You can try it but you will need to change a lot of things
[{"id":"13d062f31b99d14b","type":"tab","label":"Panel LED MQTT","disabled":false,"info":"","env":[]},{"id":"286c9fab3d309530","type":"mqtt out","z":"13d062f31b99d14b","name":"","topic":"","qos":"1","retain":"","respTopic":"","contentType":"","userProps":"","correl":"","expiry":"","broker":"9943c62e9b99ad7d","x":970,"y":360,"wires":[]},{"id":"85c5bfe96924da76","type":"api-current-state","z":"13d062f31b99d14b","name":"temp salon","server":"28a2c6c3.915b2a","version":3,"outputs":1,"halt_if":"","halt_if_type":"str","halt_if_compare":"is_not","entity_id":"sensor.auriol_hg02832_2_124_t","state_type":"str","blockInputOverrides":true,"outputProperties":[{"property":"temperatura","propertyType":"msg","value":"","valueType":"entityState"},{"property":"data","propertyType":"msg","value":"","valueType":"entity"}],"for":"0","forType":"num","forUnits":"minutes","override_topic":false,"state_location":"payload","override_payload":"msg","entity_location":"data","override_data":"msg","x":310,"y":360,"wires":[["c25e92f76813dbde"]]},{"id":"c25e92f76813dbde","type":"function","z":"13d062f31b99d14b","name":"text to screen","func":"var tekst1 = msg.temperatura\nvar tekst2 = msg.data.attributes.unit_of_measurement\nmsg.tekst = tekst1+tekst2\n\nmsg.topic = \"wledPixel-8793/zone1/text\"\nmsg.payload = msg.tekst\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":520,"y":360,"wires":[["7f2d0665df77de2d"]]},{"id":"4e773f1f8a239c4a","type":"inject","z":"13d062f31b99d14b","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"","payloadType":"date","x":100,"y":320,"wires":[["85c5bfe96924da76"]]},{"id":"8d4549d66589df1e","type":"api-current-state","z":"13d062f31b99d14b","name":"hum salon","server":"28a2c6c3.915b2a","version":3,"outputs":1,"halt_if":"","halt_if_type":"str","halt_if_compare":"is_not","entity_id":"sensor.auriol_hg02832_2_124_h","state_type":"num","blockInputOverrides":true,"outputProperties":[{"property":"wilgotnosc","propertyType":"msg","value":"","valueType":"entityState"},{"property":"data","propertyType":"msg","value":"","valueType":"entity"}],"for":"0","forType":"num","forUnits":"minutes","override_topic":false,"state_location":"payload","override_payload":"msg","entity_location":"data","override_data":"msg","x":310,"y":460,"wires":[["bad86c4f266b3b8f"]]},{"id":"bad86c4f266b3b8f","type":"function","z":"13d062f31b99d14b","name":"text to screen","func":"var tekst1 = msg.wilgotnosc\nvar tekst2 = msg.data.attributes.unit_of_measurement\n\nmsg.tekst = tekst1+tekst2\n\nmsg.topic = \"wledPixel-8793/zone1/text\"\nmsg.payload = msg.tekst\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":520,"y":460,"wires":[["7f2d0665df77de2d","85c5bfe96924da76"]]},{"id":"d176189282e02d39","type":"mqtt in","z":"13d062f31b99d14b","name":"","topic":"wledPixel-8793/state","qos":"2","datatype":"auto-detect","broker":"9943c62e9b99ad7d","nl":false,"rap":true,"rh":0,"inputs":0,"x":110,"y":640,"wires":[["a67272e2c0e71c19"]]},{"id":"a67272e2c0e71c19","type":"debug","z":"13d062f31b99d14b","name":"status","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","statusVal":"","statusType":"auto","x":290,"y":640,"wires":[]},{"id":"ea67fa2bf6983925","type":"server-state-changed","z":"13d062f31b99d14b","name":"door change","server":"28a2c6c3.915b2a","version":4,"exposeToHomeAssistant":false,"haConfig":[{"property":"name","value":""},{"property":"icon","value":""}],"entityidfilter":"binary_sensor.czujnik_otwarcia_drzwi_contact","entityidfiltertype":"exact","outputinitially":false,"state_type":"habool","haltifstate":"","halt_if_type":"str","halt_if_compare":"is","outputs":1,"output_only_on_state_change":false,"for":"0","forType":"num","forUnits":"minutes","ignorePrevStateNull":true,"ignorePrevStateUnknown":true,"ignorePrevStateUnavailable":true,"ignoreCurrentStateUnknown":false,"ignoreCurrentStateUnavailable":false,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"},{"property":"data","propertyType":"msg","value":"","valueType":"eventData"},{"property":"topic","propertyType":"msg","value":"","valueType":"triggerId"}],"x":90,"y":60,"wires":[["96717b9749d0b1cc"]]},{"id":"504d199bb60e633a","type":"switch","z":"13d062f31b99d14b","name":"open/closed","property":"payload","propertyType":"msg","rules":[{"t":"true"},{"t":"false"}],"checkall":"true","repair":false,"outputs":2,"x":310,"y":60,"wires":[["7f58d193e9c6d34c"],["8ec92ce3142a2371"]]},{"id":"7c1042a8bfa8f752","type":"server-state-changed","z":"13d062f31b99d14b","name":"temp change","server":"28a2c6c3.915b2a","version":4,"exposeToHomeAssistant":false,"haConfig":[{"property":"name","value":""},{"property":"icon","value":""}],"entityidfilter":"sensor.auriol_hg02832_2_124_t","entityidfiltertype":"exact","outputinitially":false,"state_type":"str","haltifstate":"","halt_if_type":"str","halt_if_compare":"is","outputs":1,"output_only_on_state_change":true,"for":"0","forType":"num","forUnits":"minutes","ignorePrevStateNull":false,"ignorePrevStateUnknown":false,"ignorePrevStateUnavailable":false,"ignoreCurrentStateUnknown":false,"ignoreCurrentStateUnavailable":false,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"},{"property":"data","propertyType":"msg","value":"","valueType":"eventData"},{"property":"topic","propertyType":"msg","value":"","valueType":"triggerId"}],"x":90,"y":360,"wires":[["85c5bfe96924da76"]]},{"id":"3652792e1155e593","type":"server-state-changed","z":"13d062f31b99d14b","name":"hum change","server":"28a2c6c3.915b2a","version":4,"exposeToHomeAssistant":false,"haConfig":[{"property":"name","value":""},{"property":"icon","value":""}],"entityidfilter":"sensor.auriol_hg02832_2_124_h","entityidfiltertype":"exact","outputinitially":false,"state_type":"str","haltifstate":"","halt_if_type":"str","halt_if_compare":"is","outputs":1,"output_only_on_state_change":true,"for":"0","forType":"num","forUnits":"minutes","ignorePrevStateNull":false,"ignorePrevStateUnknown":false,"ignorePrevStateUnavailable":false,"ignoreCurrentStateUnknown":false,"ignoreCurrentStateUnavailable":false,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"},{"property":"data","propertyType":"msg","value":"","valueType":"eventData"},{"property":"topic","propertyType":"msg","value":"","valueType":"triggerId"}],"x":90,"y":460,"wires":[["8d4549d66589df1e"]]},{"id":"1cb1839be1769853","type":"inject","z":"13d062f31b99d14b","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"","payloadType":"date","x":100,"y":420,"wires":[["8d4549d66589df1e"]]},{"id":"7f2d0665df77de2d","type":"simple-queue","z":"13d062f31b99d14b","name":"queue 5s","firstMessageBypass":true,"bypassInterval":"5000","x":760,"y":360,"wires":[["286c9fab3d309530","d19ef62ca981fb41"]]},{"id":"bd02e35c4cf364c7","type":"inject","z":"13d062f31b99d14b","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"true","payloadType":"bool","x":110,"y":20,"wires":[["504d199bb60e633a"]]},{"id":"867976b5554ea26d","type":"inject","z":"13d062f31b99d14b","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"false","payloadType":"bool","x":290,"y":20,"wires":[["504d199bb60e633a"]]},{"id":"7f58d193e9c6d34c","type":"function","z":"13d062f31b99d14b","name":"scroll in LEFT","func":"msg.topic = \"wledPixel-8793/zone1/scrolleffectIn\"\nmsg.payload = 'PA_SCROLL_LEFT'\n\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":520,"y":20,"wires":[["07ee4598900ecdb6","ad5ff9b9b8b09cf1"]]},{"id":"07ee4598900ecdb6","type":"function","z":"13d062f31b99d14b","name":"scroll out LEFT","func":"msg.topic = \"wledPixel-8793/zone1/scrolleffectOut\"\nmsg.payload = 'PA_SCROLL_LEFT'\n\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":520,"y":60,"wires":[["1bcf7fe634823883","ad5ff9b9b8b09cf1"]]},{"id":"1bcf7fe634823883","type":"function","z":"13d062f31b99d14b","name":"scrollpause ","func":"msg.topic = \"wledPixel-8793/zone1/scrollpause\"\nmsg.payload = '0'\n\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":510,"y":100,"wires":[["ad5ff9b9b8b09cf1","41cb705d98f32a6d"]]},{"id":"41cb705d98f32a6d","type":"function","z":"13d062f31b99d14b","name":"text to screen","func":"msg.topic = \"wledPixel-8793/zone1/text\"\nmsg.payload = \"DRZWI OTWARTE!\"\nmsg.resend_messages = true;\n\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":520,"y":140,"wires":[["20087910656a86b4"]]},{"id":"ad5ff9b9b8b09cf1","type":"simple-queue","z":"13d062f31b99d14b","name":"queue 10ms","firstMessageBypass":true,"bypassInterval":"50","x":770,"y":80,"wires":[["643ce1930fad7e42"]]},{"id":"643ce1930fad7e42","type":"mqtt out","z":"13d062f31b99d14b","name":"","topic":"","qos":"1","retain":"true","respTopic":"","contentType":"","userProps":"","correl":"","expiry":"","broker":"9943c62e9b99ad7d","x":970,"y":80,"wires":[]},{"id":"8d2d119824a4860f","type":"mqtt out","z":"13d062f31b99d14b","name":"","topic":"","qos":"1","retain":"","respTopic":"","contentType":"","userProps":"","correl":"","expiry":"","broker":"9943c62e9b99ad7d","x":970,"y":240,"wires":[]},{"id":"8a28ffc4c85baa93","type":"function","z":"13d062f31b99d14b","name":"scroll out NONE","func":"msg.topic = \"wledPixel-8793/zone1/scrolleffectOut\"\nmsg.payload = 'PA_NO_EFFECT'\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":520,"y":260,"wires":[["dc5fc74446f8e44c"]]},{"id":"d69aec596935ec0c","type":"delay","z":"13d062f31b99d14b","name":"","pauseType":"delay","timeout":"3","timeoutUnits":"seconds","rate":"1","nbRateUnits":"1","rateUnits":"second","randomFirst":"1","randomLast":"5","randomUnits":"seconds","drop":false,"allowrate":false,"outputs":1,"x":980,"y":180,"wires":[["b7691cda8aafb607"]]},{"id":"13cb17ada1701986","type":"switch","z":"13d062f31b99d14b","name":"resend is false","property":"resend_messages","propertyType":"msg","rules":[{"t":"false"}],"checkall":"false","repair":false,"outputs":1,"x":780,"y":140,"wires":[["d69aec596935ec0c"]]},{"id":"a0f37c0703b8d63e","type":"switch","z":"13d062f31b99d14b","name":"no_effect payload sent","property":"payload","propertyType":"msg","rules":[{"t":"eq","v":"PA_NO_EFFECT","vt":"str"}],"checkall":"false","repair":false,"outputs":1,"x":800,"y":300,"wires":[["85c5bfe96924da76"]]},{"id":"20087910656a86b4","type":"msg-resend","z":"13d062f31b99d14b","interval":"3","intervalUnit":"secs","maximum":"10","bytopic":false,"clone":false,"firstDelayed":false,"addCounters":true,"waitForResend":true,"highRate":false,"outputCountField":"licznik","outputMaxField":"licznik_max","name":"","x":510,"y":180,"wires":[["ad5ff9b9b8b09cf1","13cb17ada1701986","6581604de4f41f6c"]]},{"id":"8ec92ce3142a2371","type":"function","z":"13d062f31b99d14b","name":"stop resend","func":"msg.resend_messages=false;\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":290,"y":140,"wires":[["20087910656a86b4"]]},{"id":"6581604de4f41f6c","type":"switch","z":"13d062f31b99d14b","name":"counter is max","property":"licznik","propertyType":"msg","rules":[{"t":"eq","v":"10","vt":"num"}],"checkall":"false","repair":false,"outputs":1,"x":780,"y":180,"wires":[["d69aec596935ec0c"]]},{"id":"dc5fc74446f8e44c","type":"simple-queue","z":"13d062f31b99d14b","name":"queue 10ms","firstMessageBypass":true,"bypassInterval":"50","x":770,"y":240,"wires":[["8d2d119824a4860f","a0f37c0703b8d63e"]]},{"id":"b7691cda8aafb607","type":"function","z":"13d062f31b99d14b","name":"scroll in UP","func":"msg.topic = \"wledPixel-8793/zone1/scrolleffectIn\"\nmsg.payload = 'PA_SCROLL_UP'\n\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":510,"y":220,"wires":[["dc5fc74446f8e44c","8a28ffc4c85baa93"]]},{"id":"d19ef62ca981fb41","type":"debug","z":"13d062f31b99d14b","name":"debug 8","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","statusVal":"","statusType":"auto","x":960,"y":420,"wires":[]},{"id":"6b99dc8a408cf3bb","type":"debug","z":"13d062f31b99d14b","name":"debug 9","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","statusVal":"","statusType":"auto","x":300,"y":600,"wires":[]},{"id":"cbc2f765e79681ef","type":"function","z":"13d062f31b99d14b","name":"brightness","func":"msg.topic = \"wledPixel-8793/intensity\"\nmsg.payload = msg.payload\n\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":310,"y":540,"wires":[["c367344537cd8bde","ae323913263a1b10"]]},{"id":"c367344537cd8bde","type":"mqtt out","z":"13d062f31b99d14b","name":"","topic":"","qos":"1","retain":"","respTopic":"","contentType":"","userProps":"","correl":"","expiry":"","broker":"9943c62e9b99ad7d","x":530,"y":540,"wires":[]},{"id":"11704d18bbd7d79e","type":"server-state-changed","z":"13d062f31b99d14b","name":"temp out","server":"28a2c6c3.915b2a","version":4,"exposeToHomeAssistant":false,"haConfig":[{"property":"name","value":""},{"property":"icon","value":""}],"entityidfilter":"sensor.pogoda_temperature","entityidfiltertype":"exact","outputinitially":false,"state_type":"str","haltifstate":"","halt_if_type":"str","halt_if_compare":"is","outputs":1,"output_only_on_state_change":true,"for":"0","forType":"num","forUnits":"minutes","ignorePrevStateNull":false,"ignorePrevStateUnknown":false,"ignorePrevStateUnavailable":false,"ignoreCurrentStateUnknown":false,"ignoreCurrentStateUnavailable":false,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"},{"property":"data","propertyType":"msg","value":"","valueType":"eventData"},{"property":"topic","propertyType":"msg","value":"","valueType":"triggerId"}],"x":100,"y":180,"wires":[["4ccceb76ac5deb23"]]},{"id":"4ccceb76ac5deb23","type":"api-current-state","z":"13d062f31b99d14b","name":"temp out","server":"28a2c6c3.915b2a","version":3,"outputs":1,"halt_if":"","halt_if_type":"str","halt_if_compare":"is_not","entity_id":"sensor.pogoda_temperature","state_type":"num","blockInputOverrides":true,"outputProperties":[{"property":"temperatura","propertyType":"msg","value":"","valueType":"entityState"},{"property":"data","propertyType":"msg","value":"","valueType":"entity"}],"for":"0","forType":"num","forUnits":"minutes","override_topic":false,"state_location":"payload","override_payload":"msg","entity_location":"data","override_data":"msg","x":280,"y":180,"wires":[["2912972eb24b88a8","6c950afef112b64d"]]},{"id":"2912972eb24b88a8","type":"delay","z":"13d062f31b99d14b","name":"","pauseType":"delay","timeout":"1","timeoutUnits":"seconds","rate":"1","nbRateUnits":"1","rateUnits":"second","randomFirst":"1","randomLast":"5","randomUnits":"seconds","drop":false,"allowrate":false,"outputs":1,"x":300,"y":300,"wires":[["85c5bfe96924da76"]]},{"id":"73eea73c62ddb509","type":"inject","z":"13d062f31b99d14b","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"","payloadType":"date","x":100,"y":140,"wires":[["4ccceb76ac5deb23"]]},{"id":"009b244b1aecd5de","type":"ha-device","z":"13d062f31b99d14b","name":"1 kliknięcie","server":"28a2c6c3.915b2a","version":0,"debugenabled":false,"exposeToHomeAssistant":false,"haConfig":[{"property":"name","value":""},{"property":"icon","value":""}],"inputs":0,"deviceType":"trigger","device":"73b15f7ea0e079c3a73c91df9103d5ef","event":{"platform":"device","domain":"mqtt","device_id":"73b15f7ea0e079c3a73c91df9103d5ef","type":"action","subtype":"single","discovery_id":"0x00124b002396fd5d action_single","metadata":{}},"capabilities":[],"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"eventData"},{"property":"topic","propertyType":"msg","value":"","valueType":"triggerId"}],"x":100,"y":240,"wires":[["4ccceb76ac5deb23"]]},{"id":"6c950afef112b64d","type":"function","z":"13d062f31b99d14b","name":"function round","func":"msg.temperatura = msg.temperatura.toFixed(1)\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":520,"y":300,"wires":[["c25e92f76813dbde"]]},{"id":"5bf0effbbe446be3","type":"eztimer","z":"13d062f31b99d14b","name":"","debug":true,"autoname":"sunrise - dusk","tag":"eztimer","topic":"","suspended":false,"sendEventsOnSuspend":false,"latLongSource":"haZone","latLongHaZone":"zone.home","lat":"50.27075","lon":"19.07613","timerType":"1","startupMessage":true,"ontype":"1","ontimesun":"sunrise","ontimetod":"17:00","onpropertytype":"msg","onproperty":"payload","onvaluetype":"num","onvalue":"8","onoffset":0,"onrandomoffset":0,"onsuppressrepeats":false,"offtype":"1","offtimesun":"dusk","offtimetod":"dusk","offduration":"00:01:00","offpropertytype":"msg","offproperty":"payload","offvaluetype":"num","offvalue":"1","offoffset":0,"offrandomoffset":0,"offsuppressrepeats":false,"resend":false,"resendInterval":"0s","mon":true,"tue":true,"wed":true,"thu":true,"fri":true,"sat":true,"sun":true,"x":100,"y":540,"wires":[["cbc2f765e79681ef","6b99dc8a408cf3bb"]]},{"id":"ae323913263a1b10","type":"debug","z":"13d062f31b99d14b","name":"debug 11","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","statusVal":"","statusType":"auto","x":540,"y":600,"wires":[]},{"id":"96717b9749d0b1cc","type":"api-current-state","z":"13d062f31b99d14b","name":"door sensor","server":"28a2c6c3.915b2a","version":3,"outputs":1,"halt_if":"","halt_if_type":"str","halt_if_compare":"is_not","entity_id":"binary_sensor.czujnik_otwarcia_drzwi_contact","state_type":"habool","blockInputOverrides":false,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"},{"property":"data","propertyType":"msg","value":"","valueType":"entity"}],"for":"0","forType":"num","forUnits":"minutes","override_topic":false,"state_location":"payload","override_payload":"msg","entity_location":"data","override_data":"msg","x":110,"y":100,"wires":[["504d199bb60e633a"]]},{"id":"3acc4ce086a7fc26","type":"inject","z":"13d062f31b99d14b","name":"","props":[{"p":"payload"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"trigger","payloadType":"str","x":90,"y":600,"wires":[["5bf0effbbe446be3"]]},{"id":"99467e16857d7ab1","type":"function","z":"13d062f31b99d14b","name":"scroll out UP","func":"msg.topic = \"wledPixel-8793/zone1/scrolleffectOut\"\nmsg.payload = 'PA_SCROLL_UP'\n\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":850,"y":540,"wires":[["d52fd39b2a0ae023","ebab0e168e2fe645"]]},{"id":"d52fd39b2a0ae023","type":"function","z":"13d062f31b99d14b","name":"scrollpause 0","func":"msg.topic = \"wledPixel-8793/zone1/scrollpause\"\nmsg.payload = '0'\n\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":850,"y":580,"wires":[["ebab0e168e2fe645","27563a5a6040c152"]]},{"id":"553dca8e6c082bd7","type":"mqtt out","z":"13d062f31b99d14b","name":"","topic":"","qos":"1","retain":"","respTopic":"","contentType":"","userProps":"","correl":"","expiry":"","broker":"9943c62e9b99ad7d","x":1190,"y":560,"wires":[]},{"id":"ebab0e168e2fe645","type":"simple-queue","z":"13d062f31b99d14b","name":"queue 10ms","firstMessageBypass":true,"bypassInterval":"10","x":1050,"y":560,"wires":[["553dca8e6c082bd7"]]},{"id":"ecd54ddadc158b6f","type":"inject","z":"13d062f31b99d14b","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"","payloadType":"date","x":700,"y":540,"wires":[["99467e16857d7ab1"]]},{"id":"27563a5a6040c152","type":"function","z":"13d062f31b99d14b","name":"text to screen","func":"msg.topic = \"wledPixel-8793/zone1/text\"\nmsg.payload = \" \"\n\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":860,"y":620,"wires":[["ebab0e168e2fe645"]]},{"id":"9943c62e9b99ad7d","type":"mqtt-broker","name":"HA Mosquitto","broker":"localhost","port":"1883","clientid":"","autoConnect":true,"usetls":false,"protocolVersion":"4","keepalive":"60","cleansession":true,"birthTopic":"","birthQos":"0","birthPayload":"","birthMsg":{},"closeTopic":"","closeQos":"0","closePayload":"","closeMsg":{},"willTopic":"","willQos":"0","willPayload":"","willMsg":{},"userProps":"","sessionExpiry":""},{"id":"28a2c6c3.915b2a","type":"server","name":"Home Assistant","version":5,"addon":true,"rejectUnauthorizedCerts":true,"ha_boolean":"y|yes|true|on|home|open","connectionDelay":true,"cacheJson":true,"heartbeat":false,"heartbeatInterval":30,"areaSelector":"friendlyName","deviceSelector":"friendlyName","entitySelector":"friendlyName","statusSeparator":"at: ","statusYear":"hidden","statusMonth":"short","statusDay":"numeric","statusHourCycle":"h23","statusTimeFormat":"h:m","enableGlobalContextStore":true}]
I made a lot of changes and not all things working properly right now, but I dont have time to debug and fix them.
