My recorder errors are getting worse, it no longer starts the recorder, so no history is available.Since I’d been having these errors for a while, I decided to delete my HomeAssistant database and start over.That didn’t help, same type of errors. Below is the first error that happened.
2021-02-05 17:41:07 ERROR (Recorder) [sqlalchemy.pool.impl.QueuePool] Exception during reset or similar
File "/usr/local/lib/python3.8/site-packages/sqlalchemy/engine/base.py", line 1276, in _execute_context
self.dialect.do_execute(
File "/usr/local/lib/python3.8/site-packages/sqlalchemy/engine/default.py", line 609, in do_execute
cursor.execute(statement, parameters)
pyodbc.ProgrammingError: ('42000', "[42000] [FreeTDS][SQL Server]Introducing FOREIGN KEY constraint 'FK__states__old_stat__6477ECF3' on table 'states' may cause cycles or multiple cascade paths. Specify ON DELETE NO ACTION or ON UPDATE NO ACTION, or modify other FOREIGN KEY constraints. (1785) (SQLExecDirectW)")
File "/usr/local/lib/python3.8/site-packages/sqlalchemy/engine/base.py", line 749, in _rollback_impl
self.engine.dialect.do_rollback(self.connection)
File "/usr/local/lib/python3.8/site-packages/sqlalchemy/engine/default.py", line 559, in do_rollback
dbapi_connection.rollback()
pyodbc.ProgrammingError: ('25000', '[25000] [FreeTDS][SQL Server]The ROLLBACK TRANSACTION request has no corresponding BEGIN TRANSACTION. (3903) (SQLEndTran)')
File "/usr/src/homeassistant/homeassistant/components/recorder/__init__.py", line 273, in run
self._setup_connection()
File "/usr/src/homeassistant/homeassistant/components/recorder/__init__.py", line 615, in _setup_connection
Base.metadata.create_all(self.engine)
File "/usr/local/lib/python3.8/site-packages/sqlalchemy/sql/schema.py", line 4553, in create_all
bind._run_visitor(
File "/usr/local/lib/python3.8/site-packages/sqlalchemy/engine/base.py", line 2095, in _run_visitor
conn._run_visitor(visitorcallable, element, **kwargs)
File "/usr/local/lib/python3.8/site-packages/sqlalchemy/engine/base.py", line 1656, in _run_visitor
visitorcallable(self.dialect, self, **kwargs).traverse_single(element)
File "/usr/local/lib/python3.8/site-packages/sqlalchemy/sql/visitors.py", line 145, in traverse_single
return meth(obj, **kw)
File "/usr/local/lib/python3.8/site-packages/sqlalchemy/sql/ddl.py", line 783, in visit_metadata
self.traverse_single(
File "/usr/local/lib/python3.8/site-packages/sqlalchemy/sql/ddl.py", line 827, in visit_table
self.connection.execute(
File "/usr/local/lib/python3.8/site-packages/sqlalchemy/engine/base.py", line 1011, in execute
return meth(self, multiparams, params)
File "/usr/local/lib/python3.8/site-packages/sqlalchemy/sql/ddl.py", line 72, in _execute_on_connection
return connection._execute_ddl(self, multiparams, params)
File "/usr/local/lib/python3.8/site-packages/sqlalchemy/engine/base.py", line 1068, in _execute_ddl
ret = self._execute_context(
File "/usr/local/lib/python3.8/site-packages/sqlalchemy/engine/base.py", line 1316, in _execute_context
self._handle_dbapi_exception(
File "/usr/local/lib/python3.8/site-packages/sqlalchemy/engine/base.py", line 1505, in _handle_dbapi_exception
self._autorollback()
File "/usr/local/lib/python3.8/site-packages/sqlalchemy/util/langhelpers.py", line 82, in __exit__
compat.raise_(value, with_traceback=traceback)
File "/usr/local/lib/python3.8/site-packages/sqlalchemy/util/compat.py", line 182, in raise_
raise exception
File "/usr/local/lib/python3.8/site-packages/sqlalchemy/engine/base.py", line 888, in _autorollback
self._root._rollback_impl()
File "/usr/local/lib/python3.8/site-packages/sqlalchemy/engine/base.py", line 751, in _rollback_impl
self._handle_dbapi_exception(e, None, None, None, None)
File "/usr/local/lib/python3.8/site-packages/sqlalchemy/engine/base.py", line 1405, in _handle_dbapi_exception
util.raise_(
raise exception
sqlalchemy.exc.ProgrammingError: (pyodbc.ProgrammingError) ('25000', '[25000] [FreeTDS][SQL Server]The ROLLBACK TRANSACTION request has no corresponding BEGIN TRANSACTION. (3903) (SQLEndTran)')
(Background on this error at: http://sqlalche.me/e/13/f405)
File "/usr/local/lib/python3.8/site-packages/sqlalchemy/pool/base.py", line 697, in _finalize_fairy
fairy._reset(pool)
File "/usr/local/lib/python3.8/site-packages/sqlalchemy/pool/base.py", line 893, in _reset
pool._dialect.do_rollback(self)
2021-02-05 17:41:07 ERROR (Recorder) [homeassistant.components.recorder] Error during connection setup: (pyodbc.ProgrammingError) ('25000', '[25000] [FreeTDS][SQL Server]The ROLLBACK TRANSACTION request has no corresponding BEGIN TRANSACTION. (3903) (SQLEndTran)')
(Background on this error at: http://sqlalche.me/e/13/f405) (retrying in 3 seconds)
2021-02-05 17:41:10 ERROR (Recorder) [sqlalchemy.pool.impl.QueuePool] Exception during reset or similar
This is with SQL Server 2019 on Windows 10.
System Health
version |
core-2021.2.1 |
installation_type |
Home Assistant OS |
dev |
false |
hassio |
true |
docker |
true |
virtualenv |
false |
python_version |
3.8.7 |
os_name |
Linux |
os_version |
5.4.86 |
arch |
x86_64 |
timezone |
America/Los_Angeles |
Home Assistant Community Store
GitHub API |
ok |
Github API Calls Remaining |
4763 |
Installed Version |
1.10.1 |
Stage |
running |
Available Repositories |
709 |
Installed Repositories |
7 |
Home Assistant Cloud
logged_in |
false |
can_reach_cert_server |
ok |
can_reach_cloud_auth |
ok |
can_reach_cloud |
ok |
Hass.io
host_os |
Home Assistant OS 5.10 |
update_channel |
stable |
supervisor_version |
supervisor-2021.01.7 |
docker_version |
19.03.13 |
disk_total |
52.2 GB |
disk_used |
10.9 GB |
healthy |
true |
supported |
true |
board |
ova |
supervisor_api |
ok |
version_api |
ok |
installed_addons |
Samba share (9.3.0), Mosquitto broker (5.1), Duck DNS (1.12.4), Terminal & SSH (9.0.0), File editor (5.2.0), Visual Studio Code (3.0.1), Grafana (6.0.0), Node-RED (8.0.1), FTP (3.5.0), roombapw Docker Image (1.0.0), rest980 Docker Image (20200205), php-nginx Docker Image (latest) |
Lovelace
dashboards |
1 |
resources |
6 |
views |
6 |
mode |
storage |
Any ideas would be appreciated. Thanks.
