Hi All!
I am trying to use multiple Notify.Events tokens for use with multiple channels. I know there’s another post " Multiple notify.events channels" but this does not answer the question of using multiple tokens, only bypassing the problem by using another platform which defies the purpose a bit.
In the Notify.Events - Home Assistant explanation, a token variable is said to be available “in case you want to override the channel to get this message to”. Has anyone had any success with this?
I have tried:
setting up 2 versions of the notify.events config, each with their own token. System check refuses to add more than one and using a different name is also rejected with errors.
Using the token variable to override: this does nothing. Config accepts this but message still sent to the original token in config
Any help or thoughts would be appreciated!
