The request is to have multiple envisalink modules as part of the same HA instance. I imagine that with rental units, offices, Airbnb, this request is going to become more prevalent.
Apologies to revive this old topic but I am wondering if there is a technical reason that it is not possible to have multiple envisalink modules in one instance of HA?
A workaround is proposed to create an instance of HA (via docker) for each envisalink module and use home-assistant-remote:
However, this seems to waste a lot of resources if there is no real reason to keep things separate.So I wanted to see if there is a technical barrier here (from the envisalink side perhaps) that makes this impossible/very hard or if this just needs to be implemented.
I actually got this working last night, by creating a second āEnvisalinkā component as a custom component and just renaming the variable from āEnvisalinkā to āEnvisalink1ā
I ended up changing the name of the component as well as the name in the manifest.json and __init__.py . I am not sure if that was necessary or the right way of doing this.
It would be so much better if you could define āsystemsā each of which is its own settings and zones. I am definitely not experienced enough in python but might try and see what I might be able to accomplish
Any chance you might provide a little tutorial on how you did this? I have never created or used a custom component. I imagine itās getting the regular āEnvisalinkā component and then copying it to, āEnvisalink1.ā But if yours is still working it would be nice to set this up correctly.
Copy the files found in this github into your custom components folder (config/custom_components/envisalink1) [or rename envisalink1 to whatever you like.] Change the name āEnvisalinkā to āEnvisalink1ā in both manifest.json and __init__.py
