Multiple "is taking over 10 seconds" warnings after upgrading to 2022.6.7
I’m running hassio on RPI4 8GB USB SSD - running smoothly!
BUT since upgrading to 2022.6.7, on every (scheduled) host reboot I’m getting multiple “is taking over 10 seconds” warnings - never had this before.
I attach sample log:
2022-06-29 07:42:14 WARNING (MainThread) [homeassistant.setup] Setup of input_boolean is taking over 10 seconds.
2022-06-29 07:42:14 WARNING (MainThread) [homeassistant.setup] Setup of input_button is taking over 10 seconds.
2022-06-29 07:42:14 WARNING (MainThread) [homeassistant.setup] Setup of counter is taking over 10 seconds.
2022-06-29 07:42:14 WARNING (MainThread) [homeassistant.setup] Setup of input_number is taking over 10 seconds.
2022-06-29 07:42:14 WARNING (MainThread) [homeassistant.setup] Setup of input_datetime is taking over 10 seconds.
2022-06-29 07:42:14 WARNING (MainThread) [homeassistant.setup] Setup of zone is taking over 10 seconds.
2022-06-29 07:42:14 WARNING (MainThread) [homeassistant.setup] Setup of input_select is taking over 10 seconds.
2022-06-29 07:42:14 WARNING (MainThread) [homeassistant.setup] Setup of timer is taking over 10 seconds.
2022-06-29 07:42:14 WARNING (MainThread) [homeassistant.setup] Setup of input_text is taking over 10 seconds.
2022-06-29 07:42:14 WARNING (MainThread) [homeassistant.components.update] Setup of update platform hassio is taking over 10 seconds.
2022-06-29 07:42:15 WARNING (MainThread) [homeassistant.components.sensor] Setup of sensor platform systemmonitor is taking over 10 seconds.
2022-06-29 07:42:15 WARNING (MainThread) [homeassistant.components.sensor] Setup of sensor platform command_line is taking over 10 seconds.
Any help would be welcome!
Welcome to my world. In my case if you look in the HA docker you may see it has fired up another instance with a higher PID. This then causes all sorts of timeouts.
Kill it (kill -9 PID) - only one should be running. Started for me with 2022.6.x
My Installation Type: Home Assistant OS don’t have any docker containers
So is mine.
SSH in and use :
docker exec -it homeassistant /bin/bash
Then type :
top
If you have more than one homeassistant running - that’s your issue.
Never used SSH access with my RPI HA
There is an official add-on. Worth installing to check if your issue is the same as mine (and then uninstall if it’s not).
You can use it as a terminal within Home Assistant itself.
I’m fully aware of the Terminal & SSH addon, (I use SSH extensively on other non-HA devices), but what makes me think that I don’t suffer from you scenario, is that my Processor use idles almost constantly at 2-3%. Yes at boot-up it can get up to 60% (maximum, and limited to ONE such reading!).
I think if I had more than one HA instance, things would look different.
It adds another 1-2% cpu usage. Anyway - it was just a suggestion as it’s what causes those problems on mine.
Don’t misunderstand me, I enjoy your input, and many thanks for that. I also wish I could help you. See this open issue on Github (https://github.com/home-assistant/core/issues/73863).
Thank you, that command was helpful. I’ve never used docker and so far I’ve managed to avoid digging into it, but this will be a great starting point for learning.
Meanwhile, I also get a lot of “is taking over 10 seconds” warnings. My top command output looks very similar to what @w35l3y posted. If I’m reading this correctly, there’s only one process which launched python to run homeassistant. I’m on core 2022.6.7 and OS 8.2.
At this point it’s not a show-stopper for me, but it does seem that HA is very chatty with the logs. Given the limited writes an SD card can tolerate, this seems counter-productive. If you were to run HA for a long period without restarting, the growing log files might also become an issue.
I wouldn’t worry as the limiting factor is typically loading yaml configurations and related to your hardware. In the next version, the yaml loading has been optimized by @bdraco, so it should be faster. He can correct me if I’m missing the mark. But that’s the take away I’ve gathered from his recent PRs.
If the problem is because the system is cpu or I/o bound there is a good chance it will be much better in 2022.7. If connecting to the device/service is slow it won’t help
How come I NEVER had this before 2022.6.7, as others have also noted?
If you could get a py-spy during startup we might be able to get an idea why, but since there weren’t any core changes between 2022.6.6 and 2022.6.7 (Comparing 2022.6.6...2022.6.7 · home-assistant/core · GitHub) its not obvious why.
fwiw, running the latest dev, and all of the improvements Nick did, I still see several of those too.
And I did already upgrade the hardware to a mini pc, with a now super fast restart time of 1 minute…52 sec even. wow, never seen before
but, its way less than before and intermittent. `for testing purposes just did another restart, an now only see:
Logger: homeassistant.setup
Source: /usr/local/lib/python3.10/asyncio/events.py:80
First occurred: 16:52:28 (1 occurrences)
Last logged: 16:52:28
Setup of rest is taking over 10 seconds.
to illustrate, the one before did:
2022-06-29 16:20:48 WARNING (MainThread) [homeassistant.setup] Setup of input_select is taking over 10 seconds.
2022-06-29 16:20:48 WARNING (MainThread) [homeassistant.setup] Setup of input_datetime is taking over 10 seconds.
2022-06-29 16:20:48 WARNING (MainThread) [homeassistant.setup] Setup of rest is taking over 10 seconds.
2022-06-29 16:20:48 WARNING (MainThread) [homeassistant.setup] Setup of input_boolean is taking over 10 seconds.
2022-06-29 16:20:48 WARNING (MainThread) [homeassistant.setup] Setup of input_number is taking over 10 seconds.
2022-06-29 16:20:48 WARNING (MainThread) [homeassistant.setup] Setup of zone is taking over 10 seconds.
2022-06-29 16:20:48 WARNING (MainThread) [homeassistant.setup] Setup of python_script is taking over 10 seconds.
2022-06-29 16:20:48 WARNING (MainThread) [homeassistant.config_entries] Config entry 'Philips Hue 1' for hue integration not ready yet: Error connecting to the Hue bridge at 192.168.1.212; Retrying in background
2022-06-29 16:20:48 WARNING (MainThread) [homeassistant.components.binary_sensor] Setup of binary_sensor platform mqtt is taking over 10 seconds.
I have same problem in latest stable version 2022.8.
2022-08-10 11:37:48.419 WARNING (MainThread) [homeassistant.setup] Setup of input_number is taking over 10 seconds.
2022-08-10 11:37:48.436 WARNING (MainThread) [homeassistant.setup] Setup of input_select is taking over 10 seconds.
2022-08-10 11:37:48.440 WARNING (MainThread) [homeassistant.setup] Setup of input_text is taking over 10 seconds.
2022-08-10 11:37:48.444 WARNING (MainThread) [homeassistant.setup] Setup of input_button is taking over 10 seconds.
Home Assistant 2022.9.7
Supervisor 2022.09.1
Operating System 9.0
Frontend 20220907.2 - latest
Raspberry Pi 4 4GB + SSD + Conbee2
2022-09-28 05:13:53.437 WARNING (MainThread) [homeassistant.setup] Setup of automation is taking over 10 seconds.
2022-09-28 05:13:53.444 WARNING (MainThread) [homeassistant.components.binary_sensor] Setup of binary_sensor platform deconz is taking over 10 seconds.
2022-09-28 05:13:53.445 WARNING (MainThread) [homeassistant.components.light] Setup of light platform deconz is taking over 10 seconds.
2022-09-28 05:13:53.447 WARNING (MainThread) [homeassistant.components.sensor] Setup of sensor platform deconz is taking over 10 seconds.
2022-09-28 05:13:53.448 WARNING (MainThread) [homeassistant.components.sensor] Setup of sensor platform forecast_solar is taking over 10 seconds.
2022-09-28 05:13:53.450 WARNING (MainThread) [homeassistant.components.weather] Setup of weather platform met is taking over 10 seconds.
2022-09-28 05:13:53.452 WARNING (MainThread) [homeassistant.components.climate] Setup of climate platform deconz is taking over 10 seconds.
2022-09-28 05:13:53.453 WARNING (MainThread) [homeassistant.components.switch] Setup of switch platform deconz is taking over 10 seconds.
Varies a bit each time, but at least some timeouts with every boot.
Same here with my snmp sensors. Outside of HA SNMP polling takes less than a sec.
Logger: homeassistant.helpers.entity
Source: helpers/entity.py:538
First occurred: 22:07:27 (3 occurrences)
Last logged: 22:09:27
Update of sensor.iot_vlan_interface_down_throughput is taking over 10 seconds
Update of sensor.home_vlan_interface_down_throughput is taking over 10 seconds
The “Update of … is taking over 10 seconds” occurrences have increases between 2023.4 and 2023.5. In my case it’s three specific entities with fan.levoit_air_cleaner being the worst
Source: helpers/entity.py:749
First occurred: 11:26:21 am (3 occurrences)
Last logged: 0:18:31 pm
  • Update of binary_sensor.bedroom_occupancy is taking over 10 seconds
  • Update of fan.levoit_air_cleaner is taking over 10 second
