This is my first venture into RP 3B+ and I’m duly impressed. Amazing little device.
So, I automated my Chicken Coop (wife thinks I’m nuts). Sensors galore, 2 automated doors, cameras, sprinkler for hot weather, etc. All working well for quite some time on HA MacOS with Mosquitto broker also on the MacOS. So, I’m well past solving all the MQTT issues, configs etc.
I copied the relevant bits from the Mac config files to the Hassio config files. The MQTT stuff is all the same except for the server on Hassio. I’m sure thats where my problem is.
I’ll post the relevant bits o my config and whats not working:
Hass.io supervisor
|Version|184|
|System|HassOS 2.12|
Home Assistant 0.97.2
Path to configuration.yaml: /config
Frontend version: 20190805.0 - latest
Lovelace UI on HASSIO:
Same from my MacOS where it works great:
Sorry, new users can only put one image in a post.
States UI - all switches missing:
I wont bore you with the states page on the Hassio - it doesn’t show any switches.
Heres the States page from my Mac HA instance- works great:
configuration.yaml:
mqtt:
broker: a0d7b954-mqtt
username: !secret mqtt_username
password: !secret mqtt_password
client_id: home-assistant
amcrest:
- host: 192.168.1.151
resolution: high
scan_interval: 5
username: admin
password: mypassword
stream_source: rtsp
#Switches
switch:
- platform: mqtt
state_topic: "stat/water/POWER"
command_topic: "cmnd/water/POWER"
payload_on: "ON"
payload_off: "OFF"
state_on: "ON"
state_off: "OFF"
optimistic: false
qos: 0
retain: true
- platform: mqtt
name: "Inside Door ReedSW"
state_topic: "/stat/chickendoor/S1/"
command_topic: "/stat/chickendoor/S1/"
state_on: "ON"
state_off: "OFF"
payload_on: ""
payload_off: ""
optimistic: false
qos: 0
retain: true
/config/.storage/core.config_entries
"data": {
"entries": [
"connection_class": "cloud_poll",
"data": {
"track_home": true
"domain": "met",
"entry_id": "7b9eb6343f7c4dda80ddc1973ed39cdd",
"options": {},
"source": "onboarding",
"title": "Home",
"version": 1
"connection_class": "local_push",
"data": {},
"domain": "mqtt",
"entry_id": "a4fa5e25628d4ae08932f45cea65f0da",
"options": {},
"source": "import",
"title": "configuration.yaml",
"version": 1
"key": "core.config_entries",
"version": 1
I removed the MQTT from the Integrations page as suggested in a different post. It shows its getting its config properly:
I CAN connect to the MQTT broker on Hassio and post and see MQTT messages using the HIVEMQ app as well as the MQTT-SPY Java app.
Any help appreciated getting these switches to show up. It’s driving me NUTS!! I’m sure it’s something simple.
Jeff
PS limiting images to 1 on users trying to get help is not a good idea… making it 5 makes sense.
