Moved from supervised to haos šŸ¤Æ
Just did that todayā€¦ long shot :gun: Restore (~6GB full backup) took virtually ages (many hours) but it finally came back :up:
So what did I gain?
And what did I loose?
  • My cpu temperatureā€¦
    which was previously achieved with this 5 lines:
  - platform: command_line
    name: CPU Temperature
    command: "cat /sys/class/thermal/thermal_zone6/temp"
    unit_of_measurement: "Ā°C"
    value_template: "{{ value | multiply(0.001) | round(1) }}"
  • My bluetooth which I actually just were recently gifted with
    together with it all itā€™s devices
    (the hardware stayed the same!)
and last but not least the most crucial thing:
  • The possibility for a ā€œunattendedā€ boot - in my case without a display (hdmi) and keyboard connected to the ha server (x86-64 machine).
The last point makes it show stopper for me because my setup typically never has a display connected and therefor it canā€™t ā€œrecoverā€ itself after a power outage or what not.
I donā€™t expect that this behavior can even be changed from a user (me) because of the architecture of the managed OS with this install type.
Guess tomorrow I have to role back :tired_face:
I also did this migration and the CPU temp is working with the same command on HAOS, I just had to try different thermal zones (mine changed to thermal_zone2).
As for the boot without display connected, that one Iā€™m also curious about. I have a NUC system and it fails to recover after a power loss (it worked normally with supervised) and when I plug in to check it always work. I had this problem and didnā€™t even know it, will check the BIOS.
You can buy one of these. You didnā€™t say what hardware you were using but I donā€™t have any issues with RPIs without a display connected recovering.
https://www.amazon.com/gp/product/B07CXYBC2H/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1
You could check the bios for an option to boot without display. My NUC starts without attached display so itā€™s definitely not a HAOS limitation.
For the temperatures you could try other thermal zones than 6.
Iā€™m aware of this but as this is not a hardware limitation (I didnā€™t changed my server and with debian it worked without display) I rather donā€™t invest in such hardware when it can be solved in software only.
My device is like the raspberries powered by 5V but itā€™s smaller :pinching_hand: and a full blown x84-64 machine actually
Totally get what youā€™re saying. Butā€¦
I donā€™t believe this is a HAOS thing as real RPIs donā€™t have this issue nor do NUCs (depends on the bios I believe). It sure seems like a bios/hardware issue to me at least.
Out of curiosity though, what kind of device is it?
I can really rule out that issues because till today (before I replaced the debian supervised install with haos) it was capable of doing an unattended boot. I didnā€™t change the hardware and no bios setting.
I think this type of computers were called something like Intel Compute Stick. Mine is years old got 2gb of ram a weak Intel 3735F CPU and is fanless - everything I need :wink:
In my limited searching, yeah it was likely a grub/boot parameter debian was passing that HAOS isnā€™t.
I expect that also - maybe not only the missing display but and/or also the missing keyboard.
Real bummer - would expect a server OS is able to boot without attached display/keyboard :confused:
You could try to edit /mnt/boot/config.txt and see if you can get it to work correctly. I am not sure if that persists reboots but I believe it does. It wouldnā€™t persist a OS update though.
But what should be change? lol idk. Maybe something in the cmdline.txt.
Looks like you are running on an Intel compute stick or similar. I have a couple that I used several years ago to make dumb TVā€™s smarter and to run VPN so that I could stream Netflix outside the US. Mine would reboot after a power outage - believe it is a BIOS setting.
Like others have mentioned, I am also running HAOS on a NUC and it reboots after a power outage. Running without a monitor and keyboard connected. I manage it completely via the HA web interface or SSH.
In the past (till today) it always restarted/started fine without display or keyboard attached (that was with a debian installed which was topped with a supervised install). I was running this setup for years now.
Today I switched to HAOS and now the setup is not able to start (cold boot) without a display attached (it works when only a display is present but no keyboard actually).
I did not touch any bios settings and there is any way no setting regarding that in my (quite limited) bios available.
This is what I did in the past and what I thought I could continue with haos on my hardware :confused:
Whatā€™s wrong with the system monitor integration? Itā€™s got a processor temperature option, works without issue for me. No command line sensoring required.
Aside - youā€™re aware that the sensor youā€™re currently using for that only updates once a minute right? If thatā€™s what you want no worries I just ask because tools for that kind of stuff usually default to about every 15 seconds or so.
It was quite some time ago I rolled out my supervised install but I think I changed something in etc/default/grub back than:
GRUB_DEFAULT=0
GRUB_TIMEOUT=5
GRUB_DISTRIBUTOR=`lsb_release -i -s 2> /dev/null || echo Debian`
GRUB_CMDLINE_LINUX_DEFAULT="quiet"
GRUB_CMDLINE_LINUX=""
maybe I added the quiet? :thinking:
I use that integration but for cpu temperatre that didnā€™t work in the past for me - it showed a different temperature sensor and not the one from the cpu (the docs mention that this can not be changed)
Yes, no worries - was sufficient as long as it worked (pre HaOS) :grimacing:
Just tried and it doesnā€™t work:
Mine will boot without a display. Gotta be a setting in the biosā€¦
Interesting. Submit a bug? Perhaps thereā€™s some hardware requirement Iā€™m not aware of but as a core integration on HAOS Iā€™d expect that to work.
Sadly itā€™s not. That would be to easyā€¦ btw. mentioned already two times in this thread today.
So today Iā€™m in the process of setting up a fresh debian system for moving back to a supervised install.
This time I installed the minimal debian 11 and right away checked if the system boots without display/keyboard and here are my findings:
  • no keyboard doesnā€™t look a problem at all
  • no monitor causes grub indeed to donā€™t let the system boot by default
If the etc/default/grub file is changed from itā€™s original state
GRUB_DEFAULT=0
GRUB_TIMEOUT=5
to this one:
GRUB_DEFAULT=0
GRUB_TIMEOUT=0
GRUB_CMDLINE_LINUX_DEFAULT="nomodeset"
(changes quiet to nomodeset and timeout form 5 to 0)
the system boots without a display :rocket:
I wonder if such a change could me also added (or included?) to HaOS :thinking:
I recently instaled HAOS (HA Operating System)on a Lenovo ThinkCentre M710Q Mini PC Intel Core i3-6100T and can boot without keyboard, mouse or monitor by default.
