Multiple configurations for other devices
It’s a shot in the dark, but can i have multiple configurations for homeassistant?
For example, i have a small tablet where i want to display homeassistant on.
But i don’t want to change my configuration for it because it looks good on my computer.
So can i have another configuration for each other device?
(HADashboard is my last resort :slight_smile: )
Why not just create a unique view for each device in lovelace?
I have my main view, and a touch view that works better for mounted tablets.
In the top right, select the 3 dots, then configure-ui. NOTE: once you do this, you will now have the manual ui (which is way better in my opinion)
Once in edit mode, there will be a ‘+’ in the view bar. Create a new view and configure that how you would like for your device.
I’m not sure if there is a way to set a default view per device, but it’s not that hard to select which view you want after the fact.
Thank you for the advice!
But i have a few views and otherwise it gets to crowded for top-bar.
Maybe a second last resort :slight_smile:
Ever tried out the custom header card? It allows per device settings and much more.
