook_update_sensor_states
await hass.data[DOMAIN][DATA_STORE].async_save(safe)
File "/usr/src/homeassistant/homeassistant/helpers/storage.py", line 136, in async_save
await self._async_handle_write_data()
File "/usr/src/homeassistant/homeassistant/helpers/storage.py", line 197, in _async_handle_write_data
self._write_data, self.path, data
concurrent.futures._base.CancelledError
2020-01-24 12:27:27 WARNING (MainThread) [homeassistant.components.sensor] Updating hive sensor took longer than the scheduled update interval 0:00:30
2020-01-24 12:28:09 WARNING (MainThread) [homeassistant.components.sensor] Updating breaking_changes sensor took longer than the scheduled update interval 0:00:10
2020-01-24 12:28:09 WARNING (MainThread) [homeassistant.components.sensor] Updating rest sensor took longer than the scheduled update interval 0:00:30
2020-01-24 12:28:09 WARNING (MainThread) [homeassistant.components.sensor] Updating apcupsd sensor took longer than the scheduled update interval 0:00:30
2020-01-24 12:28:09 WARNING (MainThread) [homeassistant.components.sensor] Updating google_wifi sensor took longer than the scheduled update interval 0:00:30
2020-01-24 12:28:09 WARNING (MainThread) [homeassistant.components.sensor] Updating hive sensor took longer than the scheduled update interval 0:00:30
2020-01-24 12:28:09 WARNING (MainThread) [homeassistant.components.switch] Updating adguard switch took longer than the scheduled update interval 0:00:10
2020-01-24 12:28:57 WARNING (MainThread) [homeassistant.components.sensor] Updating google_wifi sensor took longer than the scheduled update interval 0:00:30
2020-01-24 12:28:57 WARNING (MainThread) [homeassistant.components.switch] Updating adguard switch took longer than the scheduled update interval 0:00:10
2020-01-24 12:29:41 WARNING (MainThread) [homeassistant.components.sensor] Updating breaking_changes sensor took longer than the scheduled update interval 0:00:10
2020-01-24 12:29:41 WARNING (MainThread) [homeassistant.components.binary_sensor] Updating rest binary_sensor took longer than the scheduled update interval 0:00:30
2020-01-24 12:29:41 WARNING (MainThread) [homeassistant.components.switch] Updating hive switch took longer than the scheduled update interval 0:00:30
2020-01-24 12:29:41 WARNING (MainThread) [homeassistant.components.binary_sensor] Updating iss binary_sensor took longer than the scheduled update interval 0:00:30
2020-01-24 12:29:41 WARNING (MainThread) [homeassistant.components.sensor] Updating history_stats sensor took longer than the scheduled update interval 0:00:30
2020-01-24 12:29:41 WARNING (MainThread) [homeassistant.components.sensor] Updating rest sensor took longer than the scheduled update interval 0:00:30
2020-01-24 12:29:41 WARNING (MainThread) [homeassistant.components.sensor] Updating systemmonitor sensor took longer than the scheduled update interval 0:00:30
2020-01-24 12:29:41 WARNING (MainThread) [homeassistant.components.sensor] Updating apcupsd sensor took longer than the scheduled update interval 0:00:30
2020-01-24 12:29:41 WARNING (MainThread) [homeassistant.components.sensor] Updating hive sensor took longer than the scheduled update interval 0:00:30
2020-01-24 12:29:41 WARNING (MainThread) [homeassistant.components.switch] Updating adguard switch took longer than the scheduled update interval 0:00:10
2020-01-24 12:31:08 WARNING (MainThread) [homeassistant.components.calendar] Updating google calendar took longer than the scheduled update interval 0:01:00
2020-01-24 12:31:08 WARNING (MainThread) [homeassistant.components.sensor] Updating apcupsd sensor took longer than the scheduled update interval 0:00:30
2020-01-24 12:31:08 WARNING (MainThread) [homeassistant.components.sensor] Updating google_wifi sensor took longer than the scheduled update interval 0:00:30
2020-01-24 12:31:08 WARNING (MainThread) [homeassistant.components.sensor] Updating hive sensor took longer than the scheduled update interval 0:00:30
2020-01-24 12:31:57 WARNING (MainThread) [homeassistant.components.sensor] Updating breaking_changes sensor took longer than the scheduled update interval 0:00:10
2020-01-24 12:31:57 WARNING (MainThread) [homeassistant.components.sensor] Updating rest sensor took longer than the scheduled update interval 0:00:30
2020-01-24 12:31:57 WARNING (MainThread) [homeassistant.components.sensor] Updating hive sensor took longer than the scheduled update interval 0:00:30
2020-01-24 12:31:57 WARNING (MainThread) [homeassistant.components.switch] Updating adguard switch took longer than the scheduled update interval 0:00:10
2020-01-24 12:32:42 ERROR (MainThread) [homeassistant.components.webhook] Error processing webhook XXXXXXX Removed
2020-01-24 12:32:42 WARNING (MainThread) [homeassistant.components.sensor] Updating apcupsd sensor took longer than the scheduled update interval 0:00:30
2020-01-24 12:32:42 WARNING (MainThread) [homeassistant.components.sensor] Updating google_wifi sensor took longer than the scheduled update interval 0:00:30
2020-01-24 12:32:42 WARNING (MainThread) [homeassistant.components.switch] Updating adguard switch took longer than the scheduled update interval 0:00:10
2020-01-24 12:34:02 WARNING (MainThread) [homeassistant.components.calendar] Updating google calendar took longer than the scheduled update interval 0:01:00
2020-01-24 12:34:02 WARNING (MainThread) [homeassistant.components.sensor] Updating breaking_changes sensor took longer than the scheduled update interval 0:00:10
2020-01-24 12:34:02 WARNING (MainThread) [homeassistant.components.sensor] Updating google_wifi sensor took longer than the scheduled update interval 0:00:30
2020-01-24 12:34:02 WARNING (MainThread) [homeassistant.components.sensor] Updating hive sensor took longer than the scheduled update interval 0:00:30
2020-01-24 12:35:32 WARNING (MainThread) [homeassistant.components.sensor] Updating rest sensor took longer than the scheduled update interval 0:00:30
2020-01-24 12:35:32 WARNING (MainThread) [homeassistant.components.sensor] Updating apcupsd sensor took longer than the scheduled update interval 0:00:30
2020-01-24 12:35:32 WARNING (MainThread) [homeassistant.components.sensor] Updating hive sensor took longer than the scheduled update interval 0:00:30
2020-01-24 12:35:32 WARNING (MainThread) [homeassistant.components.switch] Updating adguard switch took longer than the scheduled update interval 0:00:10
2020-01-24 12:36:16 WARNING (MainThread) [homeassistant.components.sensor] Updating breaking_changes sensor took longer than the scheduled update interval 0:00:10
2020-01-24 12:36:16 WARNING (MainThread) [homeassistant.components.sensor] Updating google_wifi sensor took longer than the scheduled update interval 0:00:30
2020-01-24 12:36:16 WARNING (MainThread) [homeassistant.components.sensor] Updating hive sensor took longer than the scheduled update interval 0:00:30
2020-01-24 12:36:16 WARNING (MainThread) [homeassistant.components.switch] Updating adguard switch took longer than the scheduled update interval 0:00:10
2020-01-24 12:37:04 WARNING (MainThread) [homeassistant.components.calendar] Updating google calendar took longer than the scheduled update interval 0:01:00
2020-01-24 12:37:04 WARNING (MainThread) [homeassistant.components.sensor] Updating apcupsd sensor took longer than the scheduled update interval 0:00:30
2020-01-24 12:37:04 WARNING (MainThread) [homeassistant.components.sensor] Updating hive sensor took longer than the scheduled update interval 0:00:30
2020-01-24 12:37:48 WARNING (MainThread) [homeassistant.components.sensor] Updating breaking_changes sensor took longer than the scheduled update interval 0:00:10
2020-01-24 12:37:48 WARNING (MainThread) [homeassistant.components.binary_sensor] Updating iss binary_sensor took longer than the scheduled update interval 0:00:30
2020-01-24 12:37:48 WARNING (MainThread) [homeassistant.components.sensor] Updating rest sensor took longer than the scheduled update interval 0:00:30
2020-01-24 12:37:48 WARNING (MainThread) [homeassistant.components.sensor] Updating google_wifi sensor took longer than the scheduled update interval 0:00:30
2020-01-24 12:37:48 WARNING (MainThread) [homeassistant.components.switch] Updating adguard switch took longer than the scheduled update interval 0:00:10
2020-01-24 12:38:34 WARNING (MainThread) [homeassistant.components.binary_sensor] Updating rest binary_sensor took longer than the scheduled update interval 0:00:30
2020-01-24 12:38:34 WARNING (MainThread) [homeassistant.components.switch] Updating hive switch took longer than the scheduled update interval 0:00:30
2020-01-24 12:38:34 WARNING (MainThread) [homeassistant.components.switch] Updating tplink switch took longer than the scheduled update interval 0:00:30
2020-01-24 12:38:34 WARNING (MainThread) [homeassistant.components.sensor] Updating season sensor took longer than the scheduled update interval 0:00:30
2020-01-24 12:38:34 WARNING (MainThread) [homeassistant.components.sensor] Updating filesize sensor took longer than the scheduled update interval 0:00:30
2020-01-24 12:38:34 WARNING (MainThread) [homeassistant.components.sensor] Updating history_stats sensor took longer than the scheduled update interval 0:00:30
2020-01-24 12:38:34 WARNING (MainThread) [homeassistant.components.sensor] Updating systemmonitor sensor took longer than the scheduled update interval 0:00:30
2020-01-24 12:38:34 WARNING (MainThread) [homeassistant.components.sensor] Updating apcupsd sensor took longer than the scheduled update interval 0:00:30
2020-01-24 12:38:34 WARNING (MainThread) [homeassistant.components.sensor] Updating google_wifi sensor took longer than the scheduled update interval 0:00:30
2020-01-24 12:38:34 WARNING (MainThread) [homeassistant.components.sensor] Updating hive sensor took longer than the scheduled update interval 0:00:30
2020-01-24 12:38:34 WARNING (MainThread) [homeassistant.components.switch] Updating adguard switch took longer than the scheduled update interval 0:00:10
2020-01-24 12:39:24 ERROR (MainThread) [homeassistant.core] Error doing job: Exception in callback async_track_state_change.<locals>.state_change_listener(<Event state_...ew_state=None>) at /usr/src/homeassistant/homeassistant/helpers/event.py:81
File "/usr/src/homeassistant/homeassistant/helpers/event.py", line 103, in state_change_listener
event.data.get("new_state"),
File "/usr/src/homeassistant/homeassistant/core.py", line 364, in async_run_job
target(*args)
File "/usr/src/homeassistant/homeassistant/components/automation/state.py", line 92, in state_automation_listener
call_action()
File "/usr/src/homeassistant/homeassistant/components/automation/state.py", line 78, in call_action
context=to_s.context,
AttributeError: 'NoneType' object has no attribute 'context'
2020-01-24 12:39:27 WARNING (MainThread) [homeassistant.components.http.ban] Login attempt or request with invalid authentication from 192.168.85.25
2020-01-24 12:39:44 ERROR (stream_worker) [homeassistant.components.stream.worker] Error demuxing stream: No dts in packet
2020-01-24 12:40:13 WARNING (MainThread) [homeassistant.components.sensor] Updating google_wifi sensor took longer than the scheduled update interval 0:00:30
2020-01-24 12:42:15 ERROR (stream_worker) [homeassistant.components.stream.worker] Error demuxing stream: No dts in packet
2020-01-24 12:42:27 WARNING (MainThread) [homeassistant.components.switch] Updating adguard switch took longer than the scheduled update interval 0:00:10
2020-01-24 12:42:28 WARNING (MainThread) [homeassistant.components.sensor] Updating google_wifi sensor took longer than the scheduled update interval 0:00:30
2020-01-24 12:42:28 WARNING (MainThread) [homeassistant.components.sensor] Updating hive sensor took longer than the scheduled update interval 0:00:30
2020-01-24 12:42:55 ERROR (stream_worker) [homeassistant.components.stream.worker] Error demuxing stream: No dts in packet
2020-01-24 12:43:21 WARNING (MainThread) [homeassistant.components.sensor] Updating breaking_changes sensor took longer than the scheduled update interval 0:00:10
2020-01-24 12:43:21 WARNING (MainThread) [homeassistant.components.switch] Updating adguard switch took longer than the scheduled update interval 0:00:10
2020-01-24 12:45:50 WARNING (MainThread) [homeassistant.components.sensor] Updating google_wifi sensor took longer than the scheduled update interval 0:00:30
2020-01-24 12:45:50 WARNING (MainThread) [homeassistant.components.sensor] Updating hive sensor took longer than the scheduled update interval 0:00:30
2020-01-24 12:45:50 WARNING (MainThread) [homeassistant.components.switch] Updating adguard switch took longer than the scheduled update interval 0:00:10
2020-01-24 12:46:47 WARNING (MainThread) [homeassistant.components.switch] Updating adguard switch took longer than the scheduled update interval 0:00:10
Maybe similar to this one? Increased latency and endless "Update takes over 10 seconds" Warnings "Update fails" Errors
Thank @DavidFW1960 I did see that post but I have no duplicates of any integrations.
The worst part of it all is that the HA iPhone app keeps getting login errors every time I use the app.
I have to update my other topic again - the resolution just disappeared…
I removed the duplicates but after a while the errors came back.
Currently I have the assumption that it has something to do with a custom component (meross). I already opened an investigation there.
@cameron: Whats your config looking like? Any custom stuff?
