Multiple-entity-row card: local number formatting update broke view
Hi there,
starting with I think v4.3.0 gorgeous multiple-entity-row card broke the look of entities.
Examples:
Number format setting is AUTO
Therefore everything is shown right e. g. monetary or power attributes/entities:
BUT I have a lot of Version information entities/attributes, which now are shown wrong:
In the above example both entities (the ones presented right and the wrong ones marked in red) have the exact same configuration. No customization.
So it’s completely random. I don’t know if it’s a bug or if we need to configure the format of entities/attributes shown in multiple-entity-row since the v4.3.0 update.
Happy for every hint - help appreciated.
That card has had a lot of updates in the past few days. This might be a new issue that has crept in while that was happening.
Ask here: https://community.home-assistant.io/t/lovelace-multiple-entity-row/109109
Then create an issue here if it really is a bug:
I suspect this bug may happen if:
  • there is a round(...) filter in value_template for template sensor;
  • no unit is displayed for this sensor in the row (unit: false).
See this:
Interesting. For first few affected entities/attributes I checked I could NOT confirm this:
as shown in the screenshot of my original post both numbers - the ones shown right and the ones shown wrong - are created exactly the same way. So unfortunately the pattern you suspect does not match. It‘s completely random.
I hope the maintainer will start digging into this.
The GitHub issue you linked is CLOSED. So I don’t think the maintainer will respond to answers there…
Strange, I changed my global settings several times, then restored it to “1 123,00” - now ALL my values are displayed as “1123.00”.
Seems this is not as predictable as I suspected…
He may respond, actually. He responded is similar cases.
Update:
After 2-3 minutes the situation repeated:
Values w/o units on the 2nd line are displayed wrong.
